Author Topic: "A Barrel of Kong" - A Bar Height themed Cocktail Cab [FINISHED]  (Read 315870 times)
Drnick
  • Plodding Through Life
Re: "A Barrel of Kong" - A Bar Height themed Cocktail Cab
« Reply #120 on: May 20, 2013, 01:32:14 pm »
Are you going to be making a pair of stools to go with it?  I ask as I was in Spain last week and they had turned a bunch of barrels into tables and had matching stools.  Looked Swoosh  :applaud:
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
« Reply #121 on: May 20, 2013, 02:23:59 pm »
That's some nice looking gear, way outside of my skill set though, at least for now, cutting that dang barrel was a challenge in itself.
Typefighter01
  • Last login:February 27, 2026, 07:24:12 pm
  • Back I guess...
« Reply #122 on: May 20, 2013, 05:16:18 pm »
Griffindodd,
Is there someting you cant do?  :cheers:
Make stools outa wine barrels :dunno
Maximus
    • Arcade Icons
« Reply #123 on: May 20, 2013, 05:24:27 pm »
DOH!!!
Maximus
    • Arcade Icons
« Reply #124 on: May 22, 2013, 09:49:10 am »
Shaping up the CP edges
jmike
« Reply #125 on: May 22, 2013, 10:13:11 am »
Looking good Griff. I hadn't noticed the speaker holes on the CP.
Might have to steal that idea for my cocktail project.
btw Maximus is one of my twins boys name.
Maximus
    • Arcade Icons
« Reply #126 on: May 22, 2013, 10:17:40 am »
Twins eh, I like your efficiency :)
First coat of satin black
nickels
  • Last login:September 24, 2024, 02:17:17 pm
  • Old nerd.
« Reply #127 on: May 22, 2013, 11:19:57 am »
What a fantastic concept!
Next step is to add a kegerator underneath the monitor with the tap coming out of the side. Beer and videogames.... mmmmmmmmmmm
D'oh!
Maximus
    • Arcade Icons
Re: Re: "A Barrel of Kong" - A Bar Height themed Cocktail Cab
« Reply #128 on: May 22, 2013, 11:23:24 am »
Yep I have considered this, the hard part is easy changing in and out of the mini kegs.  Believe me  putting a door in one of these barrels is not as easy as it looks.
« Reply #129 on: May 22, 2013, 11:37:10 am »
You just went from 'classy' to 'I pledge allegiance to the frat."
Maximus
    • Arcade Icons
« Reply #130 on: May 22, 2013, 11:38:32 am »
Good point, I will start work on the Martini-erator right away!
« Reply #131 on: May 22, 2013, 12:27:29 pm »
Duct tape a box of wine to the side. Trust me, it will reek of classy then.
Maximus
    • Arcade Icons
« Reply #132 on: May 22, 2013, 12:28:20 pm »
Classy is spelled F.R.A.N.Z.I.A.
mike boss
« Reply #133 on: May 22, 2013, 07:40:54 pm »
Fantastic project. Looking great.
I'm enjoying reading the progress.
Truly top shelf workmanship.
Maximus
    • Arcade Icons
« Reply #134 on: May 22, 2013, 10:38:05 pm »
Thanks Mike.
I had to find a footstool to get high enough to take this shot for Le Chuck and his contagious doohickey
« Last Edit: May 22, 2013, 10:40:56 pm by Maximus »
Maximus
    • Arcade Icons
« Reply #135 on: May 22, 2013, 11:22:22 pm »
Well dang that poly changed this from a used barrel to something you wouldn't mind sitting in your home bar
Maximus
    • Arcade Icons
« Reply #136 on: May 23, 2013, 12:13:05 am »
Decided to get some CP art together, I was going to leave them black, but it looks too basic and bare, so I'm going to repeat the color scheme and keep it loose and generic so I don't get caught up in button placement matching and all those headaches.
lcmgadgets
« Reply #137 on: May 23, 2013, 12:56:36 am »
I love this! :applaud:
Professor Hayashida
« Reply #138 on: May 23, 2013, 01:13:04 am »
I like the black. It's very subtle.
  • Last login:Today at 01:19:27 am
« Reply #139 on: May 23, 2013, 02:42:24 am »
I assume the green, blue, and pink on the CPO align with the bezel.
How would the CPO look with a black (or dark woodgrain like your barrel?) background and subtle white outlines around the barrels and character instead of the green, blue, and pink?
Do you want DK on the bezel and both CPOs?
Consider keeping DK on the bezel, moving Mario/Jumpman to one CPO, and putting Pauline on the other.   :dunno
Maximus
    • Arcade Icons
« Reply #140 on: May 23, 2013, 09:33:30 am »
Thanks for all the ideas,  unfortunately the art is already off being printed.
A problem I had to overcome was reintroducing structural integrity to the barrel after removing the cutout areas.  Barrels rely on tension to keep them together so I reintroduced it in certain areas with plumbers strapping to get that nice solid tight feel.
« Reply #141 on: May 23, 2013, 10:46:59 am »
It seems you have an opportunity to put something fun in your bunghole. Got any plans for it?
Maximus
    • Arcade Icons
« Reply #142 on: May 23, 2013, 11:15:18 am »
Snort snort
« Reply #143 on: May 23, 2013, 02:57:53 pm »
Fantastic Idea!  Are you planning to paint the exposed metal flat black?
Maximus
    • Arcade Icons
« Reply #144 on: May 23, 2013, 03:03:03 pm »
If you mean the straps on the outside I'm going to do them hammered black.  Usually I hate that finish but in this case I think it would be a good choice for the look I want
mcseforsale
  • Creepy Mario Dude
« Reply #145 on: May 23, 2013, 03:06:09 pm »
Hey, watch it there fella.  Some of us LIVE for hammered black.  :soapbox:
 :P
AJ
Maximus
    • Arcade Icons
« Reply #146 on: May 23, 2013, 03:22:33 pm »
Right on man do your thang. I like fruity martinis and kitchy sci-fi audio books, so we all have our vices.
« Reply #147 on: May 23, 2013, 05:16:05 pm »
You already suggested a variation here -- looks like the right size for a Franzia spout.  Is it on the wrong side for that?  :duckhunt
« Last Edit: May 23, 2013, 05:20:33 pm by PL1 »
Maximus
    • Arcade Icons
« Reply #148 on: May 24, 2013, 12:59:14 am »
Franzia nuff said (bitches love Franzia)
Any hoooooooo
Half the strapping painted and fitted ready for cutting
Matching finish on the CP
Maximus
    • Arcade Icons
« Reply #149 on: May 24, 2013, 09:40:10 am »
Straps cut and CP in place for test fit. All these curves and angles are a huge pain in the butt to try and get working together
« Last Edit: May 24, 2013, 09:52:21 am by Maximus »
mcseforsale
  • Creepy Mario Dude
« Reply #150 on: May 24, 2013, 09:59:12 am »
Needs more hammered black.
Just sayin'.
AJ
sabreerbasAlpha
  • Remember those big 10ps?
« Reply #151 on: May 24, 2013, 10:03:59 am »
Looking pretty damn fine again Maximus, Love this build. I mean its in a barrel What's not to love/.. :applaud:
Maximus
    • Arcade Icons
« Reply #152 on: May 24, 2013, 11:46:44 am »
Barrels, hammered black, one giant cupholder, Franzia the only thing missing is
« Reply #153 on: May 24, 2013, 02:07:05 pm »
Badgers?... Badgers?... We don't NEED no stinking Badgers!
Or are you suggesting that Snaake needs to post in this thread?  :lol  (24 seconds)
Also, since you have changed your personal text to "The Sausage King of Chicago", are you adding "Abe Froman" to your list of aliases?
TheShaner
« Reply #154 on: May 24, 2013, 03:30:16 pm »
+1 on the cupholders.  All the hot chicks that will be playing your Bunghole full of Kong need a place to put their red solo serve cups full of Franzia.
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #155 on: May 24, 2013, 04:17:20 pm »
... Bunghole full of Kong...
Now my boss is asking why I'm laughing so hard.
Maximus
    • Arcade Icons
« Reply #156 on: May 25, 2013, 12:46:01 pm »
Should have called it that doh.
Usual suspects here for the internals.  My daughter 'relocated'  one of the 4 red buttons I had for this so that's a bit if an issue.
Maximus
    • Arcade Icons
« Reply #157 on: May 25, 2013, 01:24:31 pm »
Yep there it is
dfmaverick
« Reply #158 on: May 25, 2013, 01:39:42 pm »
She's seen daddy build enough that she decided she'd beat you to a driving game build.
Maximus
    • Arcade Icons
« Reply #159 on: May 25, 2013, 01:43:17 pm »
Ha ha yeah she's hoarding parts already.
Barrel masked up ready to paint the remaining straps in place.
MOWAHHHH classy hammered black
