Author Topic: Tron Legacy - Update 05/03/2016 - Mala Woes  (Read 145490 times)
Re: Tron Legacy
« Reply #80 on: February 28, 2012, 03:19:21 pm »
Thanks bigmatty77.
I'm biased because I suck at painting but laminating is a lot of fun.
Re: Tron Legacy
« Reply #81 on: February 28, 2012, 05:52:03 pm »
My father is missing half his right index finger and the end of this right thumb from two different accidents.
Both occured when it was late, he was tired, and should have stopped working.
Every time I get tired, but just want to get done, I think about his missing fingers and stop.  :lol
Re: Tron Legacy
« Reply #82 on: February 28, 2012, 06:44:20 pm »
I watched my sculpture prof in college saw his index finger in half longways to the first knuckle.  Not a whole lot you can do for that one because of the waste.  He was teaching a safety class, it can happen to anybody.  Just be glad you didn't shoot yourself or anything too traumatic.
Yuck.  Did they just amputate part of his finger?
That will be me now.   ;D
Hoopz
  • Intellivision Rocks!
Re: Tron Legacy
« Reply #83 on: February 28, 2012, 06:55:38 pm »
Thanks bigmatty77.
Maybe I need to try laminate but it seems like painting would be  easier.
Though your sides do look great.  The rest of the build is top notch.  Projects like this make me feel bad about mine.  Big meany.   ;D
Re: Tron Legacy
« Reply #84 on: February 28, 2012, 06:57:56 pm »
No, the blade ran along the side of the bone kinda shaving it a bit but didn't split it.  The nail was thrown off completely.  The stitched it together and it kinda healed back okay but his finger got a lot thinner towards the tip.  No idea how it looks now but it was wicked grody at the time.  Nothing beats the time I saw a specialist get a M240B retaining spring through the lap.  He's got a teflon nut now.  I've been around some really twisted crap... now that I think about it I'm probably bad luck.
Re: Tron Legacy
« Reply #85 on: February 29, 2012, 11:11:45 pm »
We laminated the back panel prior to cutting out the door.  I tried a few test cuts and was not happy with the results so I asked my brother-in-law to come bail me out.  Here are some pictures of how he used the table saw to cut out the door.
He drew a line on the fence to line up where the blade began.  He then drew lines on the work piece to be able to line up where he wanted each cut to begin.
The door had to be shimmed for the last cut to keep the door from falling out and cracking the laminate.
And the back is done!
I just need to finish routing the speaker grills and it will be time to start assembling.   :cheers:
gbeef
    • arcadepix.com
Re: Tron Legacy
« Reply #86 on: March 01, 2012, 12:51:11 am »
very nice build so far sorry to hear about those fingers you need them for play the arcade cabinet so watch out!@
My cabs
4 Player Arcade
X-men Arcade Remixed
Re: Tron Legacy
« Reply #87 on: March 01, 2012, 10:00:14 am »
Thanks gbeef!
Sparkolicious
  • Last login:June 21, 2024, 11:49:25 pm
  • Measure twice cut once dern it!
Re: Tron Legacy
« Reply #88 on: March 01, 2012, 11:09:00 am »
Really nice build you have going!   :applaud:  Awesome idea for the vent covers!  Have you straightened the monitor bracket yet?  Cresent wrench will do the trick if not.
Grats on not loosing a finger!  I've been around power tools most of my life and I have seen some pretty devastating  injuries.  I don't wear gloves around saws ever.  Just doesn't have the same "feel", and I have seen more than one person get their finger pulled into the blade when working with smaller pieces/rips.
Re: Tron Legacy
« Reply #89 on: March 01, 2012, 06:43:34 pm »
Thanks Sparkolicious.  I don't always use gloves but I feel like they helped me with this one.  But I can definitely see your point of the blade sucking in your fingers via the glove.
I did get the bracket straightened.  I ended up removing the bracket and flattening it with a hammer.  I didn't want to take a chance on hurting the monitor.
Re: Tron Legacy
« Reply #90 on: March 06, 2012, 10:36:24 pm »
I have this Friday off and had planned to spend the day putting the cabinet together.  Working by myself I figured it would take most of the day.  My brother in-law called this afternoon and offered to help me work on it tonight.    :cheers:
With two sets of hands and 4 drills it went much faster than I ever could have imagined.
First we secured the two sides and back to the base using an air nailer.  Then we went back using clamps and screwed the panels together.
Whoops.  Missed one.  At least it is on top.   ;D
I need to install the monitor mounts and speaker section.  I have a little more work to do on both of those yet.
Then it will be time for a little sanding/bondo on the screw holes.  Should have the sides laminated by the weekend.
« Last Edit: March 06, 2012, 10:41:14 pm by wp34 »
dandare
Re: Tron Legacy - Update 3/6/2012
« Reply #91 on: March 06, 2012, 11:48:53 pm »
Gorgeous!
Its a lovely feeling when you stand it up for the first time.
And I'm super jealous of your workshop!  ;D
« Reply #92 on: March 07, 2012, 09:44:44 am »
Gorgeous!
Thanks dandare.
The workshop actually was my fathers.  It is pretty awesome.   It is heated, has a built-in stereo system and had DirectTV at one time.  He was going to help me but passed away before I got started on my build. It has been important to me to use his shop and tools as much as possible.
Woodshop Flunky
« Reply #93 on: March 07, 2012, 12:47:27 pm »
Loving the look of this cab... keep it up!  :applaud:
« Reply #94 on: March 07, 2012, 02:26:31 pm »
High praise coming from you.  Thanks!
« Reply #95 on: March 09, 2012, 09:40:12 pm »
As long as I go with white or black my T-molding concerns from earlier are solved.  T-Molding.com has 11/16" that lines up perfectly.
I've been leaning towards white for some time so I'm really excited the sample fits so good.  :cheers:
Re: Tron Legacy - Update 3/9/2012
« Reply #96 on: March 09, 2012, 09:44:45 pm »
Learned another interesting trick from my brother-in-law.  He uses an industrial glue gun to seal the corners and edges.  It seems to work real well where two angled panels meet.
Well Fed Games
  • Delicious!
« Reply #97 on: March 10, 2012, 12:56:06 am »
That does look really sharp!
« Reply #98 on: March 10, 2012, 12:02:25 pm »
Thanks.   I just wish I would have found that size earlier.  Would have saved a lot of consternation.
« Reply #99 on: March 10, 2012, 12:17:45 pm »
For some reason the speaker grill has been one of the most tedious parts of this project.  I won't say frustrating because working on it has been a lot of fun but it is taking much longer than I anticipated.
I tried using an old 5x7 picture frame as a jig but that ended up being a major fail.  I decided to make a jig using strips left over from cutting the cabinet.
I want a 1/8" or so reveal so I had to plunge route around my opening to make room for the black mesh.
A 2x4 worked real well as an edge-guide.
I was a little worried about this part since the work piece was already laminated but it went very well.
My wife used this handy acrylic paint pen to paint the revealed edge black.   :cheers:
I'm going to use this to touch up other areas of the cabinet if/when required.
« Reply #100 on: March 10, 2012, 12:23:53 pm »
For some reason securing the mesh and speaker fabric proved troublesome.  I tied a few different methods before settling on 1/2" trim to hold it in place.
Trying to work on this part out at my dad's shop proved troublesome.  There is so much saw dust in the air that the speaker fabric kept getting dirty.  I decided to finish this part at home.
I took my oldest son to see Steve Wozniak speak on Thursday.  He left his badge on the counter so I used the back of it to protect the speaker fabric as I hammered the trim in place.
Here is the finished piece.  I'm happy with how it turned out.
SammyWI
Re: Tron Legacy - Update 3/10/2012
« Reply #101 on: March 10, 2012, 04:44:43 pm »
Really coming along nicely.  It starts getting exciting once the main structure comes together.
« Reply #102 on: March 10, 2012, 09:10:26 pm »
Thanks SammyWI.
There really is something to getting the cabinet upright.  On Tuesday I had a hard time leaving the shop.  I just wanted to hang around and look at it.  ;D
« Reply #103 on: March 10, 2012, 10:27:34 pm »
The speaker grill is mounted.  It was a little tough without a second pair of hands but judicious use of clamps helped.
I taped some paper over the grills to try and keep sawdust out as much as possible.
Knievel
    • Knievel Kustoms
« Reply #104 on: March 11, 2012, 11:59:08 am »
Arrr..I love me a good porthole cabinet
Nice work so far :cheers:
« Reply #105 on: March 11, 2012, 02:09:00 pm »
Thanks Knievel.  I didn't know that was what this style was called.  You would know though.   ;)
I was just showing my wife your Jet's Cocktail this morning.  Nice work as always.   :cheers:
We like the artwork you have hanging above it as well.
Knievel
    • Knievel Kustoms
« Reply #106 on: March 11, 2012, 03:20:38 pm »
haha.. I don't think it's really a cabinet style.
Thanks. Kids are having fun with it.
Artwork is by Michael Lang. Give him a search on eBay for some cool original works.  ;)
« Reply #107 on: March 13, 2012, 01:55:07 pm »
Minor update.  I finally got the top monitor bracket installed.  This was the piece I cut my finger on.  Wish there at least would have been some blood on the board for conversation's sake.
This was a little tough with just two hands but "Jed Clampett" to the rescue again!
I had just enough time to put another coat of bondo on the screw holes.  Need to sand those down next and it will be time for the outside laminate.
Hoopz
« Reply #108 on: March 14, 2012, 02:41:10 pm »
That looks really cool.   :applaud:
« Reply #109 on: March 14, 2012, 03:12:05 pm »
Thanks Hoopz.  A little slow but she is coming along.
mcseforsale
  • Creepy Mario Dude
« Reply #110 on: March 14, 2012, 03:27:53 pm »
More! More! More!  C'mon man!  It's been 4 days!!!!
Feel you on the table saw thing.  Growing up, my dad was a woodworker, too.  I always wondered why he didn't wear his wedding ring until he showed it to me...it stopped the saw blade on his table saw, saving his hand when I was about 5.
He always told me to get the cheapest wedding ring I could find (I dented mine in a MTB wreck...luckily it was 10 karat).
AJ
Green Giant
« Reply #111 on: March 14, 2012, 04:05:06 pm »
I had no idea you were from Valhalla
Toxic Arcade, my first build
PIZZ
  • Last login:January 14, 2013, 10:24:17 am
« Reply #112 on: March 14, 2012, 06:14:35 pm »
I take it you dont like the Woz? lol
« Reply #113 on: March 14, 2012, 06:39:11 pm »
AJ
Wow.  I assume he still had some damage to his hand if the blade got that close to his ring.  I think I would wear extra rings after that.
« Reply #114 on: March 14, 2012, 06:40:32 pm »
LOL - I made that hammer in metal shop back in junior high.  It does sorta look like Thor's Hammer on a stick.  I never noticed that before.
« Reply #115 on: March 14, 2012, 06:42:02 pm »
I love the Woz.   ;D  Notice I said I used the BACK of HIS badge.  My badge is safely on display in my office.
MacGyver
  • Last login:December 18, 2023, 12:49:00 am
    • Project Build
« Reply #116 on: March 15, 2012, 04:16:23 am »
Your project looks great.  I can't wait to see the end result. :applaud: It gives me hope. :)
Every time I see a table saw accident I think of this.
I don't know how much the modification costs or anything, but I guess you have to weigh it against how much a finger costs. >:D
« Last Edit: March 15, 2012, 05:52:31 am by MacGyver »
« Reply #117 on: March 15, 2012, 09:53:12 am »
That is really slick.  Turns your blade into a touch-screen that stops the blade when something conductive comes in contact.   ;D
I just gave their site a quick look but it sounds like you have to buy an entire saw and it is not an add-on.  Plus there is a $70 part that has to be replaced every time you save a finger.
Still pretty cool.  Thanks for posting.
Sparkolicious
« Reply #118 on: March 15, 2012, 10:10:50 am »
If some members of congress have their way, that technology will be required by all manufacturers.  Definitely cool technology even with having to replace the  blade and the brake. Still... I don't know if I want to be forced to pay the premium because BB wants to protect me.
Project is looking really nice!
dandare
« Reply #119 on: March 15, 2012, 08:43:29 pm »
that break is so fast. it almost looks fake, like a really cheap special effect where they edit 2 bits of film together.
