Author Topic: USB Ports  (Read 4448 times)
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
USB Ports
« on: January 15, 2014, 06:52:24 am »
so I want to install 2 USB ports in my cab but dont know what to use for ports. I wanted to use a USB extension cable with the PCI card metal thing, not the card one but the cables that end up at the metal you get to place in the space a card would be. but i dont know what the name is so I can find it.
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
xandnic
  • Last login:April 09, 2024, 03:40:59 am
Re: USB Ports
« Reply #1 on: January 15, 2014, 07:50:59 am »
I'm using these Neutrik USB ports in my build:
Drnick
  • Plodding Through Life
Re: USB Ports
« Reply #2 on: January 15, 2014, 08:04:19 am »
Search for USB Header Plate. or USB Back plate.   Bear in mind you must have the connections on your motherboard for it to plug into.  I personally used the Neutrik ports as shown above.
  • Last login:Today at 06:16:59 pm
Re: USB Ports
« Reply #3 on: January 15, 2014, 08:25:03 am »
Check here for USB rear panel brackets.
+1 on using the Neutrik feedthrus -- very easy to install.
Ortizimo
Re: USB Ports
« Reply #4 on: January 16, 2014, 06:52:36 am »
thank you all for your all your help!  :applaud:
nipsmg
  • Last login:February 15, 2026, 06:33:19 pm
  • ROONEY!! ERRGH!!
    • Arcadia
Re: USB Ports
« Reply #5 on: January 16, 2014, 08:33:31 am »
+1 more for Neutrik feed-throughs.  I love these things.
eds1275
  • Rock and Roll!
Re: USB Ports
« Reply #6 on: February 02, 2014, 01:16:47 pm »
Except the price.
Drnick
Re: USB Ports
« Reply #7 on: February 04, 2014, 02:48:13 pm »
In this hobby they are one of the cheaper items to purchase  >:D
bleargh
  • Last login:Today at 12:32:12 pm
  • ribbit...
Re: USB Ports
« Reply #8 on: February 04, 2014, 04:28:30 pm »
I just picked up a pair of these:
http://www.ebay.ca/itm/3-28ft-USB2-0-A-Female-To-A-Male-M-F-Adapter-Panel-Mount-Extend-Cable-Screw-Lock-/170851299991
and front-mounted them on my cabinet.
Pair of them cost me a whopping $6, including shipping.  Couldn't go wrong at that price...
JDFan
Re: USB Ports
« Reply #9 on: February 05, 2014, 10:02:06 am »
Tiger Direct has a nice little 4 port setup for $2.99 right now that would work just remove the mounting plate and use the 3 screws to mount -- ( http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3949897&CatId=511 )
Mr_Numbers
  • Last login:December 01, 2017, 10:49:05 am
  • Long time lurker, first time builder
Re: USB Ports
« Reply #10 on: February 06, 2014, 01:22:52 am »
Thanks for the share and good deal.  :)
JDFan
Re: USB Ports
« Reply #11 on: February 07, 2014, 10:51:50 am »
It is a very good deal if you have a retail location near you (like we do here in El Paso,  TX.) - Not so good if you have to pay the shipping (+\- $4) which is more than the sale price unless you are ordering other items as well !
« Last Edit: February 07, 2014, 10:53:25 am by JDFan »
