Author Topic: magstick plus  (Read 1939 times)
rrcade
  • Last login:December 03, 2019, 10:37:08 pm
magstick plus
« on: April 19, 2014, 02:35:21 am »
For those of you that use this, how does it feel on games like pacman where you need a true physical 4 way restrictor?
EMDB
  • Project RetroCade
Re: magstick plus
« Reply #1 on: April 19, 2014, 05:56:16 am »
The Magstik plus HAS a true 4-way restrictor...
GeoMan
  • Last login:Today at 02:09:05 pm
Re: magstick plus
« Reply #2 on: April 19, 2014, 08:23:12 am »
In 4-way it has a very good response with games that require a 4-way joystick, in 8-way with games requiring an 8-way joystick i have seen better joysticks.
keilmillerjr
  • Web Developer.
Re: magstick plus
« Reply #3 on: April 19, 2014, 09:39:10 am »
I
  • It's switching capability between 4-way and 8-way is very good.
  • The operational feel when using it sucks.
It depends what you want more. This stick has good and bad. If you play many 4-ways, I might recommend it. If you play many 8-ways, I wouldn't get it.
HanoiBoi
Re: magstick plus
« Reply #4 on: April 19, 2014, 12:05:35 pm »
I haven't tried any other joysticks on the market to offer a comparison, but I'm happy with these.
I've been successful playing 4 way (Donkey Kong), 2 way (Joust), 8 way (Robotron) and even 4 way diagonal (Q*Bert) when in 8 way mode, without issue.
I've been able to score 200k+ on Donkey Kong, 600k on Q*Bert,  and as a bad Robotron player back in the day, I've been able to score over 1 million with the magstik plus sticks.
« Last Edit: April 19, 2014, 12:09:51 pm by HanoiBoi »
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
Re: magstick plus
« Reply #5 on: April 20, 2014, 11:19:42 pm »
I have two, 4 way they work good, but for anything else. They are ok at best.
wirenut
  • Last login:January 18, 2016, 02:11:07 am
  • Rumbai, Indonesia
Re: magstick plus
« Reply #6 on: April 21, 2014, 01:21:47 am »
I agree.  The throw is just too shallow.  I bought 2 and before I even installed them I decided to switch to Ultimarc Servo Sticks.  They are really nice.
Cynicaster
Re: magstick plus
« Reply #7 on: April 21, 2014, 01:42:11 pm »
I can't think of a single game that would take advantage of a 4-way stick in the player 2 position.  What are some examples?
HanoiBoi
Re: magstick plus
« Reply #8 on: April 22, 2014, 01:40:14 am »
Trog, Tank Force, Wizard of Wor.  Anything that might require navigating a maze.
Besides 2P games requiring the second 4 way, I like to set up both of my sticks to be used as player 1 for games such as Donkey Kong, Galaga, Ms Pac Man, etc. to give people options.
Drnick
  • Plodding Through Life
Re: magstick plus
« Reply #9 on: April 22, 2014, 01:18:57 pm »
I second most comments here,  Pretty good in 4 way mode, just meh in 8 Way mode.  I won't be changing mine out anytime soon though. If you haven't already purchased and you want the 4/8 way switching then look into servosticks. Although others will have to advise on it's 4/8 way feel.
Ravenger
  • Last login:October 01, 2024, 04:43:52 pm
Re: magstick plus
« Reply #10 on: April 23, 2014, 12:37:07 pm »
I've got two Magsticks in my setup. As others have said it's great for 4 way and ok for 8-way, but not excellent. I love the switching mechanism, which works well.
My gripe is that they feel a bit clunky. I don't know if it's wear or if I didn't put them together properly after taking them apart to install them (you have to take the stick apart to mount them), but the handle on my sticks feel 'loose' when moving, despite the short throw.
They're also corner happy which makes them not too good for Robotron.
I'd like to switch them out for Servostiks at some point, but I'm reluctant to pull apart a fully working control panel, plus I'm not sure there's enough room under the panel for the servos, as it's a small panel.
