Author Topic: Ultimarc iPAC Led Connection Wiring - connector/molex?  (Read 2452 times)
MamedInCanada
  • Last login:February 02, 2016, 06:23:09 am
  • Still Learning...
« on: December 21, 2014, 06:31:14 am »
What is the connector / molex called that attaches to the header? Anyone have a picture?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Ultimarc iPAC Led Connection Wiring - connector/molex?
« Reply #1 on: December 21, 2014, 02:35:22 pm »
We sell pre-wired LEDs and also pre-crimped wires and connector housings for these.
But they are standard 0.1 inch pitch housings which are widely available.
These for example:  http://www.digikey.com/product-detail/en/65039-033LF/609-2339-ND/1002654
MamedInCanada
  • Still Learning...
« Reply #2 on: December 24, 2014, 01:17:16 pm »
Thank-you Andy
     Will this connection work in the below picture? I was able to find a 2 pin connector over? Red over the +5v and black over the ground on the header.
Thanks again
dkersten
« Reply #3 on: December 28, 2014, 12:39:04 pm »
also sometimes called "DuPont connectors" or 2.54mm connectors, if you are trying to search for them on the internet.  And many of the connectors used inside computers are the same size (ie power led and switch, reset switch, usb headers, audio headers, etc)
MamedInCanada
  • Still Learning...
« Reply #4 on: January 01, 2015, 12:30:27 am »
Thanks dkersten...found some on eBay
