Author Topic: Case or Decase, that is the question.  (Read 5293 times)
majoly
  • Last login:February 11, 2016, 03:51:11 pm
« on: February 01, 2016, 08:14:41 am »
Got lot of room inside my frame.
I was considering on decasing my computer parts and add few fans on the back of my arcade.
Of course I dont what to do that if I end up with serious heating issues.
Personal experience on people that decased their computer and what they did to make sure heat is not an issue?
Thank alot. I love this place :)
« Last Edit: February 01, 2016, 09:55:41 am by majoly »
Automark
  • Arcade in Spain ?
Re: Case or not Decased, that is the question.
« Reply #1 on: February 01, 2016, 09:25:19 am »
decase, ur cab is a case
Phreakwars
  • Last login:September 20, 2025, 03:30:56 am
  • Waka-Waka
    • forum.arcadecontrols.com/index.php/topic,146325.0.html
    • My Facebook Page
« Reply #2 on: February 01, 2016, 09:27:52 am »
decase. Heat will NEVER be an issue with a bigger enclosure that breathes .vs being boxed in.
jtslade
  • Last login:February 13, 2025, 10:06:51 pm
  • Keep it looking originallish!
« Reply #3 on: February 01, 2016, 09:37:29 am »
Case, as it makes it easy to remove and work on it or upgrade.. Easy to clean..
Yes it does not look as cool but it'd say spend more time on front end, functionality, use better controls, make it look great on the outside, CRT fine tuning.. Etc
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
Thenasty
  • Last login:Yesterday at 04:30:09 pm
« Reply #4 on: February 01, 2016, 09:50:37 am »
"Case or Decase" don't matter if you have the back cover of the cabinet removed (leaving the cab wide open from the back end).
My experience is that the back door was always off the cab. The back is facing the wall.
In your case, your set up might be different.
Free VGA Breakout Cable
  • Last login:Yesterday at 08:33:44 pm
Re: Case or Decase, that is the question.
« Reply #5 on: February 01, 2016, 10:24:21 am »
I like to decase personally, but leave cased if you're lazy. Decased looks nicer. This is from my Janky Kong build.
Peabo
  • Pinball junkie
    • Virtual Pinball Build
« Reply #6 on: February 01, 2016, 10:33:40 am »
yotsuya, I like your solution for video card stabilization, I'll have to steal that
n3wt0n
« Reply #7 on: February 01, 2016, 02:06:25 pm »
I perfer decased. Yotsuya's pic is the perfect example of why. It can be very clean when done right.
« Reply #8 on: February 01, 2016, 02:08:12 pm »
Yeah, that's the one that works best for me. Especially with that custom metal plate.
« Reply #9 on: February 01, 2016, 02:11:09 pm »
I also leave it cased if it's a project for someone else.
majoly
« Reply #10 on: February 01, 2016, 02:27:41 pm »
Thanks for all your feedbacks.
I like the "Your cab is a case" makes sense.
And love the metal plate, its clean. Ill try to make something like that once I solve I my problems :).
Thank you
paigeoliver
  • Awesome face!
« Reply #11 on: February 01, 2016, 06:50:17 pm »
Real arcade games that run on PC hardware keep the computer in the case (except for PC based Megatouch style games, which are designed to mount the motherboard caseless).
Of the many, many cabinets I have built I have only had one overheat, it was one of the few I decased.
Brizzle
  • Last login:April 16, 2017, 07:13:27 pm
  • I love designing custom graphics. Need some?
« Reply #12 on: February 02, 2016, 12:38:52 pm »
My preferance is to decase.  It exposes more air to the parts, which means cooler, which means that it lasts longer.  Plus, I dropped 8 lbs of weight by decasing form the PC case.  AND, it's easier to blow the dust off of the components.  Dust is everywhere, and you'll have to take the computer out and open it up to clean the dust off.
THAT SAID, definitely consider what Paige says, too.  He has a lot of experience.  If you're stressing, just hook that case up.  but why not try decasing?
Once you figure out how to secure everything your first time, it will be easy.
« Last Edit: February 02, 2016, 01:05:08 pm by Brizzle »
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #13 on: February 08, 2016, 03:35:38 pm »
I've always deceased and I don't what I've gotten from it other than the space I needed.  If my next project allows for the computer to stay in the case, I'm leaving it.  As far as the look, I don't think it looks better necessarily but it looks more like what you would expect an old school arcade game to look like on the inside.  Honestly, it doesn't come up though.  When people ask how it has so many games, I say "there's a computer in there" and then we play.  No one asks, "can I see what a computer looks like?"
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #14 on: February 10, 2016, 12:23:09 am »
Case and watercool. Best of both worlds!
My old user name was marlborroman13, but I kicked the habit many years ago!
jbl77
  • Last login:March 01, 2024, 04:52:21 pm
« Reply #15 on: February 10, 2016, 01:55:41 am »
I remember before watercooling was chique building a kit and always worrying about a leak.
At least I didn't do what one buddy did...used a Peltier element and mounted it upside down  :laugh2:
ark_ader
  • I glow in the dark.
« Reply #16 on: February 10, 2016, 09:10:30 am »
Case:
I never decase as I need the appropriate airflow in the PC to keep things inside cool and free of dust.  Using a PC case inside a monitor makes sense as you can route all the cables in a clutter-less way, so you don't accidentally ding any wires going to the power or controller(s), or electrocute yourself. Besides arcade cabs use the bottom up airflow (passive) to cool components.  That digdug main board doesn't generate the same heat output as your P4, or ATX PSU.  The above comments shows how stupid we have become when dealing with modern PC equipment. I would take it all with a pinch of salt.  :blank:
« Reply #17 on: February 10, 2016, 10:57:59 am »
I've had my main MAME PC decased for 5 years now with no issue.
jbl77
« Reply #18 on: February 10, 2016, 11:12:23 am »
Case:
I get what you are saying, but I would disagree.
The reason for a case is just that:  A case.  A means to hold things....in a closed in constricted environment.  Because those things (and cables) are jammed in there, air flow is naturally going to be restricted.  With that consideration, they are designed with the concept of negative pressure in mind, hence the reason for the need to keep a cased computer closed.  And with all those things in there...what happens to the dust that DOES get in your computer? I bet it clings and clumps.
Also remember, thermal tests for CPUs are done on an open air chassis (aka test bench chassis).
In an area as large as a the inside of a cabinet with the proper ventilation, it will be completely fine; you just gotta remove the heat.  That said, I would say to completely comes down to preference.
« Last Edit: February 10, 2016, 11:14:54 am by jbl77 »
vwalbridge
« Reply #19 on: February 10, 2016, 11:37:41 am »
There are de-cased computers everywhere...you just don't notice them.
ATMs, kiosks, information booths, etc.
Unless it's an Intel NUC, de-case the computer and use PCB feet to mount the motherboard. Easier than trying to mount an entire computer case inside you cab.
jbl77
« Reply #20 on: February 10, 2016, 11:40:08 am »
...because they are cased....in a non-traditional case....like a cab :)
