Author Topic: Blip - 100% complete - Updated the Control panel  (Read 120371 times)
markc74
  • Last login:June 13, 2024, 09:18:00 am
  • Flipping out
Re: Blip - 100% complete
« Reply #200 on: October 30, 2015, 07:55:53 pm »
I'll do both. I'm happy to share directly as all the files I have were made by others - I just rejigged them to work from my setup.
That being said - having had to search far and wide to get a lot of these files I would be massively in favour of helping create a central source for them. I don't want to redo what other people have started unless it would be *the* archive which could take a lot of work. I'm up for it if others are... A central repository for arcade artwork would need a lot of help...I'm up for it if it has community backing and other peeps to help build it.
stigzler
  • Last login:February 11, 2022, 03:01:48 pm
    • Mago Arcade
« Reply #201 on: November 01, 2015, 06:50:27 pm »
Nice one. Just knocking together an app to hopefully make the job smoother - one that takes .dats (in this instance MAME), constructs a game list then lets you compare three image folders (displaying dimensions, filesize and dpi etc). Idea being, one folder would be 'new' images for comparison, another your own local copy and the third a cloud syncing folder (such as dropbox).
Should make the whole process a little easier. Once have done this, maybe we start a separate thread inviting assistance? Could do it via public shares on dropbox or something...
Just got the mame marquees up and running on my cab today. Great to have all those maquees changing with game-select, but some of them are appalling. Think most in my set are 500px wide + look a bit cacky as a result.
Anywhos - thanks for the offer of collaboration and sharing.  :cheers:
markc74
  • Flipping out
« Reply #202 on: November 04, 2015, 11:46:39 am »
Hi Stigzler - if you're still after the marquees - all the files I have are available here:
https://drive.google.com/folderview?id=0B2XxpmZ16vfOX2w3ZWU3T1E4dm8&usp=drive_web
Have fun  :cheers:
markc74
  • Flipping out
« Reply #203 on: November 04, 2015, 11:54:01 am »
Recent activity on this thread reminded me that I never got around to uploading the walkthough videos I did for the cab last year. I've finally put them on youtube if anyone is interested.
Unfortunately it's narrated by me so you'll have to put up with my dulcet tones. Next time I'll try and get the guy who does 'Honest Reviews' on youtube to do it. Beeeewbs... (look it up)
And the cable wrapping I was trying to name in the first video is called snakeskin sheathing. I had a brain fart while trying to remember the name at the time!
Part 1
Part 2
fablog
  • Last login:Yesterday at 09:44:17 pm
« Reply #204 on: November 05, 2015, 01:52:02 pm »
Hi marck74. Congratulations for your creation. It's an inspiration for me. I think I will copy the black and white design  ;D
« Last Edit: November 06, 2015, 12:55:00 pm by fablog »
stigzler
    • Mago Arcade
« Reply #205 on: November 05, 2015, 01:56:47 pm »
Have fun  :cheers:
You're a gentleman and a scholar, sir! Fabulous contribution.
I'm working hard on the app to help with maintaining/producing full image sets - so I'll start a separate project thread once done and start cracking these marquees (all 10,000 of them!!?? from the mame.dat :/)
severdhed
  • Last login:October 07, 2022, 04:45:32 pm
  • RIP Dinosaur Hippo
« Reply #206 on: November 07, 2015, 11:05:16 pm »
I don't know how i missed this one, this cabinet is fantastic.  Very impressive :applaud:
stigzler
    • Mago Arcade
« Reply #207 on: November 09, 2015, 05:49:18 pm »
May be of related interest: started a HD Mame Marquee project here:
http://forum.arcadecontrols.com/index.php/topic,148204.0.html
Mark - sent you an IM on the subject - thanks for the set - some excellent marquee goodness therein. And that 1366 figure is emblazened on me brain-bag (Litemax X dimension?). I can never remember the height divided by 2 though!
m.andrade1
  • Last login:April 06, 2023, 09:56:51 am
« Reply #208 on: June 10, 2016, 02:12:49 pm »
Hello markc74
I saw on your youtube video you are using an ATI 4350 card connected to a Beovision 1 25" tv and a SSD2313 ultra wide monitor using the CRT emudriver and Windows XP 64 bit.
I´m using almost the same setup as yours, win32 + ati 4350 + crt_emudriver 1.2, besides your beovision, i´m working with an Arcade Monitor 20" thru plugged on the DVI port thru DVI > Vga adapter into the J-pac, i tried to plug a normal lcd monitor just to test if i could get any image thru the VGA port of the ATI 4350, but have nothing, windows xp 32 + Crt_Emudriver 1.2 from Calamity could´n detect the monitor, any hint how did you do that ?
Marcos
markc74
  • Flipping out
« Reply #209 on: June 14, 2016, 08:26:24 pm »
Hi Marcos - my 4350 card came with a HDMI port which is what I use to connect to the LCD marquee - I haven't tried using the vga port. The only other difference in setup is I'm using xp 64 bit but I'm not sure if that would matter in this case.
Have you enabled your LCD monitor in your display preferences? (right click on desktop). Mine is set to stretch across both screens.
markc74
  • Flipping out
« Reply #210 on: September 10, 2018, 07:16:48 am »
Updated control panel
After using my Invaders cabinet for a while I’ve decided that I much prefer using a curved button layout. So much so that it started bugging me that Blip had the buttons in a straight line - first world problems, I know.
Since I was planning on redoing the buttons I figured I may as well rejig the panel a bit to space things slightly better and move the led lights to somewhere more visible towards the top of the panel.
So - here’s the final panel, printed and wired up. I’ll probably switch the battop with a white or red one to match the graphics more but that’s about it. It feels way better this way and I definitely prefer the way the lights work now.
Anyway, just a small update as this cabinet is finished. It’s still my favourite cabinet that I have made and I still hammer it weekly.
Aaaand here it is with it’s siblings…!  ;D
« Last Edit: September 10, 2018, 07:29:20 am by markc74 »
  • Last login:Today at 09:32:19 am
Re: Blip - 100% complete - Updated the Control panel
« Reply #211 on: September 10, 2018, 07:19:42 am »
Nice. It is always worth the effort to improve game play.
markc74
  • Flipping out
« Reply #212 on: September 10, 2018, 07:25:38 am »
Defo. I didn't realise it was uncomfortable because I'd not tried the curved one before. I've kept the 2 player control panel as a straight layout to match SF2 but I tend to use that much less (as it's usually winner stays on) and it's what I'm used to. Single player, curved all the way.
I switched the joystick out for a Happs stick while I was at it. As I've got a vertical cab now it doesn't really need a servostick as there's so few 4 way horizontal games
Jimbo
  • Last login:May 18, 2024, 11:27:47 am
    • Wood Finishes Direct
« Reply #213 on: September 10, 2018, 09:35:16 am »
Looks awesome!  When you inviting me over?! ;)
markc74
  • Flipping out
« Reply #214 on: September 10, 2018, 09:47:52 am »
Whenever you're in Kent and have a bag full of beers  :cheers:
  • Last login:Today at 05:38:01 pm
« Reply #215 on: September 10, 2018, 11:23:11 am »
I’ve always liked Blip!
  • Last login:Today at 12:18:00 pm
« Reply #216 on: September 10, 2018, 12:17:10 pm »
Looks great.  Your CP art needed to be applied very precisely.  How did you do it?  Did you apply the art and then drill the holes?  If so, were you worried about the art tearing?  If not, and you drilled the holes first, how the heck did you line up the art so perfectly without the center points of the buttons to go by?
Jimbo
« Reply #217 on: September 10, 2018, 05:30:52 pm »
I'm in Kent and I'll get beers on the way! ;)
Heh... seriously, where in Kent are you?  I'm in Folkestone.
stigzler
    • Mago Arcade
« Reply #218 on: September 10, 2018, 05:50:42 pm »
Cool tweak - yeah - arc'd buttons are a lot more ergonomical.
Is it just me or does this look like mummy, daddy and baby arcade bear?
Vidiot
  • Last login:February 15, 2024, 10:00:17 am
  • John 3:16
« Reply #219 on: September 11, 2018, 01:23:29 pm »
Blip is still one of my favorite cabs of all time here on BYOAC. It's hard to believe you could improve it. Great job man. Lots of love for your work.  :applaud:
morton
« Reply #220 on: September 11, 2018, 05:11:46 pm »
Woah wait ... Is there a build thread on that lil cabaret somewhere too??
  • Last login:Today at 07:04:08 pm
« Reply #221 on: September 11, 2018, 08:11:20 pm »
Build thread for his "CUBE" cabaret:
http://forum.arcadecontrols.com/index.php/topic,151654.0.html
davide.simonetto
  • Last login:November 13, 2022, 02:02:32 pm
« Reply #222 on: March 06, 2019, 10:47:34 am »
Hi mark!
First of all congratulations for the job, is it wonderful and really stylish.
I am starting my own project and I am searching since weeks for a project to follow not to get lost in stupid mistakes given that it is my first try.
I happend to have a crt monitor the same size as your and I would love to recreate a cabinet like that. Are you available to share some plans to have an idea about the dimensions? With that width, is the control panel comfortable for 2 players?
Sent from my SM-G955F using Tapatalk
blueznl
« Reply #223 on: June 16, 2019, 04:31:34 pm »
I've not been here for a while (suffering from RLI) but got to say there have been some awfully nice projects since my last visit. Love this!
As I've just sold my second cab (don't worry, it was that bad I didn't even dare to post anything here :-)) it's time for attempt number 3. Not in a hurry, still got lots of other things to do, but I definitely love the Blip and Mimic designs.
Going through this thread I didn't see anything explaining how you fixed / swapped the control panels. Do you use any kind of mechanical lock or something?
markc74
  • Flipping out
« Reply #224 on: June 17, 2019, 03:35:02 am »
Hi Blueznl.
I don't think I posted my first couple of cabs here either (although it was a *long* time ago!). Laythe did a great job with his Mimic cab and the way he integrated the marquee and bezel design is a step up from mine.
The control panels basically slot in from the top. Because of the weight of the panels and the tight fit they don't move around at all. I originally thought about using velcro, magnets or those CP catches that were common but it really wasn't necessary.
markc74
  • Flipping out
« Reply #225 on: June 17, 2019, 03:39:00 am »
Hi mark!
Oooooops. Sorry I missed this mate. I have the plans somewhere. If you're still around PM me or reply here and I'll upload them/send them over.
The Control panel is 66cm/~26" wide which works great for 2 players. Nothing wrong with elbowing a competitor in the ribs now and again though for a tactical advantage  ;D
davide.simonetto
« Reply #226 on: June 17, 2019, 08:11:02 am »
Thanks a lot. Actually I already am halfway through the work. I used the measure you gave of the TV stand and made some proportions on the black pic you posted :) I stayed on the 60cm inside for space issues. I will share with you some pics. I am having some trouble with the retropie and the crt resolution, but I am working on it :)
Inviato dal mio GM1913 utilizzando Tapatalk
Neonpt
  • Last login:June 28, 2022, 06:24:59 am
« Reply #227 on: April 27, 2022, 07:01:27 am »
Hi mark!
Hello mate, i am starting to build my own custom arcade, and i love your cabinet design, would be great if you could share your plans.
Also, after so many years after you built it, would there be some things you would change if you would have done it today?
Thank you
