Author Topic: continue with arkanoid  (Read 5080 times)
ulao
  • Last login:October 07, 2025, 06:41:35 pm
« on: March 03, 2011, 09:19:34 pm »
Can anyone tell me how to continue in arkanoid. It says to hold fire and press start but that just ends the count down and says "game over". I get this will all arkanoid roms. The dip option says continue is enabled.
Re: continue with arkanoid
« Reply #1 on: March 03, 2011, 09:48:33 pm »
I don't know about MAME, but I have a real Arkanoid. And to continue, that is exactly what I have to do. First push and hold "Fire" then press "Start". It might be a key punch thing in MAME. Because when I press and release "Fire" it ends the count down and the same goes for just "Start". Maybe your MAME setup can't read two keys pressed at the same time?
ulao
« Reply #2 on: March 03, 2011, 10:44:02 pm »
well in this case its a joystick I'm fairly confident mame can read two buttons. I could understand the keyboard as in issue though. Hitting fire does not effect the count down for me, just start.
well actually its a joystick but emulating a mouse. So as far as mame is concerned its a mouse. I think it would be common knowledge if mame didnt support two simultaneous mouse buttons. However I think you are right in that it is sensing the one button and for some reason thinks the fire button is not down.
« Last Edit: March 03, 2011, 11:44:07 pm by ulao »
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« Reply #3 on: March 04, 2011, 01:39:32 am »
Forgive me if this is a silly question, but you are inserting a coin before trying to continue, right?
Blanka
« Reply #4 on: March 04, 2011, 04:18:48 am »
On SDL Mame with a Minipac it just works as it should.
But I really dislike the continue option in Arkanoid, as it refreshes the field to the starting state. Really anoying if you had 1 brick left.
ulao
« Reply #5 on: March 04, 2011, 08:20:08 am »
nitz, yes coins are in.
Blanka, I think that the way it always is. Think of SMB. You start to play and get half way, then you get a new start position ( mid way in  ), you use up all lives and continue. Now the start position is back to the beginning.
« Last Edit: March 04, 2011, 08:23:35 am by ulao »
« Reply #6 on: March 04, 2011, 09:35:58 pm »
Just tried it out in MAME, no problems continuing here. Played with an actual keyboard. You might try using a keyboard to see if it still does the same thing.
ulao
« Reply #7 on: March 05, 2011, 09:26:18 am »
I will thx.
Thenasty
  • Last login:November 17, 2025, 12:54:16 am
« Reply #8 on: March 05, 2011, 10:10:07 am »
just a guess just in case your are using one of those encoders that support SHIFT KEYS.
Maybe Button 1 whne HELD DOWN becomes a SHIFT KEY, if so you are getting ! instead of 1 when the Start 1 is pressed (just a thought).
I use Advmame and works like it should.
Free VGA Breakout Cable
ulao
« Reply #9 on: March 05, 2011, 10:26:17 am »
 I'm thinking both mouse downs are sending mouse button 3 or something.
left button button 0
right button button 1
middle button button 2
Left and right button 3 ? Testing this now. ( nope when pressing both buttons I get mouse 0  and  mouse 1, in mame )
I opened note pad typed asdf, the press a button and its still lower case, the pressed the other button and still lower case, does that rule out the shift business?
Hmm, I remember a test debug menu in arkanoid, going to try to find it and see if the buttons are working right.
Ok I got in to debug mode, and both button can not be pressed at once on the mouse emulator but can on the mouse. I will be able to figure this out, thx all!
« Last Edit: March 05, 2011, 10:49:34 am by ulao »
Thenasty
« Reply #10 on: March 05, 2011, 10:54:32 am »
your using the MOUSE button as Button 1 ?
Maybe thats the problem (guessing). Try using your PC witht he game using same setup in the CAB. Mouse B1 as B1.
Here is the other thought.
Maybe you have a GHOSTING effect. If you are using a HACK keyboard encoder, maybe pressing B1 and Start1, the keys are not being sent.
I am all guess here. I dunno what controller you are using.
I think you should try what above had suggested. Plug in a keyboard and give it a test. Process of elimination.
« Last Edit: March 05, 2011, 10:56:52 am by Thenasty »
ulao
« Reply #11 on: March 05, 2011, 11:03:45 am »
Ok I got it, was a simple mistake in my code. Working now. Thx again!
I'm developing my own HID. It was just something I over looked. I didnt really think about it till Nephasth said maybe its ignoring the second button. In my code it was accepting one or the other not both, now it does both.
« Last Edit: March 05, 2011, 11:06:21 am by ulao »
dextercf
  • [thisispersonal]
« Reply #12 on: March 05, 2011, 01:09:00 pm »
What are you using for a HID?
It sounds to me as if you got ghosting issues going on..
ulao
« Reply #13 on: March 05, 2011, 01:25:56 pm »
I'm designing a driver free adapter. http://spawnlinux.dyndns.org/Bliss-Box
As I said its fixed now, was a code issue.
