Author Topic: Yet Another Jukebox Program  (Read 287804 times)
mado21
  • Last login:March 04, 2016, 06:07:11 pm
Re: Yet Another Jukebox Program
« Reply #160 on: February 16, 2005, 04:23:40 pm »
hi sk
i did a you said but still geting the error it works fine on my other comp driveing my crazy
 mado21
SalmonKing
  • Moderator
  • Last login:August 16, 2007, 10:45:44 am
  • SK Jukebox
« Reply #161 on: February 16, 2005, 04:39:00 pm »
hi sk
 mado21
I have updated the installer using a different program.
Uninstall what you have done already.
http://www.pleasuredome.org.uk/~salmonking/  <- This link is always the most up-to-date
Download both the VB6 runtimes AND installer (so, 3rd & 1st link).  Run them in that order (I'm assuming you ran the installer in the first place, and didn't just use what was in the update file).  It should be that simple!
Let me know if you still have problems.
SK.
mado21
« Reply #162 on: February 16, 2005, 07:39:35 pm »
hi sk thanks for your reply but still no luck the only thing i can think of is on the comp that works i have a ATI card and on the one that doesn't i have a nvidia card maybe somethink to do with the drivers ?. also when i run the vb runtime installer i get a msg saying "do i want to install " i click yes then a window opens that says copying files then it closes and thats all nothing to say that it installed ok?.just wondering if that was right  or arnt the vb runtimes installing properly
 mado21
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #163 on: February 17, 2005, 01:37:45 am »
 mado21
Very, very strange.  Tell you what, download this file :
http://www.pleasuredome.org.uk/~salmonking/updates/SKJukeboxDebug_v206.zip
Extract it to the directory you have SK Jukebox installed to, then run the program.  That SHOULD tell me exactly where the program is failing.  Just let me know the exact error message, and it should give me a clue. *fingers crossed!*
SK.
mllkat
  • Last login:August 03, 2016, 05:03:18 pm
  • When all else fails, you're about average.
« Reply #164 on: February 17, 2005, 04:10:13 pm »
I have read alot of good reviews of your Jukebox program and decided to try it out. Unfortunately I am having a problem with an error message.
I am sure it is just a configuration problem on my end but any assistance would be appreciated.
Mllkat
Have both of you just downloaded the program for the first time?
mado21
« Reply #165 on: February 18, 2005, 02:47:13 pm »
hi SK
thanks for your reply i download the file and this is the error msg i got
the top box appeared first then a few seconds later the  2nd one popped up
i hope this helps
mado21
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #166 on: February 18, 2005, 05:38:30 pm »
hi SK
i hope this helps
mado21
It does help, but I'm not exactly sure what to think.  At that point, it is creating the connection to MsgHook.dll.  I guess the first thing to try is search your PC for any copy of that file that might be causing a conflict.  An older version might be causing problems.  The current installer will have that file in the same directory as the executable.
The 2nd thing to try is to manually register that DLL by clicking Start -> Run, then put in there :
regsvr32 (path-to-skjb)\MsgHook.dll
Manually registering it should work, but it's still a mystery as to why it isn't registering in the install.
SK.
mado21
« Reply #167 on: February 18, 2005, 07:33:39 pm »
hi SK
 success! i followed your instructions but it would not find the path. so then i tried to do it  from a dos prompt and it worked. the only thing i can think of is ive got 2 user accounts on this computer  that didnt work (they are both admin accounts),but only one on the the computer that did .again many thanks for all your help and what a great program.
mado21
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #168 on: February 18, 2005, 10:20:20 pm »
hi SK
mado21
Excellent, enjoy!   :D
olsteve
  • Last login:March 24, 2012, 10:33:35 pm
  • To play or not to play, that is a stupid question.
« Reply #169 on: February 23, 2005, 10:58:56 pm »
SK- Love the software
One problem I am having that others may have also is with the file system. I have all of my .MP3's in one directory and have them tagged with ID3 tags (X:Music\xsong.mp3). I don't have them in album folders...(X:Music\xalbum\xsong). Is there any way that I can use the ID3 tags to sort into albums or artist. I have a fairly large collection and I don't want to have to go through and sort everything into its own album folder. Right now I just get the first 99 tracks of my X:music folder. Other than that your software does everything I would want in a juke program.
Why is it when we talk to God we are praying, but when God talks to us we are put into the loony bin?
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
« Reply #170 on: February 24, 2005, 02:40:59 am »
Best program i've used yet. Thanks, it works perfect for my needs, great job. :)
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #171 on: February 24, 2005, 02:56:30 am »
You could try Tag&Rename.  That program certainly gets a huge workout on my PC, and there should be an option in there to help you with this.
http://www.softpointer.com/tr.htm
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #172 on: February 27, 2005, 12:30:40 pm »
I installed 2.06 and it looks like it wiped out all my configuration files. kindof aggravating.
papaschtroumpf
  • Have a Cow!
« Reply #173 on: February 27, 2005, 12:49:34 pm »
I understand that this is not a very general urpose request, but I would love to see a way to display a custom "instruction card" picture: since I use SK jukebox on an aracde cabinet,  the controls are not especially obvious.
Ideally the "pause" key would bring up the picture, this way this would match the panel viewer that buddabing added to MAME. Another way to do it would be to show it instead of/in alternance with the track list (maybe move the track list as scrolling text below the song progress if we loos that area?)
I'll still use SK Jukebox without that feature, but it never hurts to ask.
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #174 on: February 27, 2005, 04:36:47 pm »
If you used the Uninstall feature, then this could have happened.
I have recently changed from the MS installer to a new system, and I have TOTAL control over what is installed / uninstalled.  The .ini file is NOT included in the new uninstall, so it won't happen again.   ;)
papaschtroumpf
  • Have a Cow!
« Reply #175 on: February 27, 2005, 08:45:23 pm »
cool. not that big a deal, just a minor annoyance, and since I'm still tuning the system I didn't have backups of the SK folder yet.
HoopstarsGarage
  • Scratch Building Demi-God!
  • Last login:April 19, 2016, 09:24:11 pm
  • Scratch Building Demi-God..
    • Hoopstars Garage
« Reply #176 on: February 28, 2005, 11:01:23 pm »
As everyone else has duely noted, this is an awesome program..
Only two things I could add that would/could make this better is the following:
- allow a song to be picked using only the cursor keys and enter.  Ie. use left/right arrow to select the page album required is on, then use up/down arrow to select from the four albums on that page.  Select desired album using enter key and then album goes "full screen".  Select song using up/down arrows and enter to select song.
- start up with "random" song active - selectable of course.
again.. great program.
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #177 on: March 01, 2005, 03:35:08 am »
Thanks for the feedback!
Point 2 is a good one, so I'll add it to the list.  The amount of times I load up the program only to hit 'R' is uncountable   :D
Point 1 is the tricky one.  It has been brought up before, and is by no means easy.  In fact, I'll go so far to say that it will never happen.  The way the program is already coded would make this a nightmare to add.  Sorry to say, but I just don't see a way of adding this in!  I'll add it to the 'Long Term' list, but that could mean I won't look at it till next year.  :'(  As with every other suggestion / request, I'll certainly have another look at it, but don't hold your breath!!
Cheers,
SK.
HoopstarsGarage
    • Hoopstars Garage
« Reply #178 on: March 01, 2005, 04:22:15 am »
1 out of 2.. I can live with that  ;D
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #179 on: March 03, 2005, 09:02:22 pm »
Version 2.1.0 released.
This version adds an option to allow more than 99 songs per album   :D
Check the Version History for a few more tasty morsels   ;)
Chris
    • Chris's MAME Cabinet
« Reply #180 on: March 04, 2005, 12:45:52 pm »
--Chris
Dermbrian
  • Last login:January 19, 2024, 05:05:16 pm
« Reply #181 on: March 04, 2005, 02:41:49 pm »
Was that actually a requested feature?  What kind of album has over 99 songs on it, other than something like a sound effects CD?
Compilations that people create for themselves, mainly.
In my case, recordings of our church choirs collected over several years, would qualify.
I think the original train of thought was things like collecting hits from a given decade and putting them in one folder....thus one 'album'.  Since SK Jukebox doesn't use ID3 tags, the word 'album' is open to interpretation.
Brian
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #182 on: March 04, 2005, 04:35:31 pm »
Exactly my response to the 5 or 6 people who have brought it up!  ;)
I held off doing it for a long time, but decided that I don't like placing limitations on the software if I don't have to.  Of course, sometimes these limitations are required for time / reasonability / etc, and this one DID take a bit of work to get around.
In the end, if it can reduce the e-mails I get that start 'Hey, love the program, but...', that's a good thing   ;D
SK.
papaschtroumpf
  • Have a Cow!
« Reply #183 on: March 05, 2005, 12:01:43 pm »
So if we want a feature we should start spamming you? j/k  ;D
bauhaus
  • Last login:August 08, 2006, 01:35:23 pm
« Reply #184 on: March 18, 2005, 04:25:47 am »
mflint
  • Last login:March 01, 2014, 08:47:03 am
  • Shocking
« Reply #185 on: March 18, 2005, 11:14:49 am »
Whats the chances you could add an adjustable equalizer.
And just another note-When volume is set below 100% and the program is shut down and restarted with songs in the Que  you have to hit the end button to equal out the balance, I thought maybe it was just my machine that caused this, But I put it on a brand new machine with windows xp fresh out of the box and it does the same thing on that machine too.Still the best program I have found yet. Thanks Salmon-King its the greatest.
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
« Reply #186 on: March 19, 2005, 10:12:54 am »
WOW! an awesome program kudos to you! (and as soon as I have some $ in Paypal a donation will be coming to you also).
It has already replace VMJ in my jukebox since it does all the stuff I have wanted VMJ to do for a while (multiple genres selected easily, integrated screensaver, easier music management, etc etc).
I do have a couple of quirks I have discovered...
First when booting it will be in an empty genre (just four "no cover" pictures) and then if I hit genre and try to select the first one in the list it will just stay in the empty one.  If I switch to a different genre and then switch back it works fine then.
Secondly and not that important - If I exit and come back and it continues playing the song its fine - but when I enter a genre (Ie using the above method) it drops the left audio channel for the duration of the current song.  You can just skip it and everything is fine.
Thanks again for the awesome program!
Space Warped by Someone
Dermbrian
« Reply #187 on: March 19, 2005, 02:54:55 pm »
How about changing this thread to
"One Of The Best Jukebox Programs"
BTW, I say 'one of the best' because all programs made available by members here are just great.
Brian
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #188 on: March 19, 2005, 07:33:26 pm »
I'll add the equalizer to the 'to look at list'   ;)
I noticed something strange with the balance a while back, but it didn't come up again so just took it as a one off quirk.  I'll check it out.....
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #189 on: March 19, 2005, 07:37:07 pm »
Thanks to you as well for the feedback!   :D
If you are using genres, it should be displaying the genre list automatically when the program starts.  There should be no need for hitting the genre key to get it initially.  Perhaps I messed something up with it recently, I'll check it out.
As per the post just before yours, I had that happen to me once, so I'll check that out again too.
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #190 on: March 19, 2005, 07:38:16 pm »
Hi
Well Done.....  ;D
What about scrolling title if it's too long  :laugh:
Bauhaus
Do you mean in the area that is displaying the currently playing track?
SalmonKing
  • Moderator
  • SK Jukebox
« Reply #191 on: March 19, 2005, 08:19:08 pm »
Just a note : I only just realised that the Update link on the site was still pointing to the old version!   :-[
The page is updated now for anyone who wants to download the update to 2.1.0
bauhaus
clonestar
  • Last login:March 09, 2009, 04:00:53 pm
  • Thunderbirds are puppets!
« Reply #193 on: March 25, 2005, 04:33:57 pm »
2 & 3)
clonestar
« Reply #194 on: March 25, 2005, 06:38:21 pm »
Ok I just added SKJB to my stand alone juke and it is AWESOME, a term much over-used on this forum but in this case totally applicable.
I also had a funny quirk with the balance, this only occurred on the first track played (went if I skipped to the next title) and was drastic enough that it was tripping the cut out on my sub amps, weird huh?
Massive improvement over VMJ, why did I want a skin with lots of chrome? My cabinet has that and the clean lines of this prog set it off perfectly.
Still would love an equaliser and mpeg support but it is GREAT, thanks again.
redcoats
  • Last login:March 15, 2015, 04:04:56 pm
« Reply #195 on: March 26, 2005, 04:07:32 am »
I got a question? Is there a way to choose a whole album instead of individual songs?
clonestar
« Reply #196 on: March 26, 2005, 06:31:43 am »
Yep, enter 00 for the track number, as long as this is turned on in options
redcoats
« Reply #197 on: March 26, 2005, 07:49:32 am »
Sweet. Thanks for the help.
redcoats
« Reply #198 on: March 27, 2005, 03:12:56 am »
Is your program eventually gonna have video support? I can't complain about it since it is free, just thought adding video would be pretty awesome. I own virtual music jukebox but I don't think it is as good as your program. I don't like how they only give you three keys for it when you pay for it. I bought it I should be able to put it on every computer I own. I own 3 PC's and I'm not about to shell out more money to put it on the other two PC's. It is also buggy as hell. Anyone reading this thread and is wanting to get a jukebox program, save your money and go with this one. :) Also one more request? I'm sure you have heard this a hundred times, are you gonna make this skinable? Thanks for the awesome program. We need more guys like you around here 8)
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #199 on: March 28, 2005, 10:17:10 am »
SK stated previously that Video support was on the list, but it would take awhile.
I have the option checked to not show 00, but make it work anyway, and it doesn't work for me.
any ideas why?
Art
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
