Author Topic: Escape from the lost world bally opto issue?  (Read 3236 times)
njay
  • To Nudge or Not to Nudge !
« on: August 31, 2009, 02:54:08 pm »
Hi All,
my bally is starting to act up again.
when starting the game sometimes it complains about 1 ball missing but it is in the correct lanes
when i gently push on the opto board or molex connectors it works again
when looking at the molex connectors it seems fine all the cables are correctly connected. can anyone help?
are the boards broken?
njay
Re: Escape from the lost world bally opto issue?
« Reply #1 on: August 31, 2009, 04:35:57 pm »
so i need to remove the two board and resolder them?
no problem !
will do so tommorow thanks for answering
njay
« Reply #2 on: September 02, 2009, 07:17:14 am »
well i think i resoldered the molex pins but it crappy work and my solder skills are not that good
what i also see is the molex connectors slide over the pin but are loosly you can easily slide them off
i placed a piece of cardboard between the two molex connecters this will give a little pressure to the connectors stay on so far after 12 games no problems but that did work before
