Author Topic: Copying hard drives  (Read 2081 times)
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
Copying hard drives
« on: February 15, 2012, 09:30:14 pm »
Once again, I know this is probably the wrong section... my apologies ahead of time.
 I have a Toshiba satellite M45 that won't power on even with AC attached. Tried moving itsHD to my Fujitsu 5112 so I could move files I need to a hard drive, but no luck as connection is different.
 What options do I have for getting those files that I need?
Thenasty
  • Last login:Today at 01:30:33 am
Re: Copying hard drives
« Reply #1 on: February 15, 2012, 10:10:06 pm »
get an external USB casing (find out whats the HD's interface first).
Free VGA Breakout Cable
Richard_Nixon
  • Last login:December 02, 2012, 08:44:07 pm
  • Now listen here you drugged up communist.
« Reply #2 on: February 15, 2012, 10:46:31 pm »
It is most likely a SATA disk. Is there 2 flat connectors, one with 7 pins and one with 15 pins?
If so, something like this should work just fine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817392032
These can be had at most computer stores. Probably not for that price though.
When trying to copy files, you will also probably run into an "ownership" issue thats fairly easy to resolve.
See this KB article.
 http://support.microsoft.com/kb/308421
RTSDaddy2
  • Bees! Oh bother!
« Reply #3 on: February 15, 2012, 11:43:49 pm »
Actually Richard, it's one long connector (sorry didn't count pins.)
Richard_Nixon
« Reply #4 on: February 15, 2012, 11:51:30 pm »
What you mention sounds like it might be an adapter.
Could it look like this? Some connectors have pins going right across. (No black space as in this picture)
Drnick
  • Plodding Through Life
« Reply #5 on: February 16, 2012, 08:08:24 am »
The hard drive interface on an M45 is IDE.   Get an external IDE Caddie designed for 2.5" IDE Drives and plug it into that.
