Author Topic: Mame Goes White  (Read 1409 times)
Dillsta
  • Last login:August 15, 2009, 02:35:05 am
Mame Goes White
« on: September 28, 2008, 07:34:52 am »
When i get into mame through Mala and try to run  a game it goes white. i can get out of it but all games do this. sometimes if i mess around with the settings and turn it on and off it works. but next time i turn it on it goes white again.
Does this happen to any one else and if so how do you fix it?
Thanks Guys!
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 10:11:22 am
Re: Mame Goes White
« Reply #1 on: September 28, 2008, 10:06:36 pm »
you need to find out if MALA is giving you the problem. Try running MAME by itself that should determine if its MALA or MAME.
Free VGA Breakout Cable
natorious
  • Last login:June 19, 2023, 09:55:39 pm
Re: Mame Goes White
« Reply #2 on: September 28, 2008, 11:03:58 pm »
I had a similar problem from using an ArcadeVGA, defining specific resolutions for each game, and then using the wrong type of monitor.   I normally use a D9200 but at one point while I was still setting things up I had plugged in a normal computer monitor again and ran a few games without thinking.  The resolutions were out of range for the computer monitor and it resulted in a white screen.  Not sure if that helps at all but figured there was a slight chance you might have done the same.
Dillsta
Re: Mame Goes White
« Reply #3 on: September 29, 2008, 01:55:21 am »
I tested and it is mame not Mala Giving me the problem!
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
Re: Mame Goes White
« Reply #4 on: September 29, 2008, 04:36:47 am »
What version of mame are you using?
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
Dillsta
Re: Mame Goes White
« Reply #5 on: September 29, 2008, 07:27:11 pm »
using .77
i have a p3 850mhz
256mb ram
onboard graphics card
