Author Topic: Will this burn my apartment complex down? Mains Separating  (Read 3045 times)
Bramlet
  • Last login:June 25, 2012, 05:25:23 pm
« on: February 10, 2012, 09:17:17 pm »
I just wrapped some electrical tape around the mains cables and stuck them to the back of the dust cover. Is this acceptable short term and long term?
Richard_Nixon
  • Last login:December 02, 2012, 08:44:07 pm
  • Now listen here you drugged up communist.
Re: Will this burn my apartment complex down? Mains Separating
« Reply #1 on: February 10, 2012, 09:24:23 pm »
Use marrettes/mar connectors/wire nuts. They are safe enough for your wall, so its fine for your cab.
Bramlet
« Reply #2 on: February 10, 2012, 09:31:41 pm »
I don't want to get rid of the spades though.
Richard_Nixon
« Reply #3 on: February 10, 2012, 09:45:07 pm »
Are you using male and female spades plugged into eachother? or two of the same wrapped together?
Bramlet
« Reply #4 on: February 10, 2012, 09:53:42 pm »
I just unscrewed them from the power supply and kept them separate. The marquee lights will be flowing through these wires though.
BobA
  • What Me Worry?
« Reply #5 on: February 10, 2012, 10:17:08 pm »
Not a safe setup.  :-[ Use marrettes as Richard suggested.  You will have to cut off the spade lugs or get a terminal block where you can attach the spade lugs under a screw.
Bramlet
« Reply #6 on: February 10, 2012, 10:33:54 pm »
Ok I would rather get a terminal block because these wires are as short as they can go and I want a quick reconversion process.
ark_ader
  • I glow in the dark.
« Reply #7 on: February 11, 2012, 08:14:43 am »
+ 100  :applaud:
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #8 on: February 11, 2012, 11:37:13 am »
+ 100  :applaud:
+1000
Taping together wires with a possible nebulous connection, then taping them to a flammable material ain't a particularly good idea.
Since this looks like a dedicated cab, I am hoping that any required monitor isolation is being done.
Working: Not Enough
Projects: Too Many
Progress: None
Thenasty
  • Last login:November 17, 2025, 12:54:16 am
« Reply #9 on: February 11, 2012, 12:58:12 pm »
unused wires should be snip/remove off.
Free VGA Breakout Cable
Bramlet
« Reply #10 on: February 11, 2012, 02:25:14 pm »
OK I got a terminal block and screwed it down, I even stacked another on top so nothing can fall down into it.
BobA
  • What Me Worry?
« Reply #11 on: February 11, 2012, 03:52:25 pm »
Looks good and safe now.   Print out a label and stick it beside the strip saying  Danger 120V
SavannahLion
« Reply #12 on: February 12, 2012, 01:14:38 am »
+ 100  :applaud:
+1000
x2
You've already found a solution, but keep the following in mind on future projects. One should have no qualms cutting and capping or modifying a wire if one is dealing with anything over the standard "safe" voltages. Wires are cheap, a couple of dollars at most. Your home, your life, your family etc etc is certainly worth more than a couple of dollars.
