Author Topic: Petite LED Cocktail  (Read 31146 times)
CoryBee
  • Bopity Boopy
Petite LED Cocktail
« on: June 01, 2013, 08:38:38 pm »
Had an itch to make a mini cocktail after going over JKDubb's UCA Winning build and saw these. Made me a bit "gitty" inside and had to attempt a working mini cocktail.
I am going for a more traditional look for the cocktail, a bit like the full size cocktail build I just finished (but itsy bitsy).
Hardware
I wanted to keep the cost down so I ordered a used "Samsung SCH-R880" instead of what I have seen most minis made out of (Dingoo, GBA, etc). They may be easier to configure but I knew I could bend android to my will  >:D . I was originally going to hack a bluetooth keyboard up to whatever cell phone I purchased but then realized that I could get a cell phone with a slide out keyboard and hack that.
Joysticks will be these (haven't came in yet). Part number GH7455-ND on digi-key.
For the buttons I went with these. They are the perfect size and there is a similar model that is lit up with LEDs that I could not find. I am going to open them and hack in an SMD LED. There is space just for them in it (perfect!).
Pac-Man (With cocktail flipping!)
Software\Apps
Firstly I rooted the device, this is useful for a ton of reasons regardless of using it for an arcade.
I was going to write a custom rom image for it (and still might) but wanted to see if I can do it with just rooting it and messing with apps as the first would be phone specific.
Here is a list of apps needed to basically shell the front end
  • No Lock - This eliminates a lock screen from start up. So no need to touch screen
  • Auto Start - This will start any app you wish on startup, will use this to start MAME4Droid
  • Holo Launcher - Use this to disable the pull down bar at the top of the phone and other settings like auto-rotate
  • Root Browser - This is needed to browse through the phones system folders and make changes that are not accessible through normal file browsers
  • MAME4Droid - The MAME+Frontend I will be using
  • Root APP Delete - Use this to uninstall applications that came with your phone that wont be needed; like navigation, camera, maps, etc. This will speed up the system.
Will post another update\more information soon after I finish some regular work.
Yvan256
    • Yvan256
Re: Petite LED Cocktail
« Reply #1 on: June 02, 2013, 12:04:44 pm »
Another micro build added to my watch list!
Somewhere at Digi-Key, somebody is asking "What's up with part number GH7455-ND? We sold more in the last few months than in the last decade!"
P.S.: for the buttons, had you seen these?
« Last Edit: June 02, 2013, 12:17:12 pm by Yvan256 »
sabreerbasAlpha
  • Remember those big 10ps?
« Reply #2 on: June 02, 2013, 01:32:12 pm »
OMG CoryBee do you even sleep or do you just Knock out amazing Cabs all day and night. Another Sub..He we go again.  :notworthy: :notworthy:
CoryBee
  • Bopity Boopy
« Reply #3 on: June 06, 2013, 05:41:10 pm »
Been busy with the cabaret trifecta to post an update.
One of the main reasons I wanted to get root level access was so I can save the Mame4Droid files and the roms on the phones memory so I don't waste one of my SD Cards for such little space. There will be probably 10 - 20 games on it I think.
Build pictures
The top panel of the cabinet will be roughly 6 inches in length. And the base about 5 1\2 inches.
The top will also be two pieces of the thin MDF I got
Base cabinet pictures - the little pieces to the right are the supports
Assemble
Figuring out the dimensions for the top panel - It is a pain to do the math for such small measurements
Using the same technique I used on my full size cocktail build to cut the screen section out
The flush trim bit on the router is obviously too big for the job so I improvised and used my new dremel to follow the guides. Adjusted it so it sits just on the empty part of the bit.
Voilla!
Cleaned up the edges with the jigsaw's smallest blade and did some more measurements
Louis Tully
« Reply #4 on: June 06, 2013, 06:33:46 pm »
« Last Edit: February 12, 2015, 03:41:09 pm by Louis Tully »
« Reply #5 on: June 06, 2013, 06:55:14 pm »
Looking good! :cheers:
Jigenjuke
« Reply #6 on: June 06, 2013, 07:13:17 pm »
Now you're just showing off.  ;D
Awesome stuff man. I hope to make a micro cab one of these days. Keepin' my eye out for an Advance SP of craigslist.
What he said!  Good show Cory, will be watching.
Jigenjuke
CoryBee
  • Bopity Boopy
« Reply #7 on: June 06, 2013, 07:27:14 pm »
Thanks fellas, got a little bit further and will post some more pictures. Resizing it a bit as I think the base should be a little bit shorter.
Doing the little control panels will be a blast for sure!
Jigenjuke
« Reply #8 on: June 06, 2013, 09:32:14 pm »
Cory, looking forward to see how this turns out.  I will be making a mirco cocktail joust sometime in the near future.  Good luck.
Jigenjuke
CoryBee
  • Bopity Boopy
« Reply #9 on: June 07, 2013, 12:02:48 am »
Stripping the phone of its pretty shell
Screen and main=board separated (but not without issue......)
I wasn't careful enough while removing this metal shield (the main slider assembly) and tore part of the ribbon cable.... My heart dropped.  :banghead:
I powered the phone on hoping to see the screen and voilla! It turned on.....Unfortunately I lost all use of the touch screen and home buttons. But the screen still worked which is enough for me as I have the keyboard which is plenty to navigate the phone and finish shelling MAME.
Ripped cable
Tape to keep it from tearing any further
Anyways, back to the fun.
LCD screen removed (very carefully) from the touch digitizer glass
Thanks for looking!
« Last Edit: June 07, 2013, 01:40:47 am by CoryBee »
jdbailey1206
« Reply #10 on: June 07, 2013, 07:17:29 am »
Kudos to anyone who does a mini cab.  I get enough of a headache just dealing with a regular sized cab.
Yvan256
    • Yvan256
« Reply #11 on: June 07, 2013, 10:13:03 am »
I think one way of officially differentiating between a mini-cab and a micro-cab would be those GH7455-ND joysticks. If a cabinet uses them or something as small as those, it's a micro.  ;)
jdbailey1206
« Reply #12 on: June 07, 2013, 10:21:14 am »
sabreerbasAlpha
« Reply #13 on: June 07, 2013, 01:13:46 pm »
looking Good Cory looking good my friend. I like the work with dremel my friend. Cant wait to see this finished it looks super cool.
mcseforsale
  • Creepy Mario Dude
« Reply #14 on: June 07, 2013, 01:48:10 pm »
subscribed...
AJ
« Reply #15 on: June 07, 2013, 01:56:58 pm »
subscribed...
AJ
I'd love to see your subscription list one day...  >:D
mcseforsale
  • Creepy Mario Dude
« Reply #16 on: June 07, 2013, 02:00:02 pm »
Just further proof that AJ is always watching.
Once the basement is in a better state, I'll be starting a lot of new projects.
AJ
subscribed...
AJ
  • Last login:Today at 01:40:55 pm
« Reply #17 on: June 07, 2013, 02:42:10 pm »
subscribed...
AJ
Why wait -- you get 32 hits searching for "subscribed" by author "mcseforsale".   ;D
mcseforsale
  • Creepy Mario Dude
« Reply #18 on: June 07, 2013, 02:43:54 pm »
Wow.  that's less than I thought.  I try to subscribe early and often.
AJ
subscribed...
AJ
« Reply #19 on: June 07, 2013, 02:54:53 pm »
Those are the ones where you posted the word "subscribed" in the thread.
Not sure how else to determine what threads someone has subscribed.  :dunno
« Reply #20 on: June 07, 2013, 03:34:53 pm »
If you don't want to be instantly notified by email of new posts, click Add Bookmark at the top of the thread (Notify if you want email alerts). Then at the top of the forum there is a My Bookmarks button, click that and it will show which threads you have bookmarked.
CoryBee
  • Bopity Boopy
« Reply #21 on: June 07, 2013, 05:25:29 pm »
This thing is definitely a headache but every time I finish a part so tiny it makes it all worth it.
Me too good sir, me too.
« Reply #22 on: June 07, 2013, 05:37:16 pm »
Get her back on course! Post more :pics
CoryBee
  • Bopity Boopy
« Reply #23 on: June 07, 2013, 05:41:33 pm »
I have more to post, the control panel for player one is complete. But lady friend is hungry so we are off to Pancake Palace.
Her just now, "are you on your arcades again...."
« Reply #24 on: June 07, 2013, 06:06:03 pm »
Micro the shizzle outta that build patron!
CoryBee
  • Bopity Boopy
« Reply #25 on: June 08, 2013, 12:22:11 am »
Itsy bitsy teeny weenie control panel thingy
Everything will get a good sanding with a high grit before paint is applied
Holes drilled
Fits snuggly
Since I am under-mounting the joysticks I need to "route" out some space so it is more flush - This was accomplished with an exacto-knife
After tracing all CP parts for player two it is time for assembly
Voilla!
Here you an see where one of the buttons had been converted to LED via SMD parts (more on this, and pictures,  later)
« Reply #26 on: June 08, 2013, 11:35:24 am »
Not sure why you aligned the joystick with the top of the buttons instead of the bottom.   :dunno
Won't the vertical side block a 2-finger-grip on the stick?
« Reply #27 on: June 08, 2013, 11:37:47 am »
I'm betting it's going to be a thumb on top of the stick "grip".
« Reply #28 on: June 08, 2013, 12:28:29 pm »
I'm guessing that bottom alignment would put the body of the base of the stick pocking out a mm or more past the face of the CP and raising the buttons would not be a good solution either.  Increasing the size of the whole attachment would solve the problem but create others in terms of scale.
« Reply #29 on: June 08, 2013, 01:21:29 pm »
You nailed it -- checked one with the micrometer and it's closer to the front edge than I originally thought.
« Reply #30 on: June 08, 2013, 01:23:01 pm »
Micrometer? :dizzy: Or did you mean calipers?
« Reply #31 on: June 08, 2013, 01:57:32 pm »
6 of one, 1/2 dozen of the other.  Mine look like this.
Use whichever term you prefer.
When I read "calipers", I think of these.
They're good for some measurements, but not for .001" accuracy.
« Last Edit: June 08, 2013, 02:05:51 pm by PL1 »
« Reply #32 on: June 08, 2013, 02:05:35 pm »
It comes from my mechanic side. ;)
Petite LED Cocktail
« Reply #33 on: June 08, 2013, 04:02:05 pm »
Wait, so you held a ruler up to the screen? :lol
CoryBee
  • Bopity Boopy
« Reply #34 on: June 08, 2013, 04:20:27 pm »
---gosh-darn--- it guys?! Calipers!!!! Micromachines!!!!! GET IN LINE!!!!  :angry:
Perfect ^^
You will hold it with one hand on each side played by your thumbs mostly.
Just like my full size cocktail the controls are a bit inside the machine and tilted at an angle. This one will almost look exactly the same, just tiny.
« Reply #35 on: June 08, 2013, 06:36:44 pm »
Pretty much.  I used ratio comparison (handle diameter:shaft to edge distance) and also a foreground-miniature technique (photo on screen, hold the joystick up so it appears to be the same size/orientation) -- the usual photo-interpreter-type tricks to double-check.
Both methods work great on a 46" TV.
[/derail]
Sir, yes Sir.  Falling in, Sir.
CoryBee
  • Bopity Boopy
« Reply #36 on: June 08, 2013, 11:05:58 pm »
Player two's CP assembled
Top piece cut in a similar fashion as the full size
Routed out space for the screen to sit flush (used the full sized router for this, very....very carefully)
Mungo9000
  • Last login:August 25, 2016, 09:18:21 am
« Reply #37 on: June 09, 2013, 05:24:15 am »
 :cheers: I'm loving this build!
Sjaak
« Reply #38 on: June 09, 2013, 05:40:51 am »
Great work  :applaud:
CoryBee
  • Bopity Boopy
« Reply #39 on: June 10, 2013, 05:27:21 pm »
Thanks for stopping by Sjaak, hope all is going well on the Felix front.
Quick picture of things put together, paint is drying now. Soon will mount the screen and electronics will be soldered up.
Anyone got any good ideas on how I should secure the acrylic to the top??
