Author Topic: DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)  (Read 1906860 times)
0 Members and 13 Guests are viewing this topic.
DMB77
  • Last login:October 22, 2025, 07:33:25 pm
Re: DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)
« Reply #3640 on: October 22, 2025, 07:33:25 pm »
Thanks for the update Aragon, MIB is Sooo much better without the guns. Everything is working however I can't aim all the way to right side of the screen.  I didn't change any of the setting in the BepInEx folder, and my desktop resolution is 1080x1920.  Any Ideas on how to fix this?  The game works fine on teknoparrot but I can't use the no crosshairs/gun with TP.
Fate flies in fear of the moment
petran79
  • Last login:November 04, 2025, 11:59:04 am
« Reply #3641 on: November 03, 2025, 12:25:36 pm »
What is the argument for Chihiro version of house of the dead 3 to work via cxbx ds 1.0?
when I enter demulshooter.exe -target=chihiro -rom=hod3
cxbxr-ldr.exe does not register the mouse cursor in game. No issues in launching and shooting in Virtua Cop 3 if I enter rom=vcop3
Do I need to type something different than hod3?
PC version has issues as arcademod launcher does not work in Windows 11 unfortunately. I have to set compatibility to Win7
« Last Edit: November 03, 2025, 12:35:38 pm by petran79 »
argonlefou
  • Last login:Today at 02:56:11 am
« Reply #3642 on: November 03, 2025, 05:33:40 pm »
You have the correct command line for chihiro DS build, as you can see here
I have not used it for a long time, I don't exactly remember if there was some issues with build version / rom version to get it to work
I keep using the pc mod instead
As I just replied on your Github ticket, I use both hod3pc and the mod on a windows 11 computer without any trouble
petran79
« Reply #3643 on: November 04, 2025, 10:43:42 am »
I managed to register light gun and it could shoot but cxbx crashed immediately in the first stage.
Tried it again by disabling bezels, exclusive full screen and shaders and it run without crashes even to stage 3. Unfortunately even on a modern cpu (i5 245k in my case), emulation has slowdowns. While VC3 runs smooth.
Only difference are the better textures and vfx. Eg in the Fool boss encounter, you can clearly see the faces of the corpses falling. While on PC even at 1920x1440, those textures were a mess.
So PC version remains the best option till they improve.
Yes, issue was with not copying the patched hot3 exe to exe folder and had it in root folder instead. Now it seems to run
« Last Edit: November 04, 2025, 11:59:04 am by petran79 »
argonlefou
« Reply #3644 on: November 04, 2025, 07:07:46 pm »
Glad to hear that you managed to make it work.
And yes, Chihiro hod3 on Cxbx is not what I'd call "fully playable" state... Unfortunatelly.
Even VC3 has some texture issues, mainly the usual "Virtua Cop Circles" surrounding the enemies are not showing on cxbx.
Xemu is rendering them without any issue, but I don't think it's lightgun friendly
Jayinem
  • Last login:December 14, 2025, 09:04:21 pm
« Reply #3645 on: November 20, 2025, 06:37:34 pm »
Argon I usually use Teknoparrot for those specific light gun games but I can't get controls to work at all for one game, Point Blank X. So I'm using Demulshooter but 5 is not working to enter coins? 1 is working for start it says coin error. I am also unable to get into any test menus. I did copy the content of Point Blank X to where the .exe is, but I'm confused about your instructions
Edit the newly copied Setting.ini file (located in PBX100-2-NA-MPR0-A63_Data\ subdirectory of the game) to your needs. Available options and values are written in the ini file.
I don't really know how to edit that .ini? It looks like this
CONTROLLER 1 # 0=BNUsio 1=Simulated
GUNPORT 3 # COM port for Gun board
TICKET 0 # 0=Disabled, 1=Enabled
MAIN_PATH ./NVRAM/ # Main save location
BACKUP_PATH ./NVRAM/ # Backup save location
LANGUAGE en-US, ja-JP,zh-CN,ko-KR,es-ES,pt-BR,th-TH,ru-RU,id-ID # language at the first is default
I don't know how to change anything in this can you help?
Edit: I realize now backspace is test menu and I was able to disable coins, however it seems demulshooter is not hooking because it's red and my wiimote doesn't seem calibrated. I copied all of the files of Demulshooter 16.2 and put them where the .exe is and here is my script
Run, DemulShooter.exe -target=es4 -rom=pblankx
run, PBX100-2-NA-MPR0-A63.exe
I tried running Demulshooter.exe as administrator but Demulshooter is still red not green?
Edit 2: Now that I figured out how to disable coins in test menu the game is fully working in Teknoparrot.
« Last Edit: November 20, 2025, 07:09:50 pm by Jayinem »
argonlefou
« Reply #3646 on: November 21, 2025, 10:00:57 am »
This is a simple text file, just change whatever setting you need to be changed
What's after the '#' signs are comments, so just change the setting before like
Code: [Select]
LANGUAGE es-ES,en-US, ja-JP,zh-CN,ko-KR,pt-BR,th-TH,ru-RU,id-IDif you want Spanish laguage by default
Backspace key was listed in the game wiki page
As for DS not hooking the game,  it can be many things but a demulshooter log would be a good starting point to see if something obviopus is going on
And, as I usually said, trying to get things running directly without using AHK scripts or BAT or frontend is also a good starting point as those scripts/tools can add a layer of possible errors....
Jayinem
« Reply #3647 on: November 24, 2025, 02:04:41 pm »
Not a Demulshooter issue per say but Police Trainer 2 is broken in newer versions of Teknoparrot it throws an error and won't boot. I've been searching for a Teknoparrot emulator version that is about 6 months to a year old but can't find any on google the only one on the official website is actually too old Police Trainer 2 isn't even in the list of games it's from 2023. Does anyone happen to have a Teknoparrot this old that's not updated that you could upload somewhere?
« Last Edit: November 24, 2025, 02:06:59 pm by Jayinem »
Jayinem
« Reply #3648 on: November 29, 2025, 11:07:47 pm »
On Chihiro_DS 1.0 Virtua Cop 3 works okay and Ghost Squad appeared to the graphics were perfect in the menus and I could shoot with my Wiimote but as soon as I get into actual gameplay the characters are all black and I can't shoot them?
dgrace
  • Last login:January 23, 2026, 11:02:43 pm
« Reply #3649 on: January 01, 2026, 05:59:44 pm »
Hi Argon, I just tested v17.1 and for some reason my p1 Alien gun is not being recognized in the GUI (the device drag down). Only my p2 gun is recognized. Same with version 17.0. However, both my p1 and p2 alien mounted analog guns are being recognized in v16.4 GUI and before. So I assume there is some kind of bug in the latest version, or maybe i'm doing something wrong. Thanks in advance.
Update: It’s not a p1 vs p2 issue. It appears the GUI will only recognize one alien gun at a time. When both are plugged in, only one is recognized in the device drop down list.
« Last Edit: January 04, 2026, 11:25:10 am by dgrace »
argonlefou
« Reply #3650 on: January 11, 2026, 03:33:36 am »
Hi
Indeed, I was asked to make some changes on how guns ID are saved in the config file.
People tested a lot of guns to assure me  that it would have no impact.
But they didn't test with aliens gun and murphy's law did the rest.
See here : https://github.com/argonlefou/DemulShooter/issues/352
I think I'll need to rollback to the older way...
I'm aware of the issue, I just need to think a alittle before adressing it
Ginsonic
  • Last login:January 12, 2026, 06:48:01 am
  • Arcade enthusiast !
« Reply #3651 on: January 11, 2026, 04:14:07 am »
Hir Argon,
Flycast 2.6 is released, maybe, if you will have some spare time, you could update DS. Many thanks!
TapeWormInYourGut
  • Last login:January 24, 2026, 09:43:12 am
« Reply #3652 on: January 11, 2026, 03:06:21 pm »
Ahhhh. I have several GUN4IR lightguns that have the same PIDs because its firmware only supports up to 4 unique available values. I haven't upgraded to the latest Demulshooter, but if I do and happen to use the two guns with the same PID then that is another scenario where this come up :(. Just another call out if you need more reasons to revert it  ;)
I use a tool that sets the DS config for me prior to launching a game, so I suppose it wouldn't be an issue for me personally if DS still supports the fully qualified paths when it's manually set.
Edit: I don't have a github account to respond in that thread, but maybe a fix could be to use devices if their full ID is found, and then for any device which isn't found, you'd try searching using the short path? Saving would still use the full path, and then portability will work using the fallback search logic? No need to continue that conversation here, but is just another thought. That may only work when running games though versus configuring in the UI.
« Last Edit: January 11, 2026, 03:19:21 pm by TapeWormInYourGut »
argonlefou
« Reply #3653 on: January 12, 2026, 05:52:38 am »
Hir Argon,
thanks, just added it to v17.2 update  on github
Be assured that I did not need any more reason to revert it.....mostly the over way around : I was sent a lot of debug data before accepting the change, hoping this would not be kind of safe, but it wasn't
So I just changed it back to the old way in the v17.2 update
Starting to run some advanced looking functions, mixing both short and long names according to the computer is the best way to mess with a lot of things.
I'd rather keep a clear, unique way which has the advantage of giving clear information when things are not working.
Stability and compatibility if way more important to me than easy portability or other special-setup specific changes.
Ginsonic
« Reply #3654 on: January 12, 2026, 06:48:57 am »
Thanks a lot  :applaud:
dgrace
« Reply #3655 on: January 16, 2026, 12:41:49 am »
Hi
v17.2 resolved the issue. Thanks Argon!
