Hello markc74
I saw on your youtube video you are using an ATI 4350 card connected to a Beovision 1 25" tv and a SSD2313 ultra wide monitor using the CRT emudriver and Windows XP 64 bit.
I´m using almost the same setup as yours, win32 + ati 4350 + crt_emudriver 1.2, besides your beovision, i´m working with an Arcade Monitor 20" thru plugged on the DVI port thru DVI > Vga adapter into the J-pac, i tried to plug a normal lcd monitor just to test if i could get any image thru the VGA port of the ATI 4350, but have nothing, windows xp 32 + Crt_Emudriver 1.2 from Calamity could´n detect the monitor, any hint how did you do that ?
Marcos
