Author Topic: PC won't boot with Ipac2 connected  (Read 1314 times)
miva
  • Last login:January 07, 2014, 11:51:54 am
« on: January 05, 2014, 06:45:21 pm »
My PC will not boot unless I unplug the IPac 2.  It works fine with just my Logitech G15 attached so I don't believe it's a USB issue.
It seems to me like the ipac might be pressing some buttons on boot even tho none of my buttons or joysticks are being touched during boot because it usually ends up on the boot Windows normally, safe mode, etc. screen
When I make it into Windows it works perfectly fine.  Has anyone else had this issue and found a solution?  Or am I destined to always be connecting and disconnecting the ipac for each boot?
Fursphere
  • Last login:January 31, 2026, 08:42:02 pm
Re: PC won't boot with Ipac2 connected
« Reply #1 on: January 05, 2014, 08:26:28 pm »
Have you contacted Andy @ Ultimarc?
Thenasty
  • Last login:January 29, 2026, 11:38:03 am
« Reply #2 on: January 05, 2014, 10:02:41 pm »
check the cable you're using if any pins are bent (both ends).
Free VGA Breakout Cable
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
« Reply #3 on: January 06, 2014, 02:50:06 am »
Also check that your buttons and joystick connections aren't shorting somewhere!
miva
« Reply #4 on: January 06, 2014, 09:33:37 am »
I ended up seeing some advice on Reddit about changing USB hubs, I didn't have mine plugged into a hub but I did change which USB port it was plugged into, and for some reason that solved the issue!
