Author Topic: Should I make my arcade stick in the style of Mortal Kombat?  (Read 8268 times)
Arcade82
  • Last login:November 01, 2008, 06:40:56 pm
« on: January 22, 2007, 09:44:01 pm »
I could make an arcade stick for my 360 (and PC as well since it's USB) in the style of Mortal Kombat, with the exact same parts they used in those arcade machines...
or I could just make a generic one like with the 6 button Street Fighter layout (and an extra button to the bottom left)..
what do you think I should do?
If I made it Mortal Kombat style... would it be too awkward for all other games?
"Yeah... at least he built a cabinet. I can't wait to see yours. "
aahahahaa
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Should I make my arcade stick in the style of Mortal Kombat?
« Reply #1 on: January 22, 2007, 09:55:35 pm »
Make it work for whatever you want to use it for..... It's no good asking us what to do with this one. You have to make your choice based on what is comfortable for you to use.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
  • Last login:December 16, 2025, 04:07:15 pm
« Reply #2 on: January 22, 2007, 10:00:41 pm »
Best Regards,
Thats solid advice! If you want to play 4 way vertical games that only use 1 button - build a machine to play vertical 4 way games. You'll be much happier!
Arcade82
« Reply #3 on: January 23, 2007, 12:30:18 am »
cmon please no washout advice here..
I'm asking if it'll be awkward to place other games with it.
Is it a bad decision?
aahahahaa
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #4 on: January 23, 2007, 12:32:08 am »
yes...
you'd be using a non-standard layout to play a plethora of games with...
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #5 on: January 23, 2007, 07:53:53 am »
The standard street fighter 6 button layout (with an added 7th button for neo geo games) is a good layout for a lot of different games. The MK layout is less so. I'd go with the SF layout.
It's 9am. I'm calling it a nite.
crashwg
« Reply #6 on: January 23, 2007, 08:50:28 am »
I second that.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Glaine
  • Last login:April 24, 2013, 12:09:17 pm
« Reply #7 on: January 23, 2007, 09:53:01 am »
I'm not crazy for the MK layout either.
For anyone reading who doesn't know the difference, SF is 6 buttons, 3 on 2 rows like this:
While MK is like this (correct me if I'm wrong it's been a while):
Block is the middle button, the rest are punch and kick buttons.
It is actually a sort of neat idea, but I feel it doesn't work for very many games, where as 6 buttons on 2 rows works on most games, especially fighters.
If you also want to play neo-geo games, consider putting in another button on the SF layout, this has been talked to death and most people end up doing it. Like this:
() <- Extra button here so you have the 4 button neo-geo layout.
This setup is IMO the most flexible, the only downside is there are enough buttons that some guests will always ask what buttons they need to use for each game and the extra buttons get in the way of button masher games like track and field.
Crax
  • Hmm......maybe you should get that test still
  • Last login:March 12, 2022, 04:11:41 pm
« Reply #8 on: January 23, 2007, 10:09:23 am »
Yeah, that is the original MK layout without the run button.
fixedpigs
« Reply #9 on: January 23, 2007, 10:36:15 am »
that's what a led-wiz is for...-=)
as for buttons getting in the way...
it'd be neat if there was a way to make buttons that would be totally flat(kind of like the burners on the top of a flat stove...) with the control panel that would be touch sensitive...no extra buttons would get in the way then...
it'd be kind of like when you make up that first cp out of paper and cardboard and you try 'playing' different games by tapping the paper buttons...-=)
somunny
  • Is it hot in here?
« Reply #10 on: January 23, 2007, 10:52:26 am »
How about this layout?  Just shift the center row up halfway.
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #11 on: January 23, 2007, 11:36:09 am »
      (HP)         (HK)
              (blk)
      (LP)          (LK)
   (run)
« Last Edit: January 23, 2007, 11:37:42 am by kowal »
NiteWalker
« Reply #12 on: January 23, 2007, 11:42:46 am »
That layout's decent, but not as ergonomic as those found on candy cabs (most of em anyway). The layout above looks like it assumes you're hands are at a straight angle when playing, which isn't the natural position. It's more of an arc. See the pic for what I mean.
crashwg
« Reply #13 on: January 23, 2007, 12:00:10 pm »
Another good point.
My arms are usually at a 70-90° angle in relation to each other playing arcade games...
Lemme say it again
fjl
  • Pixels Rule!
« Reply #14 on: January 23, 2007, 12:37:07 pm »
An early mock up of angled buttons. What do you think?  :dunno
« Last Edit: January 23, 2007, 12:39:46 pm by efjayel »
ahofle
    • Arcade Ambience Project
« Reply #15 on: January 23, 2007, 12:43:42 pm »
The left set of buttons is angled the wrong way (try holding your hand in that position for a while).  They should look the same as the player 2 set of buttons or you will be very uncomfortble.
fixedpigs
« Reply #16 on: January 23, 2007, 12:48:44 pm »
ow...!
loser plays left side...-=)
fjl
  • Pixels Rule!
« Reply #17 on: January 23, 2007, 01:07:46 pm »
Well, I made it that way cause it should get the players to stand apart from each other like so...(not to scale)
Although this is my current layout...
Should I change it to have the angled buttons?
fixedpigs
« Reply #18 on: January 23, 2007, 01:33:04 pm »
i see...
but your sticks would need to be angled too then...
« Reply #19 on: January 23, 2007, 02:09:35 pm »
It's cool that your thinking about the angles of the players, but up needs to be up. Towards the monitor and not an odd angle.
fjl
  • Pixels Rule!
« Reply #20 on: January 23, 2007, 02:35:40 pm »
So leave it the way it is or change it like this...
Thing is that I don't have much CP space but I am persistent to not have a CP that sticks out from the sides. It must all fit within the walls of the side panels like on my picture. I have to since some of the doors around my house won't allow anything bigger than 28" to go through.
So i MUST restrict myself to 28" minus the side panels means my CP will be 26.5" wide.
« Last Edit: January 23, 2007, 02:48:38 pm by efjayel »
NiteWalker
« Reply #21 on: January 23, 2007, 04:00:37 pm »
I wouldn't sacrifice playability for aesthetics. If you need the control panel to be no wider than 28" because of being able to get through doors, why not build a separate control panel? There's no way playing on a control panel only 28" wide is going to be comfortable unless you and the other player weigh less than 80 pounds sopping wet. Angling the 1st player buttons downward like that places them in an unnatural position while playing.
fjl
  • Pixels Rule!
« Reply #22 on: January 23, 2007, 04:09:01 pm »
Well I'm obviously going to do the cardboard controls setup and see how it feels. But I'll probably just stick to all buttons and controls being perpendicular to the screen.  :dizzy:
NiteWalker
« Reply #23 on: January 23, 2007, 04:11:41 pm »
That would probably be your best bet. You can get a little extra space out of the cp by moving the 1st player joystick and the second player buttons towards the outside a bit more also.
fjl
  • Pixels Rule!
« Reply #24 on: January 23, 2007, 04:48:34 pm »
Well I'm trying to keep them away from the T'molding cause if you rest your hand on the t-molding it might end up being uncomfortable. Although, from my test tries, it seems that your arm never really rests on the panel, just the side of your palms. Of course I tried it on a table that wasn't really to scale, height wise. Do you find yourself resting any part of your arms on the CP or just your palms?
NiteWalker
« Reply #25 on: January 23, 2007, 04:52:53 pm »
Just my palms really. Maybe a bit on the left hand on the side as you mentioned, but only on the joystick side. I don't think it'll be a big issue.
Arcade82
« Reply #26 on: January 23, 2007, 08:47:26 pm »
You're right it is probably the best arcade setup. Definately what I'm going to do on my personal arcade machine.
This one I mean
Probably not going to do any slant or stagger though.. does anyone have a slant or stagger?
aahahahaa
Arcade82
« Reply #27 on: January 23, 2007, 08:49:20 pm »
Weird that you post this! This is probably what I'm going to go with as far as a CP on my arcade machine. Not sure about the trackball. How much can you get a decent trackball for nowdays?
aahahahaa
Arcade82
« Reply #28 on: January 23, 2007, 08:51:09 pm »
Anyway, as far as an actual upright cabinet, I don't think there is any question that the standard 6 button street fighter layout with the NeoGeo button is the best layout
as far as my home/360 arcade stick, I'm surprised I didn't think of it before but I'll just make two top panels, one in each formation.
I just hope that removing it won't screw the solder joints up too much. Or maybe I should use quick disconnects huh?
aahahahaa
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #29 on: January 23, 2007, 09:33:37 pm »
I always thought the MK layout sucked even for MK! Only giants with big hands could use it effectively.
NO MORE!!
NiteWalker
« Reply #30 on: January 23, 2007, 09:39:25 pm »
The MK layout does suck....badly. :censored:
@Arcade82: There's a lot of ways around that problem. The simplest would be molex connectors. Wire them from your PCB to a male connector and run wires from the control panels to female molex connectors. When you want to change control panels, just disconnect the molexes and reattach the other panel.
Simple as pie, but not as tasty.  :laugh2:....er.... :dunno.... :troll:
Unholyknight
  • Last login:August 29, 2020, 12:10:39 am
    • Unholyknight
« Reply #31 on: January 23, 2007, 09:40:28 pm »
The MK layout is definitely unique to the Mortal Kombat genre.  I would stick with the 6 or 8 button 2-row style layout for the broadest compatibility.
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #32 on: January 23, 2007, 11:28:17 pm »
Here's my $0.02.  Don't do MK setup unless you really, really, REALLY like it.  *I* would not have the players & buttons at an an angle and not include angleling the sticks.
fjl
  • Pixels Rule!
« Reply #33 on: January 24, 2007, 12:15:05 am »
Okay I drew them on a card board and tried both. Doesn't really feel good to play at an angle. But it also doesn't feel good to play the buttons perpendicular.
For now I've kind of settled on this button layout seeing as how the buttons will be so close to the joystick, the right hand will have to be at an angle towards the joystick. That makes less strain on the right arm and wrist. Comments?  :blah:
« Last Edit: January 24, 2007, 12:18:12 am by efjayel »
fixedpigs
« Reply #34 on: January 24, 2007, 12:18:51 am »
now you're getting it...!
NiteWalker
« Reply #35 on: January 24, 2007, 02:59:39 am »
Much better. That really looks good now. I'm sure whoever plays on it will have no complaints.
fjl
  • Pixels Rule!
« Reply #36 on: January 24, 2007, 06:30:00 am »
I was just going through the "show your control panel" thread and noticed that a lot of people have the button layout straight and close to their joystick. Perhaps even closer than my setup. And only a few that had it close to the joystick would angle the pattern. I wonder those who didn't angle it, get to play it without any problem. I'll perhaps also add a small curve to the button layout.
NiteWalker
« Reply #37 on: January 24, 2007, 06:34:44 am »
FWIW My personal use stick has the straight 6 layout and I've had no issues with the angle at all. That particular layout was on street fighter machines for years and everyone adapted to it just fine. When I make my sticks the joystick is 4" from the left buttons on center. It's a great overall layout.
fixedpigs
« Reply #38 on: January 24, 2007, 10:52:33 am »
obviously not...!
look at how much your hands bleed by using it... :dizzy: :P
NiteWalker
« Reply #39 on: January 24, 2007, 10:58:22 am »
obviously not...!
 :laugh2: :laugh2: :laugh2:
I had only red buttons at the time in the convex style so I just pretty much picked the art blindfolded. It worked out ok. Next time I'll spend more time on the art than 10 min... :lame:
