Author Topic: Totally Radical Arcade  (Read 31733 times)
Jimbo
    • Wood Finishes Direct
Re: Thinking Ghostbusters or 80s Theme
« Reply #40 on: November 24, 2014, 04:01:01 am »
Holy sh*t!  Is that guy standing above *actually* Bruce Lee?   :laugh2:
brucelee00
  • Last login:December 13, 2020, 05:16:36 pm
« Reply #41 on: January 06, 2015, 11:37:38 pm »
Did some rethinking on what I want to do with the cab design... I like the shape of the stern cab specifically the top half and like the shape of Williams cabs and really like how the Echo cab out and with the suggestions that were made I have come up with this. It's not officially done and still need to modify some things. Leaning towards an 80s neonish design, without getting too loud with the artwork... Threw together a quick mock up marquee and is in no means the final version just a place holder. As usual any and all suggestions are welcome. Happy New Year Everyone!
« Last Edit: January 06, 2015, 11:56:25 pm by brucelee00 »
  • Last login:Yesterday at 07:06:30 pm
« Reply #42 on: January 06, 2015, 11:43:26 pm »
Getting much better, my friend.  :cheers:
brucelee00
« Reply #43 on: January 06, 2015, 11:59:09 pm »
Thank you! I know it's not using a CRT which may change, or may use the new 4:3 led monitor that's coming out depending on cost.  :cheers:
« Reply #44 on: January 07, 2015, 12:18:18 am »
Agreed. CP is MUCH better.
brucelee00
Re: Rad Kade 80s Neon Theme
« Reply #45 on: February 05, 2015, 10:19:29 pm »
I've done a little more work on refining the design in SketchUp still may need a few adjustments, but would like some feedback on the two designs I've narrowed it down to. The first allows me to play light gun games, but limits the play slightly of trackball games like golden T which I like. The more vertical monitor orientation also puts it at higher viewing angle. In the second option not sure if the angle is too steep for light gun games, but it lends it self better to golden T and other trackball games that require a little more forward thrust. I used about the same angle used for the monitor as in Mortal Kombat cabs so it's not very steep. Additionally, the second option allowed me more design variation with the speaker area. Would like feed back if the angled view is the way to go in terms of both standing and sitting play along with other concerns mentioned. Thanks Everyone!  :)
Generic Eric
« Reply #46 on: February 05, 2015, 10:27:55 pm »
Neat.
What are these circles in the back?
« Last Edit: February 05, 2015, 10:29:27 pm by Generic Eric »
brucelee00
« Reply #47 on: February 05, 2015, 10:31:07 pm »
@Generic Eric those will be where the fans will go  :)
Generic Eric
« Reply #48 on: February 05, 2015, 10:34:42 pm »
Thanks.
matsadona
« Reply #49 on: February 06, 2015, 02:49:00 am »
There is some odd behavior I never can understand, and that is adding a big X-arcade style box that totally ruin the overall esthetics.
Yes, beauty is in the eye of the beholder and everybody has his own personal taste. But still, why ruin a nice design by doing that?
The only cabinet in real life that get away with an overhang panel is Gauntlet, and there it is very subtle. Except that, the only original cabinet that I have seen with a CP outside the side T-mold is Killer Instict, and that is not a good design – so why mimic that?
So, if you design something from scratch, why incorporate something that looks to have been added afterwards?
Where these Midway monster so common in the US, that all of you have been brainwashed with that kind of design?
And as always, it is my personal humble opinions, and it is not intended to hurt any ones feelings  :cheers:
brucelee00
« Reply #50 on: February 06, 2015, 07:18:25 pm »
Huh ?  ??? I think you misunderstood what I was asking or what' I'm doing as you can see I'm not doing a separate control panel box I just said i mimicked the MK cab's monitor angle and deciding which of the most recent designs you see above to go with... :cheers:
matsadona
« Reply #51 on: February 06, 2015, 09:50:46 pm »
Yes, the comment was more of a general kind, and I was about to applaud the final design. But by some reason that comment wasn't added in my post.
Anyway, looking forward to see how it turns out. And hopefully you will set standards for others to follow, so there won't be any more big-box-cp's built that will be a torn in my side  :P
brucelee00
« Reply #52 on: September 14, 2015, 04:52:04 am »
Just wanted to get a quick set of opinions on which design to go with # 1 was my original plan and i do have the template already cut out, but after recently messing around with design number #1 i come up with# 2 and #3. #2 & #3 are exactly the same minus the back angle.  Here are some pictures to illustrate the designs. Thanks for the feedback  :)
Generic Eric
« Reply #53 on: September 14, 2015, 10:25:40 am »
In the last pic, each cabinet is at a slightly different angle.  I'd suggest splitting the image into 3 if you can't get the angle in the same image.
Are they too deep if you are using an lcd?  The all look too deep.  Right now, I'm trying to place my cabinet against the wall in the basement.  I would enjoy the extra room, even it was only 3 inches.
The control panel for 3 looks deeper?  Its marquee looks bigger too.  Maybe it's the angle.  *shrug*
You mentioned a template? As in you will make more than one? Can you do a sketch up of a row of 4 or 5?  Is that something you would do?
« Reply #54 on: September 14, 2015, 11:11:56 am »
Sounds like you're over-rethinking things....
brucelee00
« Reply #55 on: September 14, 2015, 02:10:00 pm »
@ Generic Eric Hope this helps clear up the confusion. The depth between 1 and 2 at their widest points  are 31.75 and 31 inches for number 2. @Yotsuya I definitely tend to over think things  ;D
« Reply #56 on: September 14, 2015, 02:11:07 pm »
At least you learned your lesson about bezel size... :cheers:
brucelee00
« Reply #57 on: September 14, 2015, 02:21:30 pm »
@ Yotsuya Yes Sir I did  :cheers: no pinball buttons and just 6 buttons for 1 and 2 player, but will be throwing in a trackball :)
brucelee00
« Reply #58 on: November 05, 2017, 04:21:41 pm »
In the artwork design stage, but trying to settle on the name. I would like rad in the name, and decided against using kade/cade in the name. Here is a rough sketch, and the names I'm thinking. Any thoughton the names ? Totally Rad, Rad Things, Super Rad, Rad Power, Rad Dreams, Radical, Rad, Totally Radical, Forever Rad,Stay Rad, Rad to/2 the max
Re: Rad arcade 80s theme
« Reply #59 on: November 05, 2017, 09:43:50 pm »
I like Forever Radical with that design you’re doing
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #60 on: November 05, 2017, 10:45:04 pm »
I will put these here for inspiration.  :angel:
  • Last login:Today at 08:10:12 am
« Reply #61 on: November 05, 2017, 10:47:48 pm »
Radder Things.  It's Netflix 2017, bro, embrace it.
brucelee00
Re: Totally Radical Arcade
« Reply #62 on: April 21, 2018, 01:32:33 pm »
Haven't posted in this for awhile, but seeing some cool projects pop up so I figured I would share the artwork I have. Waiting for it get a little warmer out so I can finish building this cabinet.
Drnick
  • Plodding Through Life
« Reply #63 on: April 21, 2018, 03:33:40 pm »
 :applaud: :applaud: :applaud: I love the subtle "They Live" reference  :applaud: :applaud: :applaud:
Ian
« Reply #64 on: April 21, 2018, 05:09:41 pm »
Holy crap that is awesome!
« Reply #65 on: April 21, 2018, 06:35:26 pm »
+1
You artwork is totally rad!
« Reply #66 on: April 21, 2018, 07:46:10 pm »
Love that 80s look. Nailed it! Thumbs up!
kane916
  • Last login:February 05, 2025, 10:45:25 pm
« Reply #67 on: April 22, 2018, 07:47:53 am »
Top half is great kinda lost me with the bottom half. Just my opinion though.
kane916
« Reply #68 on: April 22, 2018, 07:50:35 am »
Looks like two separate machines.
Ian
« Reply #69 on: July 26, 2018, 11:28:34 am »
I am not ready to give up on this one... any progress? Still alive?
  • Last login:Today at 02:23:23 pm
« Reply #70 on: July 26, 2018, 11:32:34 am »
Yeah. For some reason I really want to see that artwork on a real machine. It breaks a lot of the "rules" I go by as far as art goes, but it just kind of works. I guess it is kind of a microcosm of the 80's in general.
Ian
« Reply #71 on: July 26, 2018, 11:47:52 am »
Right that's same reason I want that Arcade tease Chito to post completed pics of his monstrosity so I can see that bastard finished!
eds1275
  • Last login:Today at 02:57:14 pm
  • Rock and Roll!
« Reply #72 on: July 26, 2018, 12:08:07 pm »
HOT ENOUGH YET?
brucelee00
« Reply #73 on: October 13, 2020, 07:56:55 pm »
Picture Heavy!
I did not completely document this project in it's entirety, but you'll find that most of the techniques have been shown by other great build threads. Unfortunately, this project has taken a few years, and is still not done. My time has been very sparse of the last few years. Final pictures will be posted as soon as I am done. Thanks for taking a look.
« Last Edit: October 13, 2020, 08:07:21 pm by brucelee00 »
« Reply #74 on: October 13, 2020, 08:12:09 pm »
Looks great, man.
« Reply #75 on: October 13, 2020, 08:33:34 pm »
I love everything about this now that it is on a real cab. Nice work pulling the artwork together.
« Reply #76 on: October 13, 2020, 08:35:26 pm »
Love it, dude! Very creative
vertexguy
  • ...but this one goes to 11.
« Reply #77 on: October 13, 2020, 09:27:16 pm »
That art on the cab turned out great!  I really like how you encapsulated the feel of the 80's.  Well done!
thatpurplestuff
  • Last login:May 10, 2025, 02:37:15 pm
« Reply #78 on: October 13, 2020, 11:22:11 pm »
This turned out fantastic, killer artwork!
bperkins01
« Reply #79 on: October 13, 2020, 11:23:12 pm »
Well done - Great all around.  Love the artwork too.. fine execution!
