Author Topic: TurboTwist 2 Spinner Powers On Computer  (Read 1129 times)
Yardley
  • Last login:July 22, 2025, 11:36:15 pm
« on: October 28, 2015, 11:13:09 pm »
Strange issue I've been letting go for too long, my TurboTwist 2 Spinner literally turns on my PC. You read correctly,  computer is off and if I touch the spinner it will turn on, it is very sensitive and will happen even if I move my bartop (PC inside). I checked BIOS options and disabled any "allow mouse to wake computer" type settings. Any ideas?
Typefighter01
  • Last login:September 11, 2024, 09:13:06 pm
  • Back I guess...
Re: TurboTwist 2 Spinner Powers On Computer
« Reply #1 on: October 29, 2015, 07:55:36 am »
I believe there is options in Windows itself that can control this, not just the BIOS. Quick Google brings up this option to check:
Here's the option you need in Win 7
 Start -> Control Panel
 Click Mouse
 Select Hardware tab
 Click Properties
 Click Change Settings
 Select Power Management tab
 Select or Unselect "Allow this device to wake the computer"
Also, if that doesn't work, just keep Googling "Allow this device to wake computer (insert OS here)", seems to be quite a few hits for it.
EDIT: ---steaming pile of meadow muffin---...just noticed I Googled "wake", not "power", sorry.
This should work better...try this: http://www.pcadvisor.co.uk/how-to/desktop-pc/how-stop-mouse-movement-starting-up-your-pc-3333164/
eds1275
  • Last login:Yesterday at 11:32:44 am
  • Rock and Roll!
« Reply #2 on: October 29, 2015, 08:34:34 am »
Any tricks for setting Usb ports to not supply power when off? I have. a Usb light that I want off when the computer is off.
Yardley
« Reply #3 on: October 29, 2015, 08:47:26 pm »
 Click Mouse
 Select Hardware tab
 Click Properties
Finally figured it out! Ended up being some obscure setting in the BIOS. Deep sleep had to be enabled. Ugh, glad that's over.
