Author Topic: MAME Cabinet - How many buttons do I need?  (Read 7101 times)
WillyByte
  • Last login:August 21, 2022, 05:40:30 pm
  • These words should be replaced with better ones.
« on: December 05, 2015, 11:14:17 pm »
I'm building a cabinet limited to games that benefit from a 4-way Joystick.  Most of the games I anticipate installing are listed on the page attached to the link below.
http://armchairarcade.com/neo/node/486
Not including admin, coin, or player buttons is there a simple way to find out how many buttons I'm going to need?  Are there ways to sort game lists by number of buttons required?
« Last Edit: December 06, 2015, 09:37:28 am by WillyByte »
Ian
  • Last login:September 26, 2021, 01:50:35 am
Re: MAME Cabinet - How many buttons do I need?
« Reply #1 on: December 05, 2015, 11:23:14 pm »
From what I can tell, it looks like only 2 buttons. You may want to go 3 just in case.
WillyByte
« Reply #2 on: December 06, 2015, 09:39:39 am »
Thank you Ian.  I'm going to make it 3.
haynor666
  • Last login:October 27, 2025, 04:00:20 pm
  • retro maniac
« Reply #3 on: December 06, 2015, 02:08:14 pm »
Iron Horse uses 3 buttons and that's a max but Telephone Mahjong uses also mahjong panel.
mgb
  • North East, US
« Reply #4 on: December 06, 2015, 05:24:28 pm »
3 will definitely cut it for you but I think you'll find two covers pretty much any classic 4-way game.
paigeoliver
  • Awesome face!
« Reply #5 on: December 06, 2015, 08:14:52 pm »
Iron Horse is an 8-way game that mame mistakenly lists as 4-way.
The real answer to that question is 2 buttons, unless you want Mouse Trap, in which case you need 4 buttons.
  • Online Online
  • Last login:Today at 12:25:03 pm
« Reply #6 on: December 07, 2015, 08:12:50 am »
Iron Horse looks like it allows you to use the whip on a down-right diagonal, but that's just the sprite animation for the down direction.
Gun only shoots in 4 directions.
Movement is only in 4 directions.
Based on first-level gameplay, this doesn't appear to be an 8-way game.
Am I missing something here?   :dunno
P.S. Updated this FAQ entry.
kooky
  • Last login:June 22, 2025, 01:21:45 pm
  • My Motto is "More Good Times"
« Reply #7 on: December 07, 2015, 12:37:52 pm »
Punch Out / Super Punch-Out has three buttons - those games are awesome and both on your list.
haynor666
  • retro maniac
« Reply #8 on: December 07, 2015, 01:05:58 pm »
Iron Horse is 4-way. Just try enter any diagonal and see what happens ;) This game uses 3 buttons - shoot (whip, gun, fist), bomb and kneel.
  • Online Online
« Reply #9 on: December 07, 2015, 01:29:06 pm »
Good call, Kooky -- added both games to the FAQ.   :cheers:
Minor correction, Super Punch-Out!! needs a 4th button for duck. (Verified in MAME)
Quote from: history.dat
Control : 4-way joystick (pull up on the joystick to duck)
Buttons : 3
=> [1] LEFT BLOW, [2] RIGHT BLOW, [3] KNOCKOUT BLOW
  • Online Online
« Reply #10 on: December 07, 2015, 02:12:09 pm »
Took a closer look at the list linked in OP and noticed that Karate Champ is on it. (two 4-way joysticks per player)
I'd take the list as a good starting point, but check the entries since the guy who compiled it posted this reply:
Quote from: Bill Loguidice
Quote from: ibdone
Hi Bill, thanks for this list. I'm wondering if I'll need (two) 4-way sticks for any of these? For instance, if PacMan was simultaneous two-player. Thanks much...
No, they're all pretty much one player alternating, so only one joystick is needed.
Interesting side note: The source Bill credits for the list is this BYOAC thread from 12 1/2 years ago.
Paigeoliver started that thread -- his 83rd post here -- 10,052 posts ago.     :o    ;D
paigeoliver
  • Awesome face!
« Reply #11 on: December 07, 2015, 02:53:31 pm »
I was mistaken, Iron Horse is indeed 4-way.
keilmillerjr
  • Web Developer.
« Reply #12 on: December 09, 2015, 07:56:09 am »
You don't need admin buttons.
  • Last login:October 28, 2025, 11:06:27 am
« Reply #13 on: December 09, 2015, 11:53:18 am »
I have 3 on my 4-way CP, just in case.  I'm using a xx-in-1 and in the service menu it needs 3 buttons to navigate around.  So I'd go with 3 to be safe.
D
WillyByte
« Reply #14 on: December 15, 2015, 10:39:05 am »
Just found out (or reminded after 30 years of not having played) that Defender requires 5 buttons.   It's not a 4-way joystick game as I specified in my original question and I am thrilled with the 3 button CP I built.  Still, I'm adding this comment in case it's helpful to anyone who may see this down the road and is at a similar stage of planning/building.
Defender
Joystick: 2-way (up, down)
Buttons: 5 [Fire-Thrust-Reverse-Hyperspace-Smart Bomb]
Thenasty
  • Last login:Today at 11:37:04 am
« Reply #15 on: December 15, 2015, 01:24:51 pm »
unless you run the HACK for Defender and it brings you down to 3 buttons (Fire, SmartBomb, Hyperspace)
The hack if I remember correctly you use the LEFT/RIGHT on the Joystick to REVERSE/Thrust.
Free VGA Breakout Cable
