Author Topic: Wylie's Wars - Finished and Delivered!  (Read 19173 times)
dkersten
Re: Wylie's Wars - stage 2.9: Primer (and some sawdust)
« Reply #40 on: September 02, 2014, 04:34:30 pm »
Thanks.  I am about 50/50 on the 'S.. At this point the swaying factor is time, lol.  But the way it is looking, art is going to take forever anyway.. Local shop I checked out was going to be about 10 days turnaround if I give him print ready art.  Hoping Brad can do better..
I will post up higher res versions of the layout and lower front when I have a moment.
dkersten
« Reply #41 on: September 02, 2014, 11:30:51 pm »
Well Brad is going to come through for me.. again.. I highly recommend him for your art printing.
Just uploaded about 350 megs of tiff files for him to download, and he will ship the CP artwork tomorrow and I should have it Saturday...
Did a little sanding tonight and shot a 4th coat of primer on the bezel to seal up the edges.  Primer is still just not quite cured completely so sanding the sides was still gumming up a little.  Same as last time, took 48 hours and sanded way better.  So I will try to hit it tomorrow and get it prepped for the paint, and maybe even get a coat of paint on it.. I think the coin door will show tomorrow so I can get that cut in and get that piece primed.  Still have to make the back brace, which I might run out and work on tonight.. simple enough except I don't have a piece the right size so I have to dig up a bigger piece and cut it down.  Then cut in for 3 switches and the power socket.. Or I might just call it an easy night and fire up a game, lol.
Oh, I did get something done today.. I got the parts I ordered to make an extension for the spinner and got 2 of them made, one for mine and one for this one.  It works pretty well, although there is a little more play than I was hoping for, mostly due to using a "D" shaft instead of straight round.  Once I get the spinner mounted I will post some pics of how I did it.  it will be nice to be able to completely remove the spinner knob (or wheel) and not have the shaft in the way of anything.  On this cab I can use a 3/8" hole, so it will practically disappear when not installed.
dkersten
« Reply #42 on: September 04, 2014, 11:18:56 am »
All art got done and shipped in one day, should have it Saturday unless USPS fails me again..
Got the coin door yesterday, but because of bowling season, I didn't have much time to work on the cab.
I did manage to cut the hole for the coin door, which I misjudged and ended up cutting too small of a radius on the corners, so I had to patch it up and fill it a little.  While the glue dried I sanded the cab down and got the first coat of black paint on.  Despite trying to be conservative, the inside corner where the speaker plate meets the bezel still managed to run a little.  This paint goes on fast and is so thin!  I am going to have to wait until it is fully cured (should be good tonight) and get it sanded down in a few spots before getting the next coat on.  It is tough because I need to cover 3 sides in a small area and the difference between holding the nozzle for .2 seconds and .3 seconds is all it takes to get a run..  Frustrating.
I got the lower front panel primed and sanded and primed again, and one full coat of black on the main cab and a few of the other parts.  Tonight I will sand the runs, shoot another coat, get the back brace done and the switches mocked up, and make some progress on the control panel.  However far I get on the control panel I will at least get one coat of primer on it.  I picked up a different brand of primer and it dried super fast and was sandable in a matter of less than an hour, but I still want a solid coat of primer fully cured on the CP and then get at least one coat of enamel on it before the art goes on.  On Nostalgia I only primed to seal the wood and the edges were weak and the vinyl was coming up too easily.  I want to make sure my wood is sealed well and stronger on the corners so that won't happen again.
I didn't take any pics since there wasn't much to see, but today I will get the layout working for the FE, and take a shot of that.
If things go well, I will have a complete cab by Sunday night.  It is a little optimistic, but doable..
dkersten
« Reply #43 on: September 04, 2014, 07:38:40 pm »
Quick screenshot of the layout in action.. This is in Mala..
I didn't resize, sorry if it is too big (1920x1080)
More to come..
dkersten
Re: Wylie's Wars - stage 3: paint and software
« Reply #44 on: September 05, 2014, 12:30:11 pm »
Got the CP done last night (well, primered anyway, almost ready for art).  Spent most of that time building a recessed spinner mount, which I detailed in this thread.
So I detailed out how I like to cut the hole for the trackball in the woodworking forum, but just before getting started on this I had to move the side to a computer case out of the way, and I saw the fan duct sitting there bolted to the side of the computer.  On a whim I grabbed the trim ring for the U-trak and lined it up with this shroud, and it was a PERFECT match in diameter!  So I unscrewed it from the case, lined it up with where I wanted the hole in the CP, screwed it into place, and used it as a guide for the flush trim bit.  Took all of about 45 seconds to cut a perfect hole for the trackball.  I still had to chamfer the hole with a file to account for the taper of the trackball sleeve, but in the end it fit perfectly.
So after drilling the rest of the holes out, getting all the threaded inserts in place for the trackball, joysticks, and recessed spinner, I was able to get a good coat of primer on it before calling it a night.
The temp is already dropping here, so I jacked up the heat in the shop to 70 so all the paint would cure faster.
I had sanded the drips on the bezel and applied a second coat of black paint, but the paint was still a little too soft for that due to the colder weather, and it didn't work out real well.  Then to make matters worse, when wiping it down I left a little dust in the corner and now it looks like pure crap.  So I need to sand it down after it is fully cured, then apply 2-3 more light coats of paint.  Unfortunately this is going to be difficult if I am going to be getting artwork on this weekend.  So I might just have to delay the artwork install until after I have this sorted out.  I think I will sand it down well, then lay the cab on it's back and shoot the paint that way so that if it gets a little thick there it will settle out instead of run.. Plus it will fill the sanding scratches better.. This paint goes on nice and dries fast but it is so thin that it runs super easy and doesn't fill the scratches left by sandpaper at all.. I might have to sand to 320 just to get it smooth.  This is the only place it really matters a lot and of course it is the spot that got the worst.. Go figure..
rablack97
« Reply #45 on: September 05, 2014, 02:32:04 pm »
i guess i dont get why you go through all that trouble, happs trackballs are a simple 3" hole saw, and they come with the adaptor to adjust for acrylic.
Or is it you just dont want to use a mounting plate?
  • Last login:September 22, 2025, 02:22:29 am
« Reply #46 on: September 05, 2014, 02:50:33 pm »
I think Dave wholeheartedly subscribes to the theory down below:
It's supposed to be hard. If it wasn't hard, everyone would do it. The hard... is what makes it great.
dkersten
« Reply #47 on: September 05, 2014, 03:01:04 pm »
Took me 5 mins to make the hole from start to finish (used to take about 15 mins when I had to make the guide from the trim ring).  Another 3 to file out the back to accommodate the taper of the trackball, another 5 to drill and set the threaded inserts.  Not hard at all, and in the end I have a hole that you can't get with any holesaw, even if they made an 80mm holesaw, which they don't.
I also don't have a top plate, any exposed screws, no need for plexi, and no trim ring sticking up.  The U-Trak works very well, and the RGB lighting on it is fantastic.
I could also route the back out about 3/16" to raise the trackball, then just use a standard 82mm (3.25") holesaw and stick the trim ring on it and call it a day.  But then every time I went to make a shot in Golden Tee or Shuffleshot, and my hand ran across that trim ring, I would know that I spent just as much time to make something inferior, and that just doesn't make any sense to me.
I have very little experience with other trackballs, but if there is another that can undermount and end up flush with the CP surface with no exposed hardware and no need to use plexi to cover up a top plate, then I might try it in the future.
dkersten
« Reply #48 on: September 05, 2014, 03:01:58 pm »
lol, not exactly, but read my tagline
Havok
  • Trade Count: (+17)
« Reply #49 on: September 05, 2014, 04:21:51 pm »
Check out the U-trak:
http://www.ultimarc.com/trackball.html
dkersten
« Reply #50 on: September 05, 2014, 05:48:32 pm »
that's what I use, the u-trak.. I just don't know of another one that offers the same benefits.
Havok
« Reply #51 on: September 05, 2014, 09:11:29 pm »
Whoops - I glossed over that, I see it now in your earlier post. Yes, that's the only one I know of with that mounting capability.
dkersten
« Reply #52 on: September 07, 2014, 02:33:25 pm »
Well, the USPS failed me again... My "2 day priority" package didn't arrive after 3 days, so I took the time to work on electronics this weekend.  I didn't spend much time Saturday because some new furniture arrived and I was busy with all that, but I did get a few hours to play around, and today I will work on it some more.
Friday I ended up sanding out some bad paint spots, and then re-priming the entire bezel.  Saturday morning I sanded it smooth and was fortunate to have some great sunshine, so I rolled the cab out into the sun and shot 2 moderate coats of the finish paint.  The results are 100 times better than before.  Well worth the extra time.  I will get pics when the monitor is back in, it is hard to get shots of black paint against a light background and show any detail at all.
If I had art, I would be able to complete construction of the cab today and spend the rest of the day working on the CP.  But with no art yet, I will work on other details.  The marquee lighting will go in this afternoon, as will speakers.  I will prep for wiring the lighting, and possibly finish cutting the back covers.  The back support with all the buttons and socket is ready to go in.  I will have to snap a pic of that once it is in, but first I need to solder up the vandal switches.
Turns out the switch for the monitor was key.  Being a TV, when the computer sleeps, the TV will shut off, so even though it will remember it's power state when unplugged, if it doesn't have signal, it will still turn off.  So just around the back will be 1 USB jack, 1 latching switch for the marquee and coin lighting, 2 momentary switches for monitor and computer, and the power socket for the power cord, with a master switch.  The great thing about an LCD cab is that you can put switches back there and they are easy to access from the front, no big reach to get to them.
I got the 12v strip lighting hooked up to the LED-Wiz and played with the control in LED-Blinky.  Some cool things you can do there, but I will likely end up with just a simple cross fade animation that runs when in Mala or a game.  I played with the music settings and it was cool and all, but you can't do both cabinet animations and music animations in LEDblinky, so I will probably not bother with the music thing.  I ran 29 inches of LED off one set of channels on one bank, and even at max intensity (which should have been around 600ma) the LEDWiz never even got warm.  I had the heat sinks installed anyway, but I am not concerned in the least about overdriving it.  I will run about 30-40 inches of lighting per bank, 4 banks.  I *might* throw the coin door illumination on it so I can animate that as well.  Haven't decided.
The coin door reject buttons are yellow, but after adding a lot of lighting to them, I was able to hit a respectable color selection. Here are examples or Blue, Red, Green, and White.  Hybrid colors were tricky with the yellow tint, but should work out pretty well despite the yellow.
I will have more pics tonight or tomorrow morning.  And hopefully the art will arrive OK on Monday and I can finish this up before the end of the week.
dkersten
« Reply #53 on: September 08, 2014, 12:03:04 pm »
Spent a few more hours in the shop Sunday, got a lot of the interior wiring done and started getting some details finalized (at least what I could do without the art, which will hopefully be here tonight).
So I got the marquee lighting in.  2 strips of "warm white" 12v led, about 24" long each, controlled off a 12v PWM dimmer.  I found that the LED strips are too bright and need to be toned down.  The entire 5 meter roll of LED strip was about $9, the dimmer is about $4, and the connectors I used are about $5 for a pack of 10.  I have enough left over to do quite a few more and the only cost will be the dimmer.  Definitely the way to go if you are going to build more than one.  Could be used anywhere really, like to light the interior of a CP when you open it, etc.   Camera takes horrible pics of lighting.. I found that even at 2" back, you can't see the individual LED's through a marquee.  No need for diffusion, but if I needed it, some parchment paper would work great.
Here is the dimmer installed.  You can also see the back side of the 3 vandal switches and the drawer pull I use to manage wires coming from the CP and keyboard tray to keep them out of the way of the keyboard tray.
I got the 3 switches for monitor, PC, and marquee lighting installed (and lit them up because why not).  I also got the socket for the 110v power wired up to a power strip and installed.  Then I made a distribution block for 12v stuff.  The power supply is a 6 amp 12v regulated, perfect for the ambient lighting, marquee lighting, button lighting, and coin door lighting.
I got the monitor mounted in, and hooked up the switch for the 12v and for the monitor power.  Here are pics of the front and back as it sits now:
Aside from the control panel wiring and some programming for it, all I have left on the cab is the front and rear ambient lighting, the back pieces, a few holes for ventilation and wiring, and artwork and t-molding installation.
dkersten
Re: Wylie's Wars - stage 4: Art and control panel
« Reply #54 on: September 09, 2014, 10:47:56 am »
So art arrived last night at around 7 pm.  The mailman missed my house the first time around and returned at the end of his shift to deliver my package.  The print quality is perfect, the gradients are flawless and even the effects around the lightsabers came out fantastic.  Well worth the time to upload a quarter of a gigabyte of tiff files..
But by the time it got there I wasn't feeling well so I didn't get much done.  And it didn't help that I once again had an issue with the control panel art.  This time around I was super careful with the left to right spacing of the illustrator template vs the photoshop art.  And I measured the total length of the control panel with the 3/4" radius curve and both the horizontal and vertical sides of the unit, so the length plus a quarter inch bleed should have been perfect.  Yet some how I still managed to have my art shifted nearly a half inch too low, so the art came up 1/4" short on the bottom edge.  Not sure if I just measured wrong and didn't leave enough length or if I somehow shifted the margins in photoshop again, because if I had drilled my holes a quarter of an inch lower I would have had enough, but just barely, so I think it is a combination of both.  Next time I am just going to leave a 1" bleed and pay for the extra square footage.  Not worth this kind of hassle.  I am also thinking I might attempt to drill holes AFTER the art is down next time, so that I can get perfectly centered holes without worrying about stretching, shrinking, etc that causes things to line up improperly.  This time around I didn't do many lines that could be referenced to the edges or holes to show if it is off a little here or there, so it wasn't a big deal, but it is nearly impossible to get your art centered perfectly and not have any stretching by the time you get to the edges.
Anyway, the solution in to this problem might be simple and actually preferable, if it works out.  I had to call it quits last night before I reached that point though.  I normally just flush cut the edges of the vinyl since they are usually not exposed when the CP is in place in the cabinet.  When the CP is open they are at risk, but that isn't a common thing, so having the art just end right at the edge of the wood with nothing to protect it should be fine, and on Nostalgia this was reasonably OK, although I mishandled it a little and caused a little lifting in a couple spots (and once a little dirt or oil from skin is under that edge, it won't sit back down again).  But the bottom edge is exposed all the time.  The nature of the hinges doesn't allow me to put t-molding on that edge without cutting it shorter, so I left it on Nostalgia.  But this one will have kids playing it regularly, so having something to protect that edge will be worthwhile.  Since the art is short, I decided to cut a slot and use some t-molding on the face of the bottom of the edge.  This will hide the fact that I was 1/4" short, and protect that bottom edge.  It should look decent too as that part was plain anyway and it will break it up a little.  So it turned out to be a blessing.
Maybe.  See, I have yet to pound the t-molding into place.  And this is MDF, so the stress on the wood will be in the same direction as the "grain", and it is only 3/8" from the edge.  It could very easily split and just break off that whole corner.  So I have to be super careful.  I cut the slot already, but I am going to go back and open it just slightly by adjusting the router another 1/64" down and making another pass.  This will open up the slot to allow for just a little more room for the t-molding without compromising the tight fit.  Worst case I will dab some hot glue in there to ensure it never slips out.  I am a bit nervous about it because if it fails at this point I not only have to remake the CP, but get the art printed again..
So I got the marquee put together, and it looks fantastic.
I also got the art on the CP and cut most of the button holes out.  I had a severe migraine by this point and had to call it a night, but it was a good start.
I am really excited to get side art and front art on and see it all come together..
dkersten
« Reply #55 on: September 09, 2014, 11:42:05 am »
Well, I figured out what happened with my CP art..
I sent the wrong version to the printer!   :banghead: :badmood: :angry: :banghead: :hissy: :timebomb:
I am NOT happy about this at all..
I was just spending some time moving all my pics so they are no longer on my server, and I came across my first and second versions of the CP and sure enough, the differences are there.  So now not only is it short, but the Luke is too big, the sabers cross off center, and the font on the button labels is not the one I wanted.  Wow I am unhappy at the moment..
At this point, replacing it would be minimum of 5 days..
« Reply #56 on: September 09, 2014, 11:45:55 am »
Yeah, I thought Luke still looked too big.
Show your buddy. If he doesn't care, don't worry. No stresses.
dkersten
« Reply #57 on: September 09, 2014, 01:07:28 pm »
I see what happened.. I made the changes, saved a .jpg and then closed the file later without saving the .psd.  The changes are subtle so I didn't even notice it when I prepared the art to send out.  I am sure my buddy won't care, but I do, and it is frustrating to me.  So far I haven't compromised on anything here, and while I know there are imperfections, things are as good as I can get with my level of skill (and not having the time or patience to redo things a dozen times to get it perfect).  The last thing I wanted was to have to compromise on something at the very end.
Brad is reprinting it and getting it out today.  Thankfully my buddy isn't in a hurry, although it would have been nice to have done today as it is his son's birthday (was originally planned as a Christmas gift).  I should still be able to have it done this weekend.  I really want this done and off my plate so I can take a few days off from working in the shop.  Next week I plan to take some vacation time from work and while I might start another project, I want to first take some time to clean up my shop, get organized, and restock all my little hardware bits that I have been burning through.  Plus I need to take a hard look at my budget and make sure I am not coming out upside down on these.. lol.
dkersten
« Reply #58 on: September 10, 2014, 03:48:21 pm »
setback after setback.. but still grinding forward.
Applied the art to the lower front, found out that the t-molding I got needs a .080 slot, not a 1/16" slot, so I had to re-route the front piece and the drawer front to accommodate the thicker t-molding.  I used the same t-molding as on Nostalgia, and this would explain why it was so difficult to install, lol.
Went to put the front on, and discovered that despite checking it 3 times before cutting the coin door, I somehow managed to cut the coin door on the wrong end of the front panel.  How I managed to do that I have no idea.  So I removed the brass inserts, redrilled the holes, and put the inserts back in.  One of them broke halfway in though, so I had to cut it off since I couldn't get it back out again.. There is enough thread to work no problem, but frustrating nevertheless.
So I got that all done and got it mounted, but now it needs some minor adjustment.  Problem is, the keyboard drawer is already adjusted to the max, so I will end up drilling out the holes a little more to allow for more adjustment in the front panel.  It is a little off right now but it will come out nice in the end.  With all the setbacks I was just fed up and called it a night before plugging in the lighting and taking a pic with it lit.  Lighting is installed and ready to plug into the LEDWiz.
I should get further tonight, and then it is just waiting for the CP art to show.  My "fix" on the CP of adding some t-molding will get filled in tonight too, the new art will cover the spot and I am just too concerned that the corner will break off, especially with this t-molding being a little tight.  I might get it all fired up with the lighting installed so I can work on the animation programming..
rablack97
« Reply #59 on: September 10, 2014, 06:40:51 pm »
Looks good, Y not get you some coin door blue and red inserts?
dkersten
« Reply #60 on: September 10, 2014, 07:01:00 pm »
I am lighting them with RGB and running them off LEDBlinky.  I will probably do some kind of transition from red to blue and back again.. haven't decided yet.
dkersten
« Reply #61 on: September 11, 2014, 11:40:02 am »
OK, got the front aligned properly, then I mocked up the lighting (just plugged it into 12v, not through the controller yet), set the old CP on, and fired up the computer to take a couple shots.
Then I got the side art and t-molding on, and wow I am really happy with how it is coming together.  I had to open the t-molding slot a little by setting the router up with the 1/16" slot cutter, get it centered perfectly, then adjust 1/128" up and run it, and then down the same and run it.. doesn't seem like much, but that extra 1/64" makes a huge difference.  It was far easier on my router table to do this for the front cover as my lift has .002" increments.  I probably could have just loaded up the 3/32" cutter and run it, but I didn't want it to be loose, and the fit was nice and tight but not so much that I was splitting the MDF putting it in.
So I have a few things left to do yet:  Vent holes in the back, and the two back covers.  A hole for the wires to pass from the CP to the inner cab.  Securing the subwoofer and maybe even the PC, and cleaning up the wiring.  Routing the wire for the coin door lighting so you can still open the door and not have it in the way.  Wiring up the PC so I can use the remote momentary switch to turn it on and off.  Drilling a hole in the PC case to run the wires for 5v and power out to the cabinet.  Mounting and wiring up the LED-Wiz.  Installing the rear cab lighting.  And of course the entire Control Panel.  All those details are one good solid evening in the shop, the CP is a couple evenings or a full day at my kitchen table hunched over while running wiring all over the place.. Then it is just about programming the lighting and maybe adding a few more games before locking everything down and delivering it.  Even after the ~80 hours of work I have into it, I still have a solid 10+ hours left..
edit:  These pics don't come close to doing it justice, the compression from the jpeg's makes my super clean gradients and sharp silhouettes look like crap.  But you get a good idea anyway..
Here is the front view with everything on.  It is hard to get a pic that shows the unlit art and the backlit marquee, cab lighting, and monitor since they are all so different to the camera, but I think I captured it well.
And here is a shot with lights off.  The yellow stripes just don't show up well on cameral, but the yellow text and lines really pop on the otherwise blue, red, and purple background, and the black cab is a nice contrast to the colors, especially those touches of yellow.  The t-molding with the chrome stripe was definitely the right choice here, anything else just wouldn't have done it justice.  I am anxious to get a shot like this with the buttons all lit up too.
And finally, here are two shots of the sides.  It flows REALLY well and I couldn't be happier with the results.
dkersten
« Reply #62 on: September 12, 2014, 10:43:16 am »
Got the vent hole cut and the grill on, cut the hole for the CP wiring, got the LEDWiz mounted and wired to the front lighting (sides and coin door), then spent some time tying wires up and cleaning things up there.  I decided to mount the computer down, and after some consideration decided to remove the side of the case, screw it down (with felt pads for vibration), then just slide the computer onto it and put the screws in.  Simple and easy solution.  With the power button external and an external USB port, there is simply no need to access the computer unless it needs to be serviced.  I also applied some felt pads to the side of the subwoofer, then used 2 L brackets to mount it securely in place.  All wiring is secured except for the keyboard and mouse wires, which need to be able to come out during transport.  I also added battens for the back covers.
All I have left is the back covers, lighting on the back, which is simply a matter of hooking it up and taping it down (haven't decided for sure if I even want lighting on the back), and the control panel.  The art made it to town yesterday, but despite landing here at 6 am, they didn't bother to deliver it, because 2 days for priority 2 day mail would be too fast, it has to take 3 days or longer I guess..
Here are some pics of the guts.. The purple looking lighting is because the cab lighting is on
Then I spent some time playing with the lighting in LEDBlinky.  I set up some cross fade animations and set them to be run while the FE is active.  Here is a video of the animation in action.  The left goes from red to blue and back, pausing on the red and blue, the right does the opposite at the same time, and the coin door buttons go from purple to blue, then to red, then back to purple.  Unfortunately my phone's camera doesn't do a good job of distinguishing between blue and purple, so it doesn't translate well to video.  If you look at the reflection on the concrete, you can see the actual colors better.  I am going to lengthen the blues and reds and shorten the transition time, although I want to keep the transition smooth so I will keep the increments small and just decrease the frame time.  I am trying to minimize the "purple time" but not have a harsh transition.  Maybe I will try fading to black, then up to the new color.. hmm.. I would love to throw some green in there but everything else is blue and red and purple, so it wouldn't really fit.  I tried zooming into the coin reject buttons at the end of the video but they pretty much come across as purple in the video, even though there is a distinct cross fade going on.  I didn't wire the left and right on separate channels, so I just wanted something in the middle to compliment the left and right colors..
So I have 3 issues I want to work out.  First, the computer won't go to sleep while the animation is running.  I think this is something with the LED-Wiz as I have not had this problem with the Ipac UIO.  I can get around this by setting the power button on the computer to be a sleep button, making it easy to put the cab to sleep when not in use, but preventing the long load times when they want to use it.  With the latest version of the ipac UIO firmware, I can set a wake key, so you can just walk up, press the button, and be playing in just a few seconds (about 10-15 to wake Mala up and reload the animations).
Second, and this is going to be a big problem, when I DO force the computer to sleep with the sleep button, the animation just freezes, and the LED's stay on.  This is a problem.  I need a way to sleep the computer and have the whole thing turn off.  Again, the ipac UIO doesn't have this issue as when the computer sleeps, the LED's turn off.  I was trying to find a setting to turn off the USB ports when in sleep mode, but nothing I tried made any difference.  If I can't find a solution here, I am not sure what I can do.
Third, if I dedicate the LED-Wiz to cabinet lighting in LEDblinky, I can't use it for sound animation.  I would love to have it run a FE animation, and then when the game starts, to blink to the game sounds using the same animation sequence or maybe something a little more exciting.  This isn't a deal breaker like the first two, but I was hoping to come up with a way to do this.  Perhaps there is something in the setup I haven't found yet..
yamatetsu
  • Last login:Today at 02:22:49 am
  • Just because.
« Reply #63 on: September 12, 2014, 11:35:40 am »
Nice !
My probably totally unreasonable idea for the lighting would be to add a horizontal bar of LEDs (maybe at the bottom), that would allow the light to 'travel' between the two pillars (sorta like the thing on the Knight Rider car). The animation wouid start with the left pillar being lit up, the right one dark. The light on the horizontal bar begins traveling from left to right, thus 'draining' the left pillar, causing it to fade to dark. Upon reaching the right pillar, the light begins to pour into it, thus lighting it up. When the right pillar is lit and the left is dark, a little pause, then the animation is reversed.
dkersten
« Reply #64 on: September 12, 2014, 11:55:19 am »
Hmm, that's a cool idea.. I could light the bottom, but once on carpet it will be covered up :(  The gap is only about an inch, and all I could do would be to raise the front legs up which will tilt the cab back toward the wall.. At this point I am not taking that panel off and cutting it either, lol.  I will have to think about that more.. There might be something I can do there..
And I think I know the solution to turning off the lights when the PC sleeps:  I can wire a 12v relay to the PC's 12v, and turn off my separate power source when it goes off.  That way the PC has to be awake for the lighting to be powered.  The upside is I could have the marquee turn on and off with it too since it is using the same 12 volts.  Very easy to do and I think I have a few old 12v relays lying around.
Still waiting to hear back from RandyT about the sleep issue though, I would prefer if the computer would go to sleep after XX minutes by itself and not require a manual press of a button.
dkersten
Re: Wylie's Wars - Finished and Delivered!
« Reply #65 on: September 15, 2014, 12:40:57 pm »
Well, it is done and delivered.. :)
I got the CP art Friday evening, and didn't waste any time getting started.  Took about 30 minutes to get the art applied and the holes cut out.  Then I started getting stuff installed in it.  Overall it went smooth.  I worked on it for about 2 hours Friday night, got half the wiring done, then Saturday morning I had to get up somewhat early to haul kids around, and afterward I sat down for about 2 more hours and finished up the rest of the wiring.  It came out really good, although there was one big hiccup..
When designing the CP layout, I was trying to keep in mind that the last 2 CP's I did, I put the admin buttons above the trackball, and all too often I would be playing a game and end up hitting the exit button by mistake.  So I moved them to the right corner this time.  But somehow I simply spaced the fact that I have a plunger in that corner that allows me to open the control panel from underneath.  This was landing squarely on the Pause button.  It didn't take long to move the plunger to the other side, and I even had to trim out some of the support for the CP to allow for that pause button.  So no big deal in the end, just an oversight.
With the CP done, and the rest of the detail work finished, I got started on the lighting animation.  I ended up adding another strip below the sides, then set the animation to "chase" the next strip in a clockwise motion.  The first strip transitions from solid red to dark red while the next one is going from dark red to black and the next from black to dark blue, etc.  Then the first goes from dark red to black while the next is going from black to dark blue and the next from dark blue to solid blue... The effect was nice, and I used the coin button lights as the "top" of the circle.  Here is a video of the animation running just on the cab lights.
When both controllers were running animations, the performance was definitely slower.  Not much I could do without simplifying the animations, and I didn't want that, so I left it.  It was OK, just not quite as fast and as smooth as I would have liked.
So after some finishing touches, getting NES and SNES emulators set up and working, making sure everything is running right, and making my back cover panels, I called it a "done" project and delivered it.
The best part was when his kids, who had no idea they were getting this, came into the room and saw it for the first time.  We started with the lights off in the room and all the lights on the cabinet on and going, and they were in shock.  Then we turned the lights on and after a minute or two they realized it was all "star wars" themed and they went nuts.  The funny part was a game was selected that didn't have a cabinet picture, so the default picture of their cabinet was in place, and one of the two boys points to the picture and says "I want to play THAT game!".  They were so surprised at all this, they didn't have a chance to take in all the details.  When they noticed it was star wars themed, they kept saying "It's star wars?  It's star wars!" and I pointed to the Marquee and said "It's better than star wars, what does that say?" and the youngest looks at it and says "Willy's Wars?" and we all got a good laugh as in his excitement he forgot his own last name.  When he realized it was "Wylie's" he couldn't even speak he was so happy.  I showed them how to work the front end and watched them play a few games before leaving them alone to play.  They weren't raised with video games around much, so this is all very new and very cool to them.  And their dad was chomping at the bit to kick them off it and play himself.
Here are the final pics I took:
yamatetsu
  • Just because.
« Reply #66 on: September 15, 2014, 12:59:42 pm »
Very nice ! Congrats on another job very well done.
dkersten
« Reply #67 on: September 15, 2014, 01:06:01 pm »
Thank you, Yam!  This might be the last one for a while, I am burned out, lol.  3 cabs in about 4 months.. ugh, I have 2 more I am supposed to do, plus I want to build a sit down racer for myself, but I think I am going to take a break from it.  About midway through this one I started to get bored with it, and until I started playing with the ambient lighting (something new), I just wasn't having as much fun as before.
EMDB
  • Project RetroCade
« Reply #68 on: September 15, 2014, 03:36:17 pm »
You're fast...   Again a nice clean build. I don't like the artwork very much but that's personal. As long as the new owner likes it it's fine.
rablack97
« Reply #69 on: September 16, 2014, 08:35:56 am »
Yeah i feel you on this one, i have one more to build and it will probably be the last one as well.  It's one thing to build one for yourself, but when you start building for others the pressure of perfection and deadlines takes all the fun out of it.  Hopefully all will go well, but the more you build and hand out the more calls your gonna get for maint.
Very nice build though.....great job.
