Looks awesome, I'm jealous!
What kind of paint did you use for the black and colors? How did you apply it (spray can, roller, HPLV)?
... I thought they would be a problem when I began to peel them off... but (even though they hold on tight) they come off clean... just be sure to wait till the paint is a wee bit tacky...
How long is a wee bit tacky? Do they need to be removed before the color is fully dry? IOW - is tacky the preferred time to remove them?
Thanks,
I used rustoleum gloss black... comes in 1 qt cans... applied with a foam roller.... thinned with acetone at about 2/3 acetone/paint mixture... should be very thin... but not so thin it runs down the cab before it dries... I did a total of 6 coats! its really quite remarkable how tough and brilliant it becomes.
The red and yellow are Krylon spray (can)...
As far as when to peel off the stencil... I followed the instructions provided with them... a "bit tacky" was that if I touched the paint with my finger... it would actually stick to my finger... but not "wet". I also painted the stencils with the cab laying down but peeled off the stencil with it standing up, for better leverage.
I was going to clear-coat the whole thing... but it looks to damn good and I'm afraid to screw it up.
