Author Topic: Using a foot pedal for a button?  (Read 3937 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« on: September 17, 2014, 07:36:47 pm »
I want to use a foot pedal and put a switch in it to use it as a button.  Has anyone done this before? Have any pics?
I want to install a TT2 spinner and use the foot pedal to fire :)
Xiaou2
  • Last login:Yesterday at 08:37:37 am
  • NOM NOM NOM
Re: Using a foot pedal for a button?
« Reply #1 on: September 17, 2014, 11:13:45 pm »
Its not hard to hack, make, or obtain a digital pedal solution...
 However,  the real question is.. what are you using it for?
 Any game that requires decent fire rates... will be a big problem for most people. Even drummers need to sit down, use dual pedals, and those pedals are leverage-sprung (Not typical arcade pedals. More akin to a trebuchet -vs- a single axis catapult).
 One idea I had was to use a center axis pedal, with 2 leaf switches, 1 on each end.  That could be use for aiming in the up/down sections of Discs of Tron.  The original spinner is a bit difficult to spin+change vertically. ..at the same time,  so this solution could actually improve the control.
 For non analog racing games, a digital pedal will work fine.  May work ok enough for some analog games too.
 On mame, an analog pedal can be used as a digital button as well.  May not work like that on all games and emulators however.
 You can also fashion a dual mode pedal... where its geared analog, with a leafswitch, or similar,  for digital as well.
  • Last login:Today at 10:27:16 pm
« Reply #2 on: September 18, 2014, 02:08:09 am »
The 2-switch rocker pedal here can be connected using a stereo audio jack  (or similar) to wire the pedal switches in parallel with two buttons.   ;D
Works great for the high/low function in Discs of Tron.
Agreed.  Will not work well for Galaga.   :lol
Foot pedal and rapid fire are mutually exclusive unless you use some sort of auto-fire solution.
« Last Edit: September 18, 2014, 02:20:53 am by PL1 »
    • GroovyGameGear.com
« Reply #3 on: September 18, 2014, 12:37:40 pm »
These are a very nice foot switch, and cheap too.  I use them on some of my machinery.
It wouldn't take much to remove the cords and rewire for gaming use.
Thenasty
  • Last login:Today at 04:30:09 pm
« Reply #4 on: September 18, 2014, 12:46:59 pm »
Tried playing TRON with a foot button  :banghead:
Free VGA Breakout Cable
  • Last login:Today at 08:33:44 pm
« Reply #5 on: September 18, 2014, 12:53:20 pm »
 :laugh2:
SavannahLion
« Reply #6 on: September 18, 2014, 01:11:01 pm »
Oh wow, that's exactly what I needed. The Big Box Store looked at me like I was smoking crack when I asked for one.
There's a HF near the mall, I'll be able to ditch the kids and spouse for ten minutes to pick one up.
equlizer
« Reply #7 on: September 18, 2014, 07:48:50 pm »
It would be for games like DOT and forgotten worlds.  I would have that button set to rapid fire most likely.  My bartop is sitting on a computer desk right now and where the computer would sit i would drill a hole and put a button in there then use my foot to tap it or hold it down to fire. :dunno
« Reply #8 on: September 18, 2014, 08:00:15 pm »
MAME TIME is using a foot pedal for his Geometry Wars cabinet:
http://forum.arcadecontrols.com/index.php/topic,131784.0.html
Looks pretty awesome, and a viable button for the one-off needs (like the Bomb in GeoWars).  I don't know about using it as a continuously used button, like for main firing.
Xiaou2
  • NOM NOM NOM
« Reply #9 on: September 18, 2014, 08:48:44 pm »
 Not Tron.  Discs of Tron... and only for the up and down aiming.
 As for using it as a rapidfire... such as with DOT,  its not a good idea.  Dot requires more precisely timed shots to trick sark, in any but the first few easy levels.  If you shoot all your discs at once,  he will easily evade them all,  and you will be defensless for too long a time.
 There are some games that use autofire, but I believe they are limited in number.
 As for momentary pedals... note that they may work fine for your tools... but may not work so well on your favorite games.  There may be too much or too little travel, spring force, etc.
DaveMMR
« Reply #10 on: September 18, 2014, 09:04:39 pm »
What if you had two foot buttons wired to the same input and you alternated your feet for faster firing maybe?  No?
Definitely be good exercise while playing.
« Reply #11 on: September 19, 2014, 06:11:13 am »
I'd like to see someone doing this with their toes.   :laugh2:
HanoiBoi
  • Last login:April 13, 2016, 09:52:03 pm
« Reply #12 on: September 19, 2014, 06:47:36 am »
Like Xiaou2 said, you cannot successfully play DOT with rapid fire.  Go try it now and you'll understand.
I think many of us believe that maybe the foot pedal could be helpful for up/down aiming in DOT.
Another thought for up/down, depending on your control panel setup (and I have not tried this) would be to try mapping buttons that are within reach of your thumb(s).  If you can reach them, a la Defender, they could possibly be used for up/down.
If you simply want a foot pedal fire button for various other games, then by all means continue on.  That could be fun to play.
« Last Edit: September 19, 2014, 06:49:22 am by HanoiBoi »
DaveMMR
« Reply #13 on: September 19, 2014, 10:34:52 am »
Well I suppose for that game you could incorporate the buttons into some sort of layout housed in a cushioned pad so you could run frantically on it. Or, inevitably, slap it with your hands.   ;D
« Last Edit: September 19, 2014, 10:43:58 am by DaveMMR »
shponglefan
« Reply #14 on: September 19, 2014, 11:27:26 am »
Yes, I actually wired up a pedal designed as a Yamaha keyboard sustain pedal (for music) to use with MAME as a foot switch.  I used it for racing games in conjunction with a TT spinner.
TopJimmyCooks
« Reply #15 on: September 19, 2014, 12:55:45 pm »
Time Crisis, obviously.
Generic Eric
« Reply #16 on: September 19, 2014, 01:00:17 pm »
A foot pedal could be cool as a pause button.
HanoiBoi
« Reply #17 on: September 19, 2014, 01:08:00 pm »
A foot pedal would be cool as a 'jump' button, wired instead to NC (or NO?).
You could actually jump to jump.
