Author Topic: ShoRyuKade 2.0  (Read 27565 times)
ShoRyuKade 2.0
« on: May 27, 2012, 11:01:30 pm »
Edit: decided to call it ShoRyuKade (for now)
The good:
Monitor has a great picture, just needs some minor adjustments, I dont see any burnin either, weut!
Perfect 360 controllers, I think these things retail for more than I paid for the cab
cab is very sturdy, and since it was in a Laundromat it actually smells GOOD, like fresh linen
looks like it has a fairly new switching power supply in it (last pic)
Free CPS2 kick harness!
The bad:
cab is kinda beat up, has a buncha holes I'll need to patch
The wiring is a mess, but that's not exactly a tough thing to fix
Bezel is borked
Marquee has gapper tape all over it and will need to be replaced, I salvaged the translight
Marquee light needs replaced, it works but its LOUD
Monitor glass has DEEP key scratches
Tmolding is shot.
enough text, here's the money shots:
Its gonna stay in the garage so I can take it out to the drive way for sanding /painting /etc
« Last Edit: January 30, 2017, 01:15:36 pm by Malenko »
Re: No name, no theme, no idea what to do with it
« Reply #1 on: May 27, 2012, 11:11:04 pm »
Run N Gun! :D
« Reply #2 on: May 27, 2012, 11:16:11 pm »
Run N Gun! :D
Yup, some awesome guy sold it to me.
I was waiting for the download and conversion of the attract videos to finish, but its been going for over 8 hours. If only MaLa played MP4s (I cant hit the website and dont have the beta)
I've been working on game lists, even though I have almost the entire romset for the mame build I have (.141), its still too daunting to have 19,000 games to pick from. Anyone have any example game lists in MaLa format?
TopJimmyCooks
« Reply #3 on: May 28, 2012, 10:46:19 am »
I just went through the exercise of buying a lamp, starter and replacement line filter for a noisy florescent on a ms pac.  just go get the $8 undercab 18" fluorescent at the hardware store and have done.
HoBoJoe
  • Last login:August 24, 2016, 09:02:48 am
« Reply #4 on: May 29, 2012, 08:42:00 am »
Why isn't your garage full of pinball machines?
Or an awesome Porsche?
« Reply #5 on: May 31, 2012, 07:18:05 am »
Can't afford the free shipping from San Antonio, Texas :)
Ok, so I pulled the guts from another computer I had sitting around, Athlon X2 6400+ 4,GB of Ram, 500GB HD, and an Nvidia 9800GT and a Corsair 520W PS; should run mame and the Taito games just fine. Not sure I can get SFxT running at a low enough res to play on the arcade monitor haven't bothered to try yet. I got all that mounted to the slide out board from the Dynamo cab along with the Jpac.  I couldn't find a good way to mount the DVD drive to I screwed it into the hard drive bracket and covered it with electrical tape for aesthetics. I already have MaLa and most of the game lists made, I can always RDP into the machine for additional changes over the network.
enough jibber jabber, here's more pix:
The Dynamo slide board:
Power supply mounted:
motherboard stand offs installed:
motherboard installed (w/giant HSF):
hard drive mounted (using a USB case frame, hey, its all I had):
Stand offs for the Jpac, doubled up in height:
everything installed:
everything installed, different view:
Now the power strip is held in with a cable hook (plastic hook with a nail in it) over top the cord. the screws just keep it from sliding around. It will be laying on its back so I don't for-see it moving at all. I used extra screws to "box it in place" I'm not dumb enough to put a screw through a power cord , heh.   Next step is making sure all this works in the cab, then I redo the sides and order new buttons and T molding.
HoBoJoe
« Reply #6 on: May 31, 2012, 08:39:30 am »
I might have a bracket for you at the house so you don't have to use electrical tape on the CD drive. Remind me when I'm not being lazy and I'll take a look as well as get you some connectors.
« Reply #7 on: June 09, 2012, 07:22:53 pm »
got the bracket, no more electrical tape, heh. No pix of that yet, I'm waiting for the EDID dongle from germany. So I pulled the buttons and plexi from the CPO:
Gotta figure out a way to drill a new 7 button template per player, prolly cut most of that out and hope the plexi can support the buttons :/
Re: The unnamed Dynamo
« Reply #8 on: June 09, 2012, 10:20:26 pm »
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
« Reply #9 on: June 09, 2012, 11:00:43 pm »
[/quote]
WOW, so this cabinet has been retro-Fitted a few times.    Its like mice have been eating though that thing.
Personally id leave what you can.   Perspex sitting even on this will be strong enough to support button mashing  ( unless you have LEAD  hands )
« Reply #10 on: June 10, 2012, 09:42:17 pm »
So had to go to Lowe's to get a new filter for my fridge, so I figured I'd snag some plexi while I was there.
2 sheets was $48 and the guy was nice enough to do multiple cuts without giving me much grief, and he actually cut straight lines.  He wouldn't/couldn't do the angles of the CP, so I bought a plastic cutting knife for $5. Since I had 2 extra CP plexis cut, I might just take one over to my grandpas shop and have him cut it on a table saw, although my cut wasnt too shabby. I'm prolly gonna run the dremel along the end so its more flush.
Guess I need to hire snake to do some artwork or something.
new plexi screen and marquee:
Control panel:
and another ISO shot:
next up, casters and fixing up the sides.
BurgerKingDiamond
« Reply #11 on: June 14, 2012, 04:27:01 pm »
scroll down to the bottom if you want to see how I retrofitted my panel. It's the same situation you're in.
http://forum.arcadecontrols.com/index.php?topic=119420.0
-Welcome to the Fantasy Zone.
« Reply #12 on: June 15, 2012, 11:31:48 am »
Great job on that, that's going to be my last resort. I think I can just acrylic over the Swiss cheese, but if it doesn't hold, I'll do that.
In other news, EDID dongle shipped 4 days ago, according to the email I got from arcadeshop.de  Ive asked SNAAAAAKE to do the art, I'm waiting on a template so I can get the drilling done. KI2 marquee can be a place holder for the top. Once he sends the template I'll drill the holes and mount the buttons/sticks and see how it holds up. I wanna use him but if I dont get the template by tomorrow I'll PM someone else
« Reply #13 on: June 15, 2012, 11:40:15 am »
...some LED'ed joystick light thingies? I just need 2 =D lol
Is this build going where I think it's going?
« Reply #14 on: June 15, 2012, 05:02:59 pm »
Where do you think its going?
its gonna have less wiring than your cab, for sure.
« Reply #15 on: June 15, 2012, 05:09:12 pm »
LED controls?
« Reply #16 on: June 16, 2012, 04:23:50 pm »
LED controls?
naw, nothing like what you have, I just wanted to light the "stickholes" blue to match the buttons and what not. You set the bar WAAAAYYYYYYY too high when it comes to lighting a cab up =)  :cheers:
oh yeah, my EDID came in, weut!
« Last Edit: June 16, 2012, 09:05:50 pm by Malenko »
« Reply #17 on: June 16, 2012, 08:57:51 pm »
so I used my KI machine to make the button template:
then I did the same for player 2. I put the plexi back on the panel and marked off what needed to be trimmed. I ended up taking a hand saws-all and trimming the metal back. then I wrapped it in black leather texture vynil (mostly just to cover the butchered panel) as a place holder till I figure out the artwork.
I think it turned out rather well:
I also bought casters but they can wait until tomorrow or later in the week, my back hurts from crouching over for almost 2 hours to get the panel squared away.
« Reply #18 on: June 17, 2012, 09:23:58 pm »
so yeah umm DVI to VGA adapter, EDID dongle, VGA cable:
still cant get soft15 to install :/
so I put one of the sticks in:
same p360 stick, just different shaft.
I also uncovered the plexi for the monitor, need to make a new bezel still though, old one looks like crap.
« Reply #19 on: June 19, 2012, 07:48:35 am »
so in light of soft 15 not working (and no response from Sailor Sat) , I may be putting a different PC in there running XP with a 6800GT card (no dongle required) should still be plenty enough to run most MAME games, we'll see. Cant wait to mount a different PC, wheeeeee
sharpfork
    • KADE
« Reply #20 on: June 21, 2012, 12:17:57 am »
Project looks great so far!
I have two of those cabs and love them.
FYI you can squeek a 27" crt in that cab hanging off the factory mounts.
« Reply #21 on: June 21, 2012, 01:59:05 am »
Lookin' sharp thus far.  Gonna be a beast when you're through.  That is a pretty sweet chain of adapters and dongles you got going on there too.  ;)
« Reply #22 on: June 21, 2012, 11:08:35 am »
spent a while yesterday rewiring that rats nest of a control panel:
moved the jpac to its new location:
and, the one thing I thought was going to go smoothly, didnt:
I think I need to bridge the hsync and vsync to C sync ; cant wait to blow up this monitor
« Reply #23 on: June 21, 2012, 01:25:43 pm »
Needs more tuner spray...
« Reply #24 on: June 21, 2012, 08:17:38 pm »
filled it with blinker fluid, then rebooted 3 times:
actually it was a resolution issue, this WG 25K7171 hates a TON of resolutions and Im gonna hafta go through and remove a bunch of them from soft15.  Ive had quite a few arcade monitors and this is the one I like the least by a lot.
so fired up KI2 just to see...... wait that's not right....
stupid "stretch using hardware" was on!
a lot of collapse at the top of the screen, its not like that when playing PCBs, wtf is up with 7171s?!
here's the PC, no DVD drive cause I dont need one. totally different computer than what I started with. This is a core2duo 2.6GHz per core (E5200 cpu) and 4 GB of RAM running windows XP Pro SP3:
here's a pretty good shot of the wiring, I ended up having to redrill the green button's hole and moving it up about 3 inches, where it was at you couldn't hit it from the inside:
« Reply #25 on: June 21, 2012, 08:42:28 pm »
Have you tried adjusting the 50/60Hz pot?
« Reply #26 on: June 21, 2012, 10:10:05 pm »
I'll be doing that tomorrow, and trying to channel the wires in the cab a little better. The more I mess around with this arcade monitor the more I love LCDs
« Reply #27 on: June 22, 2012, 09:15:30 am »
Sparkolicious
  • Last login:June 21, 2024, 11:49:25 pm
  • Measure twice cut once dern it!
« Reply #28 on: June 22, 2012, 10:16:57 am »
Re: ShoRyuKade!
« Reply #29 on: June 22, 2012, 02:15:15 pm »
whipped up a control panel (well stole it from teh googles) resized to fit and actually did whip up a marquee (using UDON art) and had it printed at kinkos fedex for $16
I think it turned out rather well.
CPO:
Marquee:
printed out on my desk at work:
should be installed tonight!
HoBoJoe
Re: ShoRyuKade!
« Reply #30 on: June 22, 2012, 02:16:19 pm »
Let me know when you need me to come over and break it in....
TopJimmyCooks
Re: ShoRyuKade!
« Reply #31 on: June 22, 2012, 03:21:36 pm »
Don't let Yotsuya bust your chops for calling your 'cade a "-Cade"  or in this case, a "Kade".   :cheers:
Re: ShoRyuKade!
« Reply #32 on: June 22, 2012, 06:13:17 pm »
last MAME I built for me was Mortal Kabinet, lol
This is machine #4, does that count as an arcade?
Here is the marquee installed:
and here it is lit up:
heres the control panel, havent added the art yet, and theres some plastic shavings between the acrylic and the panel:
and here's everything as it stands now:
HoBoJoe
Re: ShoRyuKade!
« Reply #33 on: June 22, 2012, 06:15:05 pm »
Stop being lazy and put the CP art on!
Re: ShoRyuKade!
« Reply #34 on: June 22, 2012, 07:28:17 pm »
Stop being lazy and put the CP art on adjust that 50/60Hz pot!
+1!
Re: ShoRyuKade!
« Reply #35 on: June 22, 2012, 08:13:19 pm »
+1!
sadly I adjusted that pot, it made the top worse one way and the bottom worse the other way, I think this 22 year old monitor (looked at the manufacture date sticker, lol)  needs some new caps :/
CP art will prolly go on tomorrow Im trying to get some Diablo 3 time in before the power goes out
Re: ShoRyuKade!
« Reply #36 on: June 22, 2012, 08:22:47 pm »
---smurfy---. :-\ At least cap kits are cheap and pretty easy to do.
Re: ShoRyuKade!
« Reply #37 on: June 22, 2012, 10:13:22 pm »
really bad thunderstorms due all night
  • Last login:March 06, 2026, 05:17:37 pm
Re: ShoRyuKade!
« Reply #38 on: June 23, 2012, 06:49:12 am »
 Nicely done! :cheers:
Re: ShoRyuKade!
« Reply #39 on: June 23, 2012, 10:59:59 pm »
so CPO is installed, took a freekin HOUR
pinned it between the plexi and the CP:
cut the holes: (and trimmed the corners)
tada!
I think I need new P1 and P2 start buttons:
so other than making my mala skin and layout (and making more game lists) the cab is pretty much done. Only took a month! Now I can get back to work on my racing cab!
