Author Topic: Ultrastik 360 replacement ball top question  (Read 2248 times)
cryoguns
  • Last login:September 26, 2014, 09:24:59 pm
« on: June 29, 2014, 06:50:02 pm »
Hello!
I'm still fairly new to the arcade scene so please forgive what may be a stupid question.
I own a pair of Ultrastik 360 ball top joysticks that I will be putting in my arcade project.  Ultimarc does offer different color replacement balls, but not white specifically.
Can anyone tell me if a standard Sanwa 35mm ball will fit, or if the threads are different?  Are there any other sources for a white ball top if so?
dkersten
Re: Ultrastik 360 replacement ball top question
« Reply #1 on: June 29, 2014, 07:16:42 pm »
Yes, the standard ball tops fit, I got mine from groovygamegear.  The problem is, the stock tops are not 35mm, they are like 32 or something, so if you replace one with a 35mm with the intent of keeping the second with the stock color, it will not match well..
ChanceKJ
« Reply #2 on: June 30, 2014, 03:19:09 am »
I picked up the smoke tops for my 360's from Paradise Arcade. They fit perfectly.
cryoguns
« Reply #3 on: June 30, 2014, 09:22:54 pm »
Thank you for the suggestions!  I will check these two out.
