Author Topic: Donkey Kong Bartop  (Read 5808 times)
m00p
  • Last login:October 14, 2014, 05:41:21 am
Donkey Kong Bartop
« on: October 01, 2014, 08:44:47 pm »
Hi,
This isn't really a project announcement, but I wanted to share it with you guys.
This mostly started out of love of the game. But when I saw this post on this forum http://forum.arcadecontrols.com/index.php/topic,131566.0/all.html   It gave me all the inspiration and drive to actually do it. So thank you SuperFrog for the inspiration, and I hope I can inspire other people with my cabinet also.
I learned a lot in the process of making this cabinet and it's not perfect but close :)  . In the future I think i'm going to remake the cabinet, to make it even better.
In the cabinet there is a 60in1 yamma board, and the rest is pretty basic stuff.
If you have any questions , i'll be happy to awnser.
For higher quality picture, you can check them here: http://imgur.com/a/RaI76
« Last Edit: October 01, 2014, 08:52:50 pm by m00p »
m00p
Re: Donkey Kong Bartop
« Reply #1 on: October 01, 2014, 08:46:43 pm »
more pics
« Reply #2 on: October 01, 2014, 08:48:29 pm »
Looks good!
And sometimes, it's nice to see a thread where everything is done than 19 posts with one photo each spread out over a year.  :cheers:
m00p
« Reply #3 on: October 01, 2014, 08:49:21 pm »
more
m00p
« Reply #4 on: October 01, 2014, 08:50:48 pm »
last
firedance
  • Last login:September 11, 2026, 12:06:36 pm
« Reply #5 on: October 02, 2014, 01:31:04 am »
Nice work  8)
johnrt
« Reply #6 on: October 02, 2014, 03:38:01 am »
That's really nice work!  :applaud: :applaud: :applaud:
I was also inspired by SuperFrog (the bartop wizard), and made a Fix it Felix cab based on his design. I have pics and everything here:
http://www.379009.net/nintendo-bartop/
m00p
« Reply #7 on: October 02, 2014, 07:32:26 am »
Thats also really nice done by you johnrt :applaud: , what is the width and height of you cabinet?
johnrt
« Reply #8 on: October 02, 2014, 08:37:56 am »
It is 71 cm tall and 55 cm deep (on it's deepest, CP area). And the inner width is 38 cm. I use 18mm plywood on the side panels so the total width will then be 38 + 1.8 + 1.8 = 41,6cm.
And yours?
« Last Edit: October 02, 2014, 09:04:26 am by johnrt »
ChurchOfSolipsism
  • Last login:May 09, 2023, 01:43:39 pm
« Reply #9 on: October 02, 2014, 12:24:58 pm »
Great work! I've been working on exactly the same project for years, but since I don't have a workshop right now it's on hold indefinitely  :(
« Reply #10 on: October 02, 2014, 12:55:32 pm »
With ground up donkey kong builds, the part I'm always curious about is the speaker grill. How'd you do yours?
« Reply #11 on: October 02, 2014, 10:19:04 pm »
Why would one grind up a good build like this. Your post makes nonsense. The trick to good grilling is to let the coals ash over first and use a chimney starter.
johnrt
« Reply #12 on: October 03, 2014, 03:25:01 am »
On my VCabinet bartop I made a similar grill. I made some kind of a jig:
The final result:
jond
  • Last login:February 01, 2017, 01:46:11 pm
« Reply #13 on: October 03, 2014, 07:58:29 am »
Verry Nice work i have a few questions
1 what did you scale down to from the original?
2 what size monitor did you use?
3 what is the angle the monitor is at?
4 Did you use mame or a jamma board and where did you get it if it's a jamma board which it looks like
Great Job im jealous i need to start my build now and stop drooling over yours.
m00p
« Reply #14 on: October 03, 2014, 09:53:36 am »
And yours?
inner width is also 44cm and is also use 18mm mdf, height:75cm and 51cm deep
m00p
« Reply #15 on: October 03, 2014, 10:03:42 am »
1. I scaled it down 68% from original  ( example: 6cm x 0.68 = 4.08cm )
1.2 inner width is 44cm and is also use 18mm mdf, height:75cm and 51cm deep
2. Size is a 15 inch
3. I don't know the exact angle because i would hold the monitor in position and would sit in front of it until it looked good  ;D , then draw a line with a pencil on one side and copy it on the other.
4. Its a jamma board, I got it from a online store... just google it and you will find it. the only thing you have to be sure of is that it is a vertical game board and not horizantal.  Meaning that you will have to put your screen vertical in the cabintet.
m00p
« Reply #16 on: October 03, 2014, 10:07:43 am »
Just draw the lines of the grill, and then draw the lines needed for your router to slide by...
ChurchOfSolipsism
« Reply #17 on: October 03, 2014, 03:16:24 pm »
The others have explained it already, but yeah I also used a drill and a router to do them (I put in two speakers; I do know that most old games are mono only but still two speakers give you better sound).
hahaha :cheers:
johnrt
« Reply #18 on: October 03, 2014, 07:48:06 pm »
On this one you really have to try it out. I actually spent a couple of hours positioning the monitor.
« Reply #19 on: October 03, 2014, 08:59:25 pm »
Good job!!
talkgeek
« Reply #20 on: October 04, 2014, 12:42:14 am »
..oh no, another build just went on my must-do-list  :banghead:
This looks fantastic, well done  :applaud:
