Author Topic: White Bartop Construction for a change  (Read 4263 times)
BobA
  • What Me Worry?
« on: March 07, 2013, 01:51:10 pm »
Here is another bartop construction using white melamine coated mdf instead of the black coated mdf that I always use.
Specs:  Mini Itx Intel D525mw 2GB ram 320 GB HD
            8 way joystick, 6 player buttons 2 pinball buttons
            Zero delay encoder all 12 buttons used.
            The pinball buttons are paralleled to player buttons 5 and 6 which are set for flippers
            19 inch HD profile LCD monitor (because I had a few around and 4:5 are getting harder to find in good shape.)
« Last Edit: March 07, 2013, 01:59:01 pm by BobA »
jmike
  • Last login:June 26, 2026, 08:45:04 am
Re: White Bartop Construction for a change
« Reply #1 on: March 07, 2013, 05:59:07 pm »
Looks great BobA.
What size are the speaker holes above the screen?
Are you putting speaker grills or leaving them bare.
BobA
  • What Me Worry?
« Reply #2 on: March 07, 2013, 07:44:21 pm »
The speaker holes are about 2 inches x 3 inches.  The original grill cloth for the speaker is fastened inside the hole before the speaker is mounted.
« Reply #3 on: March 07, 2013, 08:13:49 pm »
Bob, your builds are always so clean and professional.  Great look!  White is nice.
  • Last login:May 30, 2026, 12:00:14 pm
« Reply #4 on: March 07, 2013, 08:19:44 pm »
Good job Bob! It turned out great!
 :applaud: :applaud: :applaud:
  • Last login:June 21, 2026, 04:58:43 pm
« Reply #5 on: March 07, 2013, 08:20:08 pm »
+1 nice clean work.
BobA
  • What Me Worry?
« Reply #6 on: March 08, 2013, 10:26:08 am »
Thanks for the comments guys. What newer bartop profiles would you recommend.   It is going to be spring here in a month or 2 so I have to be ready to get cutting.
I would like to keep producing this design as it is very easy not but something new is always appreciated.
rablack97
« Reply #7 on: March 08, 2013, 10:35:48 am »
Maybe modify this design....
http://forum.arcadecontrols.com/index.php/topic,123039.0.html
I was thinking of modifying this, bring the controls to the side, with the monitor at like a 30 to 45 degree angle...
http://forum.arcadecontrols.com/index.php/topic,128666.0.html
Then theres here
http://bartoparcade.katorlegaz.com/
And finally, google "arcade bartop profiles" select images and you'll be in heaven....
good luck....
JDFan
« Reply #8 on: March 08, 2013, 01:03:33 pm »
If looking for a challenge -- perhaps something similar to Ond's Xenolix bartop -- ( http://forum.arcadecontrols.com/index.php/topic,128362.msg1313383.html#msg1313383 )
BobA
  • What Me Worry?
« Reply #9 on: March 09, 2013, 09:05:18 pm »
Xenolix has style.  Might be a tad tight to work inside but it looks sharp.
Thanks for the suggestions guys.   Love the little ms pacman cocktail design but looking for an upright screen.
The Kator Legaz plans have been around forever and are really dated now.
darthpaul
  • Last login:April 20, 2026, 01:24:27 pm
  • Join, It's your duty
« Reply #10 on: March 09, 2013, 11:48:54 pm »
Great job, I really need to take a crack at one of these.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
TheDude
  • Bartops all the way !
    • BARTOPMANIA
« Reply #11 on: March 10, 2013, 01:54:13 am »
Very nice build ! The white melamine coated option is also the one I chose for mine.
As for new designs, not bad to look at older cabinets and picture them cut in half.
A few ideas here :
http://bartopmania.com/index.php?t=msg&th=176&start=0&Bartops from Full-size cabinets
