Author Topic: UK Lowboy Project Build x2. (Vertical & Horizontal)  (Read 10764 times)
lettuce
  • Make It So!
« on: November 04, 2012, 12:48:53 pm »
Im am starting work on my 4th arcade cab project, as space is a premium i wanted to build a compact smaller than standard cab. After seeing some members refer to something called a 'Lowboy' cab, i decided to look them up to see what the fuss was about, upon seeing one i instantly knew this is what i was after. My design is based on apfelanni's mod cut down conversion he did on a standard size Lowboy cab i believe.
The Lowboy will stand approx 4' 2" (127cm) tall so alot shorter than your average cab. I started by using Google Sketchup to draw up my plans, and this is the shape i came up with.....
I have a friend who's family business has their own CNC machine, so she has kindly put my plans into CAD and cut a prototype out on the CNC machine for me to make sure everything fits before the final revision is to be cut....
I shall be using an Intel i3 based PC components to go inside this cab as i dont think mame or any other emulators take advantage of more than a dual core cpu do they?...or is AMD CPU's regarded to be better for Mame? I shall also be using GroovyMAME for this build as in my opinion is probably thee best build of MAME to use atm.
I have got 2 brand new 25" CGA 15khz monitors that i am going to be using for this project, i am looking at have one vertical and one horizontal cab so hopefully will have the perfect set up...best of both worlds.
In the coming days i shall be putting this prototype together so will post more pics of this coming stage.
« Last Edit: July 03, 2016, 06:04:48 am by lettuce »
SpaceHedgehog
  • Almost done ...
Re: UK Lowboy Project Build x2. (Vertical & Horizontal)
« Reply #1 on: November 04, 2012, 12:58:23 pm »
Lowboys rock. Design looks good. Will be watching this with interest  :cheers:
Click a pic for a video tour
lettuce
  • Make It So!
« Reply #2 on: November 04, 2012, 01:11:17 pm »
Thanks man!  :applaud:
Does anyone know what the correct angle of the monitor should be for a Lowboy??.....thats if there is a regulated angle?
  • Last login:March 10, 2026, 12:46:21 pm
« Reply #3 on: November 04, 2012, 03:57:03 pm »
This looks great! :cheers:
Typefighter01
  • Last login:February 27, 2026, 07:24:12 pm
  • Back I guess...
« Reply #4 on: November 04, 2012, 04:38:40 pm »
I wondered why you answered my monitor question like you did. You will surely have your cab running before I start my next cab (not until Christmas), so I will be following this build closely....
bluemini17
  • Last login:June 06, 2014, 10:26:11 am
    • My Youtube Channel
« Reply #5 on: November 04, 2012, 04:56:30 pm »
Great to see another UK arcade nut. may I ask where you obtained the new monitors? I like the dimensions you have, cant wait to see this progress.
David
404
« Reply #6 on: November 04, 2012, 06:04:47 pm »
love the size! been thinking of making a 4 foot single player lowboy for some time now.
dextercf
  • [thisispersonal]
« Reply #7 on: November 04, 2012, 06:10:54 pm »
Me wants to follow this build.
+1 on the monitor angle!
lettuce
  • Make It So!
« Reply #8 on: November 13, 2012, 06:13:16 pm »
Finally got around to starting work on putting the cab together today, so ill let the pictures do the talking...
Have also ordered a pair of Ultimarc ServoStik sticks, i wanted to make this a 2P cab but looking at the cab in person now not sure if i can fit 2 sets of controls on the control panel given the width of the cab.
On a side note i stumbled across a website a while back that had loads of control panel layout diagrams, that you could print out. Does anyone know what the url of this website is?
« Last Edit: July 03, 2016, 06:10:15 am by lettuce »
jmike
« Reply #9 on: November 13, 2012, 06:28:29 pm »
Nice work so far. I'm hoping to build a similar setup so I'll be watching closely.
I believe the site you're looking for is:
http://www.slagcoin.com/joystick/layout.html
lettuce
  • Make It So!
« Reply #10 on: November 13, 2012, 06:33:47 pm »
Thats the one, cheers mate!!  :applaud:
lettuce
  • Make It So!
« Reply #11 on: November 24, 2012, 06:15:57 am »
A slight update to this project. Mounting for the 25" CRT monitor in place.....
And then the CRT placed inside the cab with the bezel on, its a nice very tight fit but the corners of the bezel will need to be adjused.......
Does anyone know the actual radius of the corners of a CRT screen??...if there is a universal measurement?
And then with the Control panel in place....
I dont think im entirely happy with the placement of the monitor i feel it needs to be an inch or so lower!!??
« Last Edit: July 03, 2016, 06:13:32 am by lettuce »
Termin8tor
  • Last login:August 04, 2020, 01:54:23 am
« Reply #12 on: November 24, 2012, 06:31:29 am »
Watching this one with interest.
« Reply #13 on: November 24, 2012, 12:57:03 pm »
If you place your hands on the panel and look at the monitor, does it feel uncomfortable, or is it just the fact that it's off center vertically? You have a nice space under the monitor to add an instruction card holder for example, would probably look closer to a factory build that way.
Looking good! :cheers:
Eldritch1969
« Reply #14 on: November 24, 2012, 01:41:44 pm »
Nice design. Must feel really comfortable sitting in front of it. Very interesting to see it coming along
Cheers !
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
« Reply #15 on: November 26, 2012, 03:54:31 am »
Cheers !
My experience with Low Boys are more about standing then sitting.   I never liked the angle sitting.  ( Low Boy cabs in NZ anyways )
« Last Edit: November 26, 2012, 01:32:25 pm by Acids »
« Reply #16 on: November 26, 2012, 11:35:48 am »
I hate you people with your access to CNC's.
Seriously, nice job so far.
lettuce
  • Make It So!
« Reply #17 on: November 26, 2012, 05:15:45 pm »
Cheers !
This will be sat at...its lower than your average lowboy cab after all
matt4949
« Reply #18 on: November 26, 2012, 07:46:44 pm »
very cool. I think my next project will be a bartop with a CRT. Really liking the look of this one.
TGov
  • Last login:March 21, 2017, 02:07:54 pm
« Reply #19 on: November 26, 2012, 08:05:09 pm »
Where did you get your monitors?
bluemini17
« Reply #20 on: November 30, 2012, 02:21:02 pm »
+1  ;D
krick
  • Gotta have blue hair.
« Reply #21 on: December 23, 2012, 01:11:33 am »
I don't think anyone ever answered this.
Intel CPUs are hands-down the best choice for MAME.  Don't even consider an AMD CPU even if it is significantly cheaper.  You'll regret it.  This isn't an Intel fan-boy thing.  This is fact.
As for multiple cores, I believe that baseline MAME only takes advantage of 2 cores.  It can push some of the rendering code into a different thread which results in a performance boost in certain drivers.   As I understand it, the latest version of GroovyMAME uses yet another thread for the video page flipping code.  So I guess the optimal CPU for GroovyMAME would have at least 3 cores.  However, I don't know if anyone has actually benchmarked and compared performance in GroovyMAME with 2 vs 4 cores, so don't take my word for it.
You can get Intel i5 quad-core CPUs for under $200 on Newegg.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
