Author Topic: LED BUTTONS  (Read 15342 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
LED BUTTONS
« on: August 12, 2013, 02:11:07 am »
Is there a way to set LED  buttons to turn on depending on game.  example player 1 has 6 buttons if im gonna play mario bros only 2 buttons shld b on or all six for Street fighter? :dunno and also how to get power to led buttons Thanks.
dunno if this arcade amp has diferent voltage on all outputs can some one point me if i can use any ports to connect second fan (12v) or led arcade buttons?
  • Last login:Today at 03:03:03 pm
Re: LED BUTTONS
« Reply #1 on: August 12, 2013, 03:37:32 am »
GGG has the LED-Wiz.
Ultimarc has the PacLED64.
There are many threads like Nephasth's Two-Headed Beast build that can provide more info on these products and using them with many front ends and/or the LEDBlinky program.
The controllers will probably need an external power source since the current limit via USB is 500 mA (100 mA if connected to an unpowered hub) -- 12 RGB buttons @60 mA per button would draw 720 mA.
***Example only, check the specs on the buttons you choose and leave yourself some wiggle room on the current rating of the power supply.***
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #2 on: August 13, 2013, 01:15:47 am »
LEDwiz or PacLED64 ? :dunno im using maximus arcade...??? ???
shponglefan
Re: LED BUTTONS
« Reply #3 on: August 13, 2013, 01:40:38 am »
How many channels do you need?  Ledwiz supports 32, Pacled supports 64.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #4 on: August 13, 2013, 01:43:28 am »
idk what ya mean whit channles  (noob) im planing to have  20 buttons. and if you know the best brand of led buttons that will b kool :afro: im ready to order
Re: LED BUTTONS
« Reply #5 on: August 13, 2013, 02:28:04 am »
Each channel can be controlled independently to set the brightness like a light dimmer switch.
If you are using single color LED buttons, 20 buttons = 20 channels.
If you are using RGB (Red/Green/Blue) buttons, 20 buttons = 60 channels. (20 Red / 20 Green / 20 Blue)
An RGB button allows you to set a variety of colors by controlling the levels on the red, green, and blue channel you associate with that button -- picture the red, green, and blue pixels on a monitor combining to make different colors.
You can mix and match RGB and single color buttons on one controller IIRC.
« Last Edit: August 13, 2013, 02:31:54 am by PL1 »
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #6 on: August 13, 2013, 10:14:10 pm »
thanks Scott  :cheers:   Any or the best brand available by ne chance I want the bottons to bright even when the light is on..(room)
shponglefan
Re: LED BUTTONS
« Reply #7 on: August 13, 2013, 10:18:25 pm »
You might want to check out this thread: RGB pushbutton showdown.  It has a nice comparison of the various brands of LEDs/buttons.
FWIW, I don't think there's really a "best" brand.  It largely comes down to individual characteristics of the LEDs.  Some are made to fit specific buttons, some are made to retrofit various buttons, and so on...
« Last Edit: August 13, 2013, 10:21:36 pm by shponglefan »
Brian74
  • Yep... I built that!!
Re: Re: LED BUTTONS
« Reply #8 on: August 13, 2013, 10:22:39 pm »
Here are some buttons that are/can be used with rgb leds
http://www.ultimarc.com/ClassicRGB.html
http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=238
http://www.paradisearcadeshop.com/product.php?id_product=275
Sent from my SGH-T989 using Tapatalk 2
Brian74
Re: LED BUTTONS
« Reply #9 on: August 13, 2013, 10:24:00 pm »
I have the clear buttons. But I swapped out the centers with black ones
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #10 on: August 13, 2013, 10:25:10 pm »
thats what i wat to do  ;D
« Last Edit: August 13, 2013, 10:26:53 pm by Caparo8bit »
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #11 on: August 13, 2013, 10:27:54 pm »
sweet tysm
Brian74
Re: LED BUTTONS
« Reply #12 on: August 13, 2013, 10:38:12 pm »
Here are my buttons
Dcpmark
  • Last login:December 30, 2023, 11:28:10 pm
Re: LED BUTTONS
« Reply #13 on: August 13, 2013, 11:17:45 pm »
I'm fairly certain MA has built-in LEDWiz/LED Blinky support. But I don't know that PacLED64 won't work with MA.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #14 on: August 13, 2013, 11:21:32 pm »
how but this one for power (planing to use smart power strip) and set this button  to turn on all the system......... :timebomb:
BobA
  • What Me Worry?
Re: LED BUTTONS
« Reply #15 on: August 13, 2013, 11:42:55 pm »
Enough info provided for LED power so I will not add.  The picture however shows that these 2 terminals burnt up a 12 V fan.  This is due to the 2 terminals being the 120V going to the cab. The other fan in the pic is a 115/120V ac fan.
« Last Edit: August 13, 2013, 11:45:50 pm by BobA »
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #16 on: August 13, 2013, 11:46:11 pm »
Enough info provided for LED power so I will not add.  The picture however shows that these 2 terminals burnt up a 12 V fan.  This is due to the 2 terminals being the 120V going to the cab. The other fan in the pic is a 115/120V ac fan/
how bout the other ports???????
BobA
  • What Me Worry?
Re: LED BUTTONS
« Reply #17 on: August 14, 2013, 12:09:28 am »
Don't know what you refer to as ports.   The arcade PS is a source of 5V and 12V as marked on the terminal strip.  There is usually an AC Line Neutral and Ground that are inputs to the power supply.  The Ground is for the AC ground and is not related to the ground for the 5V and 12V.
So use 12V or 5V depending on what your LEDs require.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #18 on: August 14, 2013, 12:43:14 am »
great tysm so now i have to spend $25\30 to get another fan. hope i use the right terminals from the arcade amp this time and dont burn my 25 led buttons :notworthy:
edekoning
Re: LED BUTTONS
« Reply #19 on: August 14, 2013, 06:36:58 am »
Yeah I really love those buttons now. I also think that spray painting the inner plunger made them look better when the leds are off. I also have no lightbleeding :)
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
Re: LED BUTTONS
« Reply #20 on: August 15, 2013, 01:20:40 pm »
I want one of those, badly.  I had the hardest time finding them with the power image on them, I was only able to find them with the ring and a solid metal button.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #21 on: August 15, 2013, 01:58:37 pm »
   http://www.ebay.com/itm/16mm-12V-BLUE-Led-Lighted-Push-Button-Metal-Momentary-Switch-for-Car-Boats-DIY-/271107000518?pt=LH_DefaultDomain_0&hash=item3f1f3c88c6
Re: LED BUTTONS
« Reply #22 on: August 15, 2013, 02:09:18 pm »
I TOLD YOU NOT TO HOOK A FAN UP TO THOSE IN YOUR OTHER THREAD
I also told you to hook it into the 12v on the power supply.
http://forum.arcadecontrols.com/index.php/topic,133864.msg1379215.html#msg1379215
That being said, why are you spending 25-30 on a $5 PC fan? I'm hoping the big letters will help you to actually read this time.
« Last Edit: August 15, 2013, 02:12:08 pm by Malenko »
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #23 on: August 15, 2013, 02:18:44 pm »
ccrab thanks well im getting another fan same as the one im using right now so now i can use those terminals the other fan is already in the trash
« Last Edit: August 15, 2013, 02:21:07 pm by Caparo8bit »
  • Last login:Yesterday at 11:23:23 pm
Re: LED BUTTONS
« Reply #24 on: August 15, 2013, 02:22:42 pm »
You know, the normal font size and color works pretty nicely, too.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #25 on: August 15, 2013, 02:29:47 pm »
ok
    • GroovyGameGear.com
Re: LED BUTTONS
« Reply #26 on: August 15, 2013, 03:08:38 pm »
ok
CoryBee
  • Bopity Boopy
Re: LED BUTTONS
« Reply #27 on: August 15, 2013, 03:19:09 pm »
I want to play too
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #28 on: August 15, 2013, 03:39:51 pm »
how many buttons can j-pac control ( right now im using 10 (not using xtra ports in j-pac jet)???
Re: LED BUTTONS
« Reply #29 on: August 15, 2013, 03:46:59 pm »
4 per player, plus coin and start, right?
Re: LED BUTTONS
« Reply #30 on: August 15, 2013, 03:54:30 pm »
nuuuuu it does the standard jamma and has 3 or 4 extra per player on the top. so at least 6 or 7 per
Re: LED BUTTONS
« Reply #31 on: August 15, 2013, 06:45:29 pm »
You're right, it had the extra terminals. I was just thinking JAMMA
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #32 on: August 15, 2013, 07:28:23 pm »
ok so im planning to install  19 led buttons ( 2 players)   (12)6 for each player  2 for coins 2 for start  and three for Maximus Arcade (1)esc.(1)home.(1)enter my show case 33" is for 4 players but i only see player 3 and 4 harness hanging ( not connected to jamma h.) how do i connect this so i can use more buttons??  :dunno  oooh also what type of quick disconnect harnes r good for speakers and power my arcade comes in two pieces so when i moved will b nice to just disconnect and connect ( not cuting cable everytime)
« Last Edit: August 15, 2013, 07:41:12 pm by Caparo8bit »
BobA
  • What Me Worry?
Re: LED BUTTONS
« Reply #33 on: August 16, 2013, 12:33:26 am »
Since you only have a 2 player control panel you would need to build a 4 player control panel to connect the hanging wires for player 3 and 4.
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #34 on: August 16, 2013, 12:46:13 am »
what im trying to do is connect player 3 or 4 to jamma harness and use those buttons for   maximus arcade options like esc. home. enter ....
BobA
  • What Me Worry?
Re: LED BUTTONS
« Reply #35 on: August 16, 2013, 01:25:38 am »
What encoder/interface are you using?
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #36 on: August 16, 2013, 01:27:31 am »
mmmmm encoder.... i gues is winpac  thats encoder?
BobA
  • What Me Worry?
Re: LED BUTTONS
« Reply #37 on: August 16, 2013, 01:37:40 am »
What model Ipac are you using?
Caparo8bit
  • Hyperspin/Maximus
Re: LED BUTTONS
« Reply #38 on: August 16, 2013, 01:38:32 am »
j-pac
BobA
  • What Me Worry?
Re: LED BUTTONS
« Reply #39 on: August 16, 2013, 01:46:43 am »
You need to add an ipac to your jpac to allow the inputs for players 3 and 4 along with adding all the buttons and joysticks to you panel.
