Author Topic: Having HD trouble setting up a new computer mame transfer questions  (Read 1883 times)
gatordad
  • Trade Count: (+11)
  • Last login:October 01, 2025, 10:06:07 am
I'm starting to have issues where certain games won't run and when I reboot the pc I get
boot to the last good know configuration option
I'm guessing its HD trouble at an early stage
The HD is about 13 years old so I have an extra pc with pci express slot and an avga card
Can I copy over all my folders and roms to the new pc without issue? any advice or things to do or not to do from those who have crossed this bridge already?
Thanks in advance
Thenasty
  • Last login:October 10, 2025, 11:29:47 pm
Re: Having HD trouble setting up a new computer mame transfer questions
« Reply #1 on: January 04, 2012, 11:24:04 am »
why not just put the NEW HD on the same pc and clone it ?
Copying the entire MAME folder that includes EVERYTHING is fine. You just need to re-intall the DRIVERS for your sound/Video Card etc.. if using the HARDware from old to new.
I think if the PC now is good specs, just clone HD and your set.
Free VGA Breakout Cable
gatordad
« Reply #2 on: January 04, 2012, 01:27:59 pm »
The "new" pc has pci-e slot where the old one is agp I want to use the new pci-e Arcade vga card I have
Plus the old pc has 2 operating systems installed win 2000 and xp,  xp is the "e" drive and 2000 is the c drive
Thenasty
« Reply #3 on: January 04, 2012, 07:04:12 pm »
Ones the NEW PC is up and running with all DRIVERS and ready for MAME, you can copy the entire MAME folder and roms to the same spot where you have everything installed.
Everything should be good to go.
Hoopz
  • Last login:June 13, 2025, 09:18:32 pm
  • Intellivision Rocks!
« Reply #4 on: January 04, 2012, 10:10:08 pm »
Some versions of Windows have small issues when copying a folder from one hard drive to another.  Windows may make the folder "read only" so if you have any issues with the files on the new hard drive, right click on the folder and look at it's properties.
It's a huge pain to figure out because no one would assume Windows does that.  Once you've spent hours screwing around trying to figure it out, it becomes pretty easy to remember.   ;D
gatordad
« Reply #5 on: January 06, 2012, 01:46:58 pm »
I just formatted the new drive (1T) last night and loaded xp
Hopefully this weekend I'll finish this up
Lots more questions coming, its been a while since I set up my cab and its been left untouched for some time. (if it works don't muck with it) that was my mentality
gatordad
« Reply #6 on: January 09, 2012, 11:13:32 am »
Now I remember why this computer was put in the storage room a few years ago.
Kept getting the Blue Screen of Death
Took most of the weekend to figure out I had a bad stick of ram, but its stable now, will install everything as time permits this week.
