January 26, 2026, 07:44:10 am
Nice build buddy.So I have a more "midi" sized cab (32" playfield) and was going to make some back box hinges out of black plexi. The plan was to make a wooded template then cut the pieces with a router and then put the bends in with a heat gun, but down the line i decided that more viewable art work was more important to me than the hinge.What are you planning to use for side rails?, i went with some small steel L pieces from the local hardware store then just sanded until shiny(need a nice round bend for comfort).Also as for the custom lockbars on the other forum that is where mine came from, although again it still needs a sand and polish.
I think this just hit my list of projects to do....
WoW nice additions where did you get the coindoor from ?
Quote from: GIZMOGAMES on May 21, 2012, 10:12:05 amWoW nice additions where did you get the coindoor from ?I got it from ultimarc.comI just checked the site out and now I see my problem... "COIN DOOR: Finished in black Hammerite. fits an aperture 8.5 inches wide X 7.5 inches tall."That's the measurement for the hole, not for then entire coin door and frame. I'll just get a new sheet of MDF for the front, move the plunger and start/extra ball buttons further out, and it should squeeze in there. I started to move things around in sketchup, and I'm pretty sure it'll work, but I might have to route the insides of the side panels so that the plastic nuts for the pushbuttons fit.
Thanks. As for the wife, I'm not sure, but you might try jewelry?
I showed my wife your build, and she loves it! She said she wants me to make one for our youngest boy... he's only two now, so it may take a year or two.Anyhow, can't wait to see this one done.
Wow... no responses on the artwork?
Quote from: swaffar on May 28, 2012, 07:18:35 pmWow... no responses on the artwork?Probably because there's nothing to criticize. I think it looks great.Are those goldleaf push buttons I c? I've bought a mess of them, but haven't tried them yet (no cab, & I don't want to build something temporary to test them out--I suspect I'd never get the cab built after that).Great work. Keep up the posting!
I'll have left/right flipper, left/right tilt, launch ball, start game, extra ball, and i'll have a button for menu. I'm also installing an old microsoft controller that has accelerometers so I can physically nudge....Some games have a magna save button and I know the Shadow has a second side button to control an object on the playfield.
Quote from: swaffar on June 16, 2012, 07:31:58 pmI'll have left/right flipper, left/right tilt, launch ball, start game, extra ball, and i'll have a button for menu. I'm also installing an old microsoft controller that has accelerometers so I can physically nudge....Some games have a magna save button and I know the Shadow has a second side button to control an object on the playfield. In addition to the standard L/R flippers and L/R Magnasave you mentioned, some tables have separate upper L/R flipper controls like the Family Guy table with Stewie's playfield. The good news is that I can't think of any tables that use both the upper flippers and Magnasave. You could probably just wire left-upper-flipper and left-Magnasave together and trigger both keypresses ("A" and "L-Ctrl") with one button. Same on the right. (Apostrophe and "R-Ctrl")I understand why you might want both left/right tilt nudge buttons and a controller with accelerometers for nudging. Some people find that the accelerometers can be a real pain to use for nudging due to sensitivity or calibration issues. (UHID-G fine-tuning can be quite the experience.) A plumb-bob nudge might be a good alternative.Instead of the usual 3 nudge buttons (L/R/Up), you take the lower bracket, cut it into 3 pieces (left, right, and front), wire them to the button inputs and mount them on a piece of wood or plexi. Upper bracket is tied to ground so when you nudge the cab, the bob swings and closes the circuit. You can adjust sensitivity by adjusting the height of the bob.Here are several examples of plumb bob nudge assemblies:http://www.hyperspin-fe.com/forum/showthread.php?10895-Cab-nudging-with-tilt-bobs-filter-double-presses-with-ahk-script&p=112149#post112149http://www.vpforums.org/index.php?showtopic=19365&hl=plumb (First post, second pic)Scott
