Author Topic: MaLa v2.0 Beta 3 — User testing in progress  (Read 209453 times)
loadman
  • Online Online
  • Last login:Today at 05:04:51 pm
  • MaLa FE developer
    • MaLa
« on: July 22, 2026, 03:06:52 am »
MaLa v2.0 is nearing its first beta release, and I'm looking for a small group of genuine testers to help shake it out before a wider release.
What's changed: a full dev migration from Delphi 2007 to Delphi 12, running natively on Windows 10/11. Under the hood: rebuilt video engine, hardware handling, plugin system, and a long list of stability fixes — full rundown on the WIP page at malafe.net
What I'm after: this is a genuine test round, not an early download. If you're interested, DM me with:
What MaLa version you're currently running
Your basic cabinet/hardware setup — controls, LED/LCD boards, encoder, etc.
Whether you're able to pull debug logs and report issues back to me
Thanks for sticking with MaLa through the long development and webpage hiatus. The game is not over :-)
« Last Edit: October 17, 2026, 06:22:01 pm by loadman »
arquillos
  • Last login:Today at 09:17:56 am
Re: MaLa v2.0 Beta 1 — Testers wanted (soft target: early August)
« Reply #1 on: July 23, 2026, 09:09:36 am »
Hi loadman!
So glad you are working on a new version!
If nobody volunteer, I can try helping you (starting as early as Wednesday 5th August).
I can send you the cabinet details, it is a basic Core2Duo + Win 7.
  • Last login:Yesterday at 08:45:33 pm
« Reply #2 on: July 25, 2026, 09:21:06 pm »
Id be glad to test it.
darthpaul
  • Last login:October 17, 2026, 03:06:56 pm
  • Join, It's your duty
« Reply #3 on: August 26, 2026, 07:38:35 am »
This is great news, I never gave up on MaLa. I'm looking forward to updating when it is ready.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
TOK
  • Last login:Today at 05:34:40 am
  • The Game Always Wins
« Reply #4 on: September 16, 2026, 02:31:43 pm »
It has been a LONG time since I've posted. I decided to upgrade my vertical MAME cab from an 2ghz Athlon and Windows 2000(!) to a Ryzen 5000. This thing has been going for nearly 20 years on the same version of MaLa. My front end setup is really simple, with just a Favorites and Complete lists and a simple Space Invaders moon backdrop as the background.
I've updated my gameroom and pulled stuff out of storage, so I probably don't have the time required to do the Beta justice but I'm really looking forward to progress reports and release. Thanks so much for doing this!
Edit to add: Just saw my last post was 10 years ago, and that was about MaLa too! I never ended up fully updating the machine because it was basically working find and MaLa wouldn't work with what I was considering.
« Last Edit: September 16, 2026, 02:34:56 pm by TOK »
loadman
  • Online Online
  • MaLa FE developer
    • MaLa
« Reply #5 on: September 26, 2026, 01:57:56 am »
Quick update: Beta 1 is built, and I'm about to send it out to a first small batch of testers.
Starting small on purpose — a few cabs across different setups — so if something's badly wrong I hear about it before a lot of people have it installed.
I'll widen it out once they've had a decent go.
If you put your hand up and don't hear from me in this round, you're in the next one :-)
« Last Edit: October 01, 2026, 09:28:59 pm by loadman »
loadman
  • Online Online
  • MaLa FE developer
    • MaLa
« Reply #6 on: September 26, 2026, 02:01:53 am »
COOL.  :cheers:
loadman
  • Online Online
  • MaLa FE developer
    • MaLa
Re: MaLa v2.0 Beta 1 — Testers wanted (Beta Testing has started)
« Reply #7 on: October 01, 2026, 09:17:47 pm »
I have enough testers for now.  :-) . (Changed 18/10)
Thanks for all who have already done some beta testing of V2.0
   :applaud:  :cheers:
« Last Edit: October 17, 2026, 06:38:56 pm by loadman »
loadman
  • Online Online
  • MaLa FE developer
    • MaLa
Re: MaLa v2.0 Beta 1 — User testing in progress
« Reply #8 on: October 04, 2026, 11:23:13 pm »
For the testers:
As you know this initial V2.0 release is focused on stability but......
A few new things in the beta that are easy to miss, if you'd like to poke at them:
Look: Options → GUI → Display → Misc, tick "Use modern VCL Style" and pick one from the dropdown (needs a restart, Windows 10 or later).
Move MaLa anywhere: Options → Backup → Paths, "Make all paths relative". It backs up first, and you can undo it from the Backup tab.
Rotation: right-click → Change orientation, then pick 0°, 90°, 180° or 270° directly.
Plugins: Options → Event Plugins, where you can untick a plugin to disable it and see which events it supports.
GIFs: drop a GIF named after the ROM into your video folder and it plays as the game video.
https://malafe.net/wip
« Last Edit: October 04, 2026, 11:27:08 pm by loadman »
loadman
  • Online Online
  • MaLa FE developer
    • MaLa
Re: MaLa v2.0 Beta 3 — User testing in progress
« Reply #9 on: October 16, 2026, 07:42:19 pm »
Thanks again to all the testers,   :cheers:
Don't forget to check you are testing on the latest build.
We have found a few bugs and fixed them.  :applaud:
It was bound to happen as I changed a lot of the old MaLa engine.
I would now welcome a few more testers if you have the time
« Last Edit: October 18, 2026, 04:19:29 am by loadman »
