Author Topic: why i get error on www  (Read 6623 times)
Thenasty
  • Last login:December 17, 2025, 10:15:06 pm
« on: September 22, 2010, 01:46:27 pm »
i'm getting this error now when coming to BYOAC
Free VGA Breakout Cable
Vanguard
  • The aliens are using their mouthpiece, "Saint" to discredit my theory.
  • Last login:December 08, 2025, 03:12:05 am
Re: why i get error on www
« Reply #1 on: September 22, 2010, 03:01:03 pm »
I posted about the same thing.  (Random Error) was the subject.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:December 16, 2025, 07:43:13 am
« Reply #2 on: September 22, 2010, 03:09:49 pm »
Same forum, or different forums each time? What versions of IE are you both running? Are you viewing this site in compatibility mode?
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Thenasty
« Reply #3 on: September 22, 2010, 03:53:37 pm »
ie 8 (win 7). I have not done any changes at all.
If the Error window comes up. I click OK then click BACK and it's like everything is OK but FREEZES. It's like SERVER just CRASH and get the DIAGNOSE the Problem screen.
Thenasty
« Reply #4 on: September 22, 2010, 03:55:27 pm »
right ATM it looks like its working again.
What I did is just click the Compatibily mode and click it again (to Normal).
Let me see if the Ramdom error went away.
Thenasty
« Reply #5 on: September 22, 2010, 03:56:26 pm »
thats was quick. I still got another error.  :cry:
Vanguard
« Reply #6 on: September 22, 2010, 04:10:19 pm »
It really seems like it has to have something to do with the server.   I don't get this problem on any other website and sometimes I get the error constantly and I basically give up trying to browse BYOAC.   Other times it just comes and goes for a second and everything is fine.
saint
« Reply #7 on: September 22, 2010, 04:13:12 pm »
I'm running through the basic maintenance things on the forum now. Looking for error logs too.
--- John St.Clair
     Project Arcade 2!
Vanguard
« Reply #8 on: September 22, 2010, 04:22:11 pm »
If this keeps up, I'm going to demand a refund...
saint
« Reply #9 on: September 22, 2010, 04:46:30 pm »
I know, right?
Question - if you're reliably getting these errors, can you switch to Firefox or another browser than IE for a while, and see if the errors are still happening?
--- John St.Clair
     Project Arcade 2!
Vanguard
« Reply #10 on: September 22, 2010, 05:11:34 pm »
Chrome is working fine so far.   I'm sure it's an IE8 thing but it seems like it is related to communication with the server.   Maybe IE8 is more sensitive to a true problem that exists?
Vanguard
« Reply #11 on: September 22, 2010, 06:12:02 pm »
Hey Thenasty,
Try this.  Go into tools->internet options->security and click the "default level" button and see if things clear up.
I did this an so far no problems.
Saint, I want 6 months of membership fees refunded!!!!
Vanguard
« Reply #12 on: September 22, 2010, 06:15:40 pm »
Bah, nevermind...that lasted a whole 3 minutes and now I'm having trouble again.
Vanguard
« Reply #13 on: September 22, 2010, 07:06:38 pm »
Why am I getting crazystanian ads from google too?
saint
« Reply #14 on: September 22, 2010, 09:48:44 pm »
No freaking idea.
--- John St.Clair
     Project Arcade 2!
Thenasty
« Reply #15 on: September 23, 2010, 07:58:54 am »
still getting ramdon (diff..ones) errors.
Thenasty
« Reply #16 on: September 23, 2010, 08:13:42 am »
something I notice is that, once I get the error (then I click the back button), everything will be ok (in this site) but if I try to goto any web sites, it won't go.
This only happens in BYOAC site. I can go to anywhere but if I come here then get the error, I can no longer goto any sites.
If I close IE, get msg that It's busy, do I want to close it anyway.
« Last Edit: September 23, 2010, 08:16:10 am by Thenasty »
saint
« Reply #17 on: September 23, 2010, 08:57:18 am »
Is anyone else having this issue?
Do the two of you have this issue if you use a different computer? It's almost as if some code on the page is hosing it out.
--- John St.Clair
     Project Arcade 2!
gryhnd
« Reply #18 on: September 23, 2010, 09:37:35 am »
I fired up XP and have been surfing BYOAC for about 20' now using IE8 (I usually use FF whether I am on my Macs or PCs).
So far I've not run into the problem the others are seeing.
IE8 is set to "medium" security for the internet zone, fwiw.
Completed: No Name Upright
Vanguard
« Reply #19 on: September 23, 2010, 10:21:33 am »
I tried messing with all sorts of security settings and nothing helped.
saint
« Reply #20 on: September 23, 2010, 10:52:22 am »
But consistently it's only happening in IE on your machines?
--- John St.Clair
     Project Arcade 2!
Thenasty
« Reply #21 on: September 23, 2010, 12:00:59 pm »
I was in Google doing some Street MAP and error pop up. So it's not only BYOAC web page now.  :banghead:
gryhnd
« Reply #22 on: September 23, 2010, 12:49:19 pm »
You cannot view, access, or load some webpages in Internet Explorer 8 or Internet Explorer 9 Beta
http://support.microsoft.com/kb/967897
Vanguard
« Reply #23 on: September 23, 2010, 03:35:59 pm »
When it happens, it pops up the error dialog and once you close it, it takes you to the "Diagnose Connection" page.   When I run the diagnostics, it says everything is fine.
Thenasty
« Reply #24 on: September 23, 2010, 10:23:01 pm »
hmmm.. seems like it's working now. I did a manual update (notice that lat update I did was 11/2009, which is wierd).
I had 69 (200+MB) of windows update and the Adove Flash update too.
I'll keep testing if it fixed. So far so good....  :applaud:
Thenasty
« Reply #25 on: September 24, 2010, 08:02:36 am »
I really think that did it, unless Saint found a fix.
I'll keep my fingers cross for the next couple of days  :applaud: :applaud:
saint
« Reply #26 on: September 24, 2010, 08:59:40 am »
Not me :)
--- John St.Clair
     Project Arcade 2!
Vanguard
« Reply #27 on: September 24, 2010, 09:55:35 am »
Saint's just a guy in an India call center.   To get any real tech support on this forum you need to go to the owner.
I gave up and switched to Chrome.   I like it better that IE.
« Last Edit: September 24, 2010, 05:50:46 pm by Vanguard »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #28 on: September 24, 2010, 10:33:12 am »
Working: Not Enough
Projects: Too Many
Progress: None
Vanguard
« Reply #29 on: September 24, 2010, 05:52:22 pm »
I don't think it was fixed by your update.   I tried IE8 again and it's been working fine.   Seems like whatever the issue was, it cleared up or India fixed it.
saint
« Reply #30 on: September 24, 2010, 06:22:35 pm »
I *did* run various forum maintenance tools, but I believe you were still getting the error after I did so. I haven't done anything since then.
On the other hand... meh :dunno :)
--- John St.Clair
     Project Arcade 2!
Thenasty
« Reply #31 on: September 25, 2010, 11:33:23 am »
I'm convinced that ALL IS DANDY FINE now..... Whatever it was, it's a GONNER   :applaud: :applaud:
« Reply #32 on: October 02, 2010, 03:34:18 pm »
so stingray fixed it?
