Author Topic: What am I missing with wiring this minipac?  (Read 1636 times)
Guywiththegun
  • Last login:February 17, 2020, 12:00:21 pm
« on: April 29, 2016, 10:14:36 am »
So I'm following the instructions, daisy-chaining the ground wires, and then connecting the wires to the individual buttons. They're kind of a pain to get on sometimes, but I felt like everything was pretty secure. I fired it up and most buttons worked, but I was having issues with LEFT and the 6th button ("High Kick"  ;D) not working. Everything seemed to be connected, but I tried just forcing the wiring in a little more, wiggling around etc. Left came back on, but dropped out again, and came back on. Still nothing for the button, so I switched wires and got it working. Then the 2nd button stopped (though I'm not sure if I just never noticed it not being on at all). Kind of frustrating to wonder if down the line these things are gonna start randomly dropping out.
At this point I kind of want to disconnect everything not working and start again but some (ground wire on LEFT especially) are near impossible to get off.
Is there a trick to all this?
« Last Edit: April 29, 2016, 10:16:11 am by Guywiththegun »
Thenasty
  • Trade Count: (+17)
  • Last login:February 03, 2026, 08:27:56 pm
Re: What am I missing with wiring this minipac?
« Reply #1 on: April 29, 2016, 10:54:32 am »
make sure that the wires are connected to "NO" on each of the Cherry switches.
Free VGA Breakout Cable
Guywiththegun
« Reply #2 on: April 29, 2016, 10:58:10 am »
They definitely are. I made sure of it.
UEDan
  • Last login:November 10, 2019, 05:54:08 am
« Reply #3 on: May 02, 2016, 11:38:45 am »
Do you have a multi-meter to check the connections?
Check connections:
ipac to button connector.
ipac to microswitch tab
If it's ground wire, check the tabs from ipac and previous button.
