Author Topic: only one joystick works w/ ipac  (Read 3785 times)
machinehead01
  • Newbie
  • Last login:Never
« on: March 30, 2002, 03:44:17 pm »
I have a control panel, ipac  two joysticks and three buttons on each side, both joysticks work in test mode, they both have different charactars in note pad but only one joystick and 3 buttons on one side of panel works for player one and player two,I have ipac jumper set to mame and jumper set to ps2 dont quite understand ipac utilitie progam or dont know if it is for a control panel useing mame 059b, any easy fix?
aramis
  • Last login:November 26, 2002, 09:24:04 pm
  • mame cab ALMOST done!
Re: only one joystick works w/ ipac
« Reply #1 on: March 30, 2002, 03:49:26 pm »
The Ipac should work great w/ the jumper set to MAME. Open up Notepad, and verify that you see these keys as the joystick/buttons are pressed as shown:
Joy2 Right:  G
Joy2 Left:    D
Joy2 Up:      R
Joy2 Down: F
Plyr2 Button1: A
Plyr2 Button2: S
Plyr2 Button3: Q
If you don't see these responses in Notepad, then you have it wired wrong. If you don't see ANYTHING in Notepad, check your ground wiring.
You should only have to use the utility program if you want to change the default "MAME" setup. In most cases, you don't have to do this.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 10:55:05 pm
« Reply #2 on: March 30, 2002, 04:02:37 pm »
I think you are playing a SINGLE Control Panel game ie:Pacman. Mspacman etc... This type of game are alternating games, which uses only 1 joystick for both player 1 and 2. When player 1 dies, then its players 2 turn using the same joysticks and buttons...
Free VGA Breakout Cable
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #3 on: March 30, 2002, 08:35:36 pm »
Try a game like Metal Slug that uses all three buttons and both joysticks.  See if that works, because if there is an input in Notepad for player 2, then Thenasty is right, and that means you're playing games that only has one joystick as the input.
 -good luck
   -CthulhuLuke
