OK, first proper update in a while! Finally getting back in to this now
![Smiley :)](http://newforum.arcadecontrols.com/Smileys/default/smiley.gif)
I have all the controls now ready for edge-lighting, but the pac-pro needed mauling so that the LEDs can reach the plexi...
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351421;image)
Then some high strength PVA to lock the plexi in place. The metal mounting plate will go over this leaving a nice edge-lit RGB ring in the middle...
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351423;image)
Next up, (skip forward 13 months!) I decided to spray paint the backs of the panels white because, well, I want it looking nice
Masking taped over the control holes on the front and then sprayed a few thin coats of white gloss Rustoleum Universal All Surface Paint. Backs look great now for wiring
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351425;image)
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351427;image)
Time to finish prepping the panels for the artwork. I needed to get them filled and sanded so that there are no ridges around the control mounting plates (and plexi inserts) and the panel. I used some Isopon P38 for this. Seems to have worked great, now the panels are dead flat with no ridges
You can see that I masking taped the visible edge-lit plexi parts in the middle of the joysticks and spinners.
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351429;image)
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351431;image)
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351433;image)
The panel artwork overlays from gameongrafix arrived some time ago and look awesome...
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351435;image)
It's hard to portray in a photo just how nice this looks and feels...
![](http://forum.arcadecontrols.com/index.php?action=dlattach;topic=149895.0;attach=351437;image)
Next to do: -
I need to make sure no LED light can get through the panels/plexi inserts as it will show through the artwork. For this reason, and also to give a good surface for applying the adhesive-backed artwork, I'm going to spraypaint the panels black. A few coats of Rustoleum I'm hoping will stop any light getting through.
Also, wrapping the artwork around the top/bottom edges of the panels is a no-go without some contact adhesive. I've tried this out with a spare panel and some spare cut-offs that Scott from gameongrafix was nice enough to include with my order for free, and it works great.
Once I have the panels painted black, the artwork will be applied (scary!) and then it's time for wiring.
I'll post the plan for wiring soon.
