Author Topic: Sega Monaco GP 1979/1980 - My Remake  (Read 363053 times)
geecab
  • Last login:Yesterday at 04:13:08 am
Re: Sega Monaco GP 1979/1980 - My Remake
« Reply #400 on: June 28, 2024, 04:27:36 am »
@GPForverer2024 and @xfassa
Excellent stuff chaps! Thanks for the posts!! Hopefully, I'm not to far away from the next debug release. The normal play -> extended play switchover thing is a bit tricky but its getting there. Also, I noticed that depending on where your time runs out on the normal play (Grey) roads influences the point where you start on the extended play (Blue) roads. For example, sometimes you'll see the Blue road with gravel patches on *before* the bridge, sometimes *after* the bridge. I worked out the sequence now, I'll explain a bit better when I've implemented it all :)
@Ali
Hi again! Thanks for trying v1.5.0, glad you like it. Unfortunately, the link to your image doesn't work for me? What's the name of the configuration that you are having problems with?
Ali
  • Last login:January 31, 2025, 08:55:56 pm
« Reply #401 on: June 29, 2024, 04:31:07 pm »
Hi Geecab!!
Im using 1920 x 1080!
The problem with glasses appear on the beginning and the endings of horizontal screen (on the left of left arcade, Moon Patrol, and on the right of the right, Command)...
Best regards!
« Last Edit: June 30, 2024, 03:28:47 am by Ali »
geecab
« Reply #402 on: July 05, 2024, 01:53:05 pm »
Hi All!
I've put together another debug version. Hopefully, we are getting close to an actual v1.5.1 release!
@xfassa - I've added the immediate Normal play to Extended play road switchover thing.
@Ali - Hopefully, the default configurations fit the screen a little better now.
The game package - v1.5.0D9:
****EDIT: This version is now obsolete, please see initial post (on page 1) for download links to latest and obsolete versions****
Extract from the release notes:
v1.5.0D9 (05-07-2024)
 - For Classic Monaco GP and Pro Monaco GP game modes, ensure Normal Play
   (Grey roads) to Extended Play (Navy blue roads) switch over happens
   immediately when the timer expires (and you have enough points).
 - More precise artwork placement when self generating the default set of
   configurations.
« Last Edit: August 08, 2024, 07:10:22 am by geecab »
xfassa
  • Last login:September 16, 2024, 09:53:01 am
« Reply #403 on: July 07, 2024, 09:12:24 am »
GEECAB - Thank you for the update!  The game instantly transitions to the bonus conditions when the timer hits zero.  Absolutely perfect, thank you sooooooo much.  :-)
Ali
« Reply #404 on: July 08, 2024, 09:01:17 pm »
   configurations.
Many thanks Geecab!!
Superb work!!
Are you forgetting to update you 1st post?
(Or only not posting Debug versions)?
Maybe, are there people checking only the 1st, since you wrote some time ago:
"Each time I make a new version, I will update this post so that it contains a link to the latest version of the game :)
-=Latest Version=-
Monaco GP Remake v1.4.6 for Windows... ...
Best Regards, Ali
Ali
« Reply #405 on: July 08, 2024, 09:02:06 pm »
   configurations.
Superb work!!
-=Latest Version=-
Best Regards, Ali
geecab
« Reply #406 on: July 10, 2024, 06:18:48 am »
Excellent stuff xfassa and Ali! Thanks for the feedback!
@Ali - Whoops, good spot, I should have updated the 1st post with v1.5.0 but got side tracked with bug fixing. I won't update it just now as I'd rather people hang on for the v1.5.1 release. And yes, I won't update the 1st post with debug versions, only full releases.
I'm going to play test v1.5.0D9 a bit more myself before releasing v1.5.1. I may tweak the difficulty levels across the game modes and make them more consistent. I think the difficulty level for the Classic Monaco GP and Pro Monaco GP is about right, but the Pursuit and Stunt game modes for me are a bit easy... This weekend, I'll put v1.5.0D9 in my cabinet (That uses a spinner / mouse hack) and decide if things need to be tweaked after that. Hopefully, in a about a week I'll be ready to do a v1.5.1 release, unless you guys find any more bugs that is :)
geecab
« Reply #407 on: July 18, 2024, 09:09:17 am »
Hi all!
Thought I'd write a quick update as I've noticed a few issues when running the game on my cabinet. Just a few loose ends to sort out....
- [DONE] When steering with mouse/spinner, when entering your name for the hiscore table, the cursor used to select a letter moves too fast.
- [DONE] When steering with mouse/spinner, it is possible to 'teleport' just after leaving the starting grid and after leaving the boathouse.
- [DONE] In debug mode, the car/boat wrongly takes damage.
- [DONE] The stunt park game mode is too easy because the amount time awarded at the checkpoints was never getting reduced for subsequent laps.
- [DONE] Ability to reset hiscores without using the in-game editor (Or deleting the hiscores file). To reset the hiscores, hold down the 'R' key (which is configurable) for 10 seconds during the attract mode. A countdown appears after which you hear the explosion sound to indicate the reset is complete.
- [DONE] When overtake bonuses are being awarded at the end of a Pro game, allow player to press start or accelerator to hurry this along.
- [DONE] The Stunt game had incorrect sign during the one of the boat sections.
- [DONE] On the Pursuit/Stunt games, picking up a spanner (which awards you a few extra seconds as well as fixing any damage) just after your time had run out did not allow you to continue for those few extra seconds.
- [TODO] More play testing. Almost done.
« Last Edit: July 23, 2024, 05:04:12 am by geecab »
geecab
« Reply #408 on: August 07, 2024, 06:33:18 am »
Hi All!
Monaco GP Remake (v1.5.1) for windows is ready download from my google drive. The Linux and Raspberry Pi packages will be available soon.
****EDIT: This version is now obsolete, please see initial post (on page 1) for download links to the latest version****
The release notes should explain everything there is to know about using Monaco GP Remake and all its new features. It should be as easy as:
 1. Downloaded the game package and unzip it into a folder of your choice.
 2. Double click on 'gui_launcher.exe'.
 3. Choose a configuration and click the “Start” button to play.
Default keys are LeftArrow = Steer left, RightArrow = Steer Right, A = Accelerate, S = Gear, 5 or 6 = Insert Coin, 1 = Start Button, TAB = In game configuration editor, R = Reset hiscores (Hold for 10 seconds during attract mode).
Note. No arcade ROMs are required, and all of the arcade background artwork I created (As seen in the teaser trailers) should work straight off the bat.
Extract from the release notes version history:
v1.5.1 (04-08-2024)
 - Added 'ADDITIONAL_TIME' to the GAMEPLAY configuration options. If the game
   proves too difficult, give yourself a little extra time initially and at
   checkpoints (The track file can also be modified for the same effect).
 - Added 'KEY_RESET_HISCORES' to the CONTROL configuration options. You are
   now able to reset hiscores without deleting the hiscores file. To reset the
   hiscores, hold down the reset hiscores key ('R' by default) for 10 seconds
 - When steering with mouse/spinner and entering your name for the hiscore
   table, the cursor used to select a letter moved too fast.
 - When steering with mouse/spinner, it was possible to 'teleport' just after
 - In debug mode, the car/boat wrongly took damage.
 - When overtake bonuses are being awarded at the end of a Pro game, the player
   may press start or accelerator to hurry this along.
 - The Stunt game had incorrect sign during the one of the boat sections.
 - On the Pursuit/Stunt games, picking up a spanner (which awards you a few
   out was not allow you to continue for those few extra seconds.
 - Added 270 degree wheel / analog joystick steering curve diagram to docs.
 - The readme.txt found in the 'track' directory includes descriptions of
   RoadChanges and TrackEvents seen in *.trk files.
   configurations.
 - Fix secondary bezel resize issue after exiting in-game editor.
 - Scoreboard bezels 'Monaco GP' lettering now have less glow and less red tint.
 - Fix for steering 'teleport' issue when using mouse (xfassa).
 - New scoreboard import/export configurations added.
 - Added dashboard indicator artworks for when driving on night, on ice, when
   the engine damaged and when out of gas.
 - Added a speedo gauge artwork.
 - Ability to set 2 bezels artworks: A Primary Bezel (Showing, say, a bezel
   image with its blacklight on), and a secondary bezel (Showing, say, a bezel
   image with its backlight off).
 - A new 'bezel mode' option that configures how the game should switch between
   bezels (Either, Switch from one to the other when in-play without flicker,
   or with one flicker, or with two flickers etc...).
 - Police chase artwork lights now work on import mode.
 - Fixed Pro score LEDs not working when running the Stunt and Pursuit Modes.
 - Fixed the revcounter so that you don't have to have it enabled on the
   export mode to be able to see it on the import mode.
 - Make skidding on ice skid more like the arcade.
   By default, skidding will only start when the steer threshold is reached.
   Once started, the car will skid indefinitely (Until the car slows right
   down, or crashes, or drives onto a normal road). I decided not to set a
   finite skid time as default because, since I working on this, I have seen
   youtube videos of arcade machines where the skid never times out. I suspect
   the arcade machine I watched originally (that did have a finite skid time)
   may have had a board fault. The default ice skid settings are now:-
       ice_skid_trigger_speed     30
       ice_skid_trigger_steer     20
       ice_skid_intensity         50
       ice_skid_time_active       5000
       ice_skid_time_decay        0
 - Fix revcounter bug when running import mode at a low refresh rate.
 - New refresh_rate option added Helps reduce CPU usage.
 - New chequered_road_brightness option added.
 - Add new curve, deadzone and range steering options for limited rotation
   wheels.
 - In-game editor now scrolls long descriptions. Improve wording of some
   config options.
 - Fix brief 'teleport' after driving over a puddle bug.
Enjoy! 😊
« Last Edit: December 06, 2025, 12:27:12 pm by geecab »
GPForverer2024
  • Last login:August 24, 2025, 09:43:10 am
« Reply #409 on: August 09, 2024, 09:33:50 am »
hello geecab!
I have just tested version 1.5.1 and of course everything works perfectly, a real treat!!!
what can I say other than a big thank you for this magnificent REMAKE and this great work!!
For your information, don't forget for what uses 2 screens to lower the refresh rate to 25 (for my part)
GEECAB The best!  :applaud: :applaud: :applaud:
 :) THANKS
geecab
« Reply #410 on: August 09, 2024, 01:45:26 pm »
Excellent stuff GPForverer2024!!
Great to hear you're happy with v1.5.1, and thanks for your help ironing out those bugs with all the debug builds you've tested!
Yes indeed, I was in 2 minds whether to make the default refresh_rate 25 for the import configurations, but I just left everything at 50 in the end. However, I have wrote a 'worked example'  for dual screen support in the release notes, and in that example I do use a refresh_rate of 25 and make a point of explaining why. Hopefully, if users trying out dual screen support and read the release notes, it should be pretty clear what to do should they start noticing CPU performance issues :)
« Last Edit: August 11, 2024, 05:28:00 am by geecab »
GPForverer2024
« Reply #411 on: August 10, 2024, 05:56:48 am »
Hi GEECAB!
Yes, you were right, it's all in the release notes.
I have a little idea to improve the arcade version!
 Do you think it would be possible to add a real flashing light as soon as you hear the police or fire siren it comes on??? That would be great!!!!
Maybe by activating it via a button? I don't know, I'm not a programmer, to my great sadness... but I would very much like to be able to add a real flashing light to our terminal What do you think?
I want to be your tester
 Here is a link to the flashing light
https://www.pincab.eu/gyrophares-pincab/44-gyrophare-12v-bleu.html
 see you soon GEECAB! ;)
GPForverer2024
« Reply #412 on: August 10, 2024, 06:33:55 am »
HI GEECAB !!
I found this I don't know if it can be useful for you?
geecab
« Reply #413 on: August 11, 2024, 05:27:00 am »
Hi GPForverer2024!
Cool idea! I think it might almost be possible with v1.5.1 'as is', but it might mean you will need to learn a little about programming in C++.
In the MGPr package you should find "scoreboard_reader.exe". The source code and Visual Studio C++ project file for the scoreboard_reader.exe you'll find for this in the 'utils' directory (So you could, if you wanted to, download a free version of Visual Studio C++, open the project file (scoreboard_reader.vcproj) and compile yourself a scoreboard_reader.exe).
Anyway, scoreboard_reader.exe, is a very simple application that when you run it, it reads the shared memory of a running MGPr instance that is configured for export mode. The scoreboard_reader.exe just reads the shared memory every second and prints it as text in a command line window. Try it by running, say, MGPr with the 800x600_pursuit_export_scoreboard.cfg and whilst its running double click on scoreboard_reader.exe.
You'll see a whole bunch of stuff gets printed (The scores, car speed, time, speed, gear shift position etc...). You'll see "Police" printed which is 1 when you are being chased, 0 otherwise.
So, you could modify the scoreboard_reader.cpp source code, so that if Police changes for 0 to 1 you send the usb command to turn your flashing light on, and when Police changes from 1 to 0 you send the usb command to turn the flashing light off. I can always help modify the scoreboard_reader.cpp for you should you get stuck.
Unfortunately, at the moment, MGPr doesn't export anything to let you know when there is a FireTruck on screen, but that shouldn't too tricky for me to add.
Does that make any sense?
« Last Edit: August 11, 2024, 05:31:28 am by geecab »
GPForverer2024
« Reply #414 on: August 11, 2024, 09:29:08 am »
Hi GEECAB!
 I'm glad you like my idea
yes it makes sense!!
 I'll try to learn the basics in C++
I ordered the material as soon as I receive it I will get back to you (about 10 days)
 I'm very excited about the idea of adding a rotating beacon
I hope to succeed in any case   ???
See you soon
 Thank you GEECAB    ;)
geecab
« Reply #415 on: August 13, 2024, 05:05:00 am »
Excellent stuff GPForverer2024! I'm pretty confident we'll get this going, looking forward to you getting the parts! :)
GPForverer2024
« Reply #416 on: August 20, 2024, 11:02:27 am »
Hi GEECAB!
I received the equipment,
So I followed the tutorial in the video above and all the commands via PowerShell work manually to activate or deactivate the relay
 now I modified the scoreboard_reader.cpp file as you told me with a C++ editor and I added this script at the end from line 235 and it doesn't work I know there is an error in the script but I don't know what as I am
a beginner in C++
Here is the end of the script I added:
if (police=1)
    [Byte[]] $powerOn  = 0xA0,0x01,0x01,0xA2
    [Byte[]] $powerOff = 0xA0,0x01,0x00,0xA1
    $usbrelay = new-Object System.IO.Ports.SerialPort COM3,9600,None,8,one
    $usbrelay.Open()
    $usbrelay.Write($powerOn),0,$powerOn.Count)
    $usbrelay.Close()
#endif
if (police=0)
        $usbrelay.Open()
        $usbrelay.Write($powerOff),0,$powerOff.Count)
        $usbrelay.Close()
#endif
Can't wait to read you back
Thank you GEECAB !!! ;)
geecab
« Reply #417 on: August 20, 2024, 03:06:15 pm »
Hi GEECAB!
a beginner in C++
if (police=1)
    $usbrelay.Open()
    $usbrelay.Close()
#endif
if (police=0)
        $usbrelay.Open()
        $usbrelay.Close()
#endif
Hi GPForverer2024!
I think I understand how your relay works with your powershell commands. As we want to control your relay with the C++ program, we need to talk to it "the C++ way" (Which is a bit tricky, especially as this is your first ever C++ program lol!). Give me a few days, I've done something similar before with an Arduino, I'll write some code for you and hopefully get us started :)
geecab
« Reply #418 on: August 23, 2024, 04:37:00 am »
Hi GPForverer2024!
I wrote a program called "scoreboard_to_serial", that I think might do the job (Talks to Serial Port COM3, and writes relay power on or off data to COM3 when police cars are on or off the screen). Hopefully you'll be able to follow most of what is going in the 'main' function (See scoreboard_to_serial.cpp).
I've zipped up source code and the executable I built.  I've also included the Visual Studio project file if you fancy building it / editing it yourself:
https://drive.google.com/file/d/1MRyH8U3os-mGbW1cczWWWntHctn6jgZO/view?usp=sharing
If it doesn't work, can you run the exe from command line and let me know what the errors say.
If it does work, that's cool, I'll make that modification to the MGPr so that the 'police' element also changes when a FireTruck/Rescue vehicle is on screen.
GPForverer2024
« Reply #419 on: August 24, 2024, 02:35:46 am »
Hi GEECAB!
You are incredible! It works !!!!!!!    :applaud: :applaud: :applaud:
 it's crazy what you manage to do, I'm FAN  ;)
 otherwise yes it would be nice to be able to distinguish the police and the firefighters, I'm going to buy another card but with 2 relays when do you think?
 really THANK YOU GEECAB!  :applaud: :applaud: :applaud:
 Looking forward to hearing from you!
geecab
« Reply #420 on: August 24, 2024, 08:45:18 am »
Wow! Can't believe it worked straight off the bat, excellent stuff GPForverer2024!
Cool! and if you decide later that you didn't like the "One light spins for firetrucks, and the other light spins for police" thing, then you/we could always modify scoreboard_to_serial.cpp to run in a mode where it makes both lights spin at the same time for police & firefrucks maybe? There could be a command line argument that scoreboard_to_serial.exe looks for to put it in the desired mode?
GPForverer2024
« Reply #421 on: August 25, 2024, 04:39:41 am »
Hi GEECAB!
 yes yes I confirm that it worked the first time!! a remarkable job GEECAB BRAVO!! :applaud:
 otherwise finally I bought a new card with 4 relays!
 because in the idea it would be good that we can choose which relay does what?
 1 relay = police flashing light
 2 relays = firefighter flashing lights
 3 relays = vibrating motor shaker for the steering wheel (when the car passes over puddles and also over the blue ice road)
 4 relays = I don't know yet
 I was inspired by Pincab's toys
 I ordered the shaker too for testing
 here is the link of the relay card in there is info at the bottom of the page for the config if it can help you with your C++ script
https://www.aliexpress.com/item/1005003992496644.html?spm=a2g0o.detail.pcDetailBottomMoreOtherSeller.61.49e1OgMBOgMBJd&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.40050.354490.0&scm_id=1007.40050.354490.0&scm-url=1007.40050.354490.0&pvid=1762b301-b225-4518-85dc-d2e4fc5ea09c&_t=gps-id%3ApcDetailBottomMoreOtherSeller%2Cscm-url%3A1007.40050.354490.0%2Cpvid%3A1762b301-b225-4518-85dc-d2e4fc5ea09c%2Ctpp_buckets%3A668%232846%238110%231995&pdp_npi=4%40dis%21EUR%216.95%214.03%21%21%217.55%214.38%21%402103854617245742206191105e148f%2112000027669023747%21rec%21ES%21%21ABX&utparam-url=scene%3ApcDetailBottomMoreOtherSeller%7Cquery_from%3A&gatewayAdapt=glo2fra
 I can't wait to test all this!
I'll make you a new video
I don't know what you think?
Looking forward to reading you soon and once again a big thank you GEECAB!!    ;)
geecab
« Reply #422 on: August 28, 2024, 05:42:30 am »
Hi GPForverer2024!
That should all be fine, I think it should be pretty straight forward to modify the code to support several relays. I'll write you some code in a few days to get you started.
I might have a look into how difficult it would be to trigger force feedback / rumble effects direct to your g29 wheel at some point. There is some support for this already in Allegro, but its appears to be an at experimental stage of development, and it is not supported on XP. It would be quite nice if I could make the scoreboard_to_serial.exe talk direct to you g29 wheel. There is a force feedback plugin written by a user named 'Boomslang' discussed here https://forum.arcadecontrols.com/index.php?topic=157734.0, might ask some questions on that thread, maybe they'd like to support MGPr or I can somehow talk to their plugin :)
GPForverer2024
« Reply #423 on: August 28, 2024, 10:47:11 am »
Hi GEECAB!
 Many thanks for the new script which will have the possibility to manage 4 relays!
I just came across a small bug with scoreboard_to_serial.exe
Let me explain:
when I did the 1st try, I connected the usbrelay on my PC (personal) and I launched MGPR import then export and scoreboard_to_serial.exe and there everything works it detects my USBRELAY well and it works!!
then I connected my USBRELAY to my Arcade Terminal, the PC detects my USBRELAY but in COM5 so I modified the scoreboard_to_serial.cpp file and changed the com3 to com5 And when I launch the
scoreboard_to_serial.exe file the window opens and closes immediately without me being able to read anything. I have the impression that it can't find it while in my device manager it is well configured
 I don't know what to do?  :'(
Otherwise for the vibration flywheel, my flywheel doesn't have a G29, it's a flywheel (270°)made with an arduino board
Follow on a tutorial on YouTube
 I bought a small 12V shaker that will be triggered with a relay when the car passes over a puddle or blue ice It's a small flat motor that I'll fix behind the steering wheel support board and that will give me the
 vibrations on the steering wheel certainly not as a force feedback but simple vibrations
 I hope I was accurate lol Looking forward to reading you soon!! ;)
geecab
« Reply #424 on: August 28, 2024, 12:24:40 pm »
Hi GPForverer2024!
Oh that's a shame, it was all going so well!
Rather than double clicking on scoreboard_to_serial.exe, can you run it from command line. it should print some error messages when it fails and you should see them if you run it from command line. Hopefully that'll give us an idea of what is going on.
Also, just want to make sure, after you've edited the scoreboard_to_serial.cpp file, you are compiling a new exe with Visual Studio?
Ah sorry, getting you confused with another user lol!
GPForverer2024
« Reply #425 on: August 29, 2024, 05:53:50 pm »
Hi GEECAB
I'm really sorry
 but could you tell me how to run the file on the command line?
 And how do I compile the file?
Now I'm lost, sorry. :'(
Thank you
GPForverer2024
« Reply #426 on: August 30, 2024, 03:25:50 am »
Hi GEECAB!
good news!! I found the solution
 I was in device manager and change the USBrelay COM5 port to COM3 port so that I don't modify your scoreboard_to_serial.cpp file and it works!!!!
you can't know what it feels like to see the flashing light turn in the middle of a game of MGPR it's great!!!
 on the other hand when the flashing light is triggered the steering wheel no longer responds left or right until the flashing light goes off and the steering wheel responds well in MGPR
Thank you very much ;)
geecab
« Reply #427 on: August 30, 2024, 09:26:16 am »
Hi GPForverer2024!
Ah sorry, should have been a bit more specific. I mean run it in a windows "Command Prompt" window. Press the Windows key + R, and a Run command box should appear.  Type cmd in the Run command box and click OK. A Command Prompt window should appear. From within the Command Prompt window, if you then change directory to where the scoreboard_to_serial.exe is stored (For example, cd c:\downloads\scoreboard_to_serial<enter>) and then run it by typing scoreboard_to_serial.exe<enter>.
Ok, might be a bit of a steep learning curve ahead. I think it is perhaps worth it in the long run, you'll be able to tweak how your relays react to the MGPr changes as you wish (Without having to wait for me to build you something) :)
To create the exe, I recommend downloading and installing "Visual Studio with C++  (Community 2022)", its free, here's the link https://visualstudio.microsoft.com/vs/features/cplusplus/. I'd install it on your PC (Personal) machine, not your arcade machine.
Once installed, you should be able to start "Visual Studio 2022",  click on the "Open a Project File" option and select the c:\downloads\scoreboard_to_serial\windows\scoreboard_to_serial.vcprog file. Visual Studio will then say something about it needs to do a one-way upgrade to scoreboard_to_serial.vcprog, converting it to a .vcxprog file (Which is absolutely fine, just agree to it (Its because I made the vcproj using an old version of Visual Studio), it'll also say it needs create a solution file (.sln) which is fine too. Once the project has loaded, click 'Build' on top menu bar and then click on 'Build Solution'. Then wait a few seconds, and hopefully an exe will get built (You should find it in c:\downloads\scoreboard_to_serial\windows\Debug\ directory).
Hm, sounds like the there was good reason windows decided your relay should use COM5, probably because your wheel is using COM3 so you now have a bit of a conflict...
Let me know how you get on with the Visual Studio thing. If you don't have any joy, I could build you a scoreboard_to_serial.exe that asks you what com port it should use when it first starts up...
GPForverer2024
« Reply #428 on: August 30, 2024, 10:49:38 am »
Hi GEECAB!
 I was able to build the new scoreboard_to_serial.exe file by following your top recommendations! I was able to change to COM 5 and it works!
 On the other hand, always the same problem, the steering wheel moves more left and right as soon as the flashing light comes on!
 I think you're right, there's a material conflict!!
I even like to change the COM port to 12 and always the same
 For information I noticed that my usbrelay in the device manager had the same name as my flywheel, there is just the COM port that changes, namely:
USB-SERIAL CH340(com4)
 USB-SERIAL CH340(com5)
com4 is my steering wheel and com5 usbrelay
 Do you have any idea why my steering wheel doesn't react when the flashing light comes on?
 thank you for your feedback
geecab
« Reply #429 on: August 30, 2024, 11:45:34 am »
Hi GPForverer2024!
Well done for getting the exe built, you are now a C++ programmer! :)
But yes, seems to be a conflict with having multiple ch340 devices :/
Can you let me know a few things...
1. Is your Arcade machine running windows 11 ?
2. What version of Windows is running on you PC (personal) ?
3. When you view the Properties of the "USB-SERIAL CH340" devices in Device Manager, in the "Driver" tab, what Driver Version is reported (Should be something like "3.5.2019.1")
4. When you view the Properties of the "USB-SERIAL CH340" devices in Device Manager, in the "Events" tab, what does the first line of the 'Information' window read (Should be something like "Device USB\VID_1A86&PID_7523\5&2b1d7621&0&1 was configured").
5. Also, on the relay device itself, can you read what is written on the little black chip (You might see something like "WCH CH340G") ?
« Last Edit: August 30, 2024, 12:18:16 pm by geecab »
GPForverer2024
« Reply #430 on: August 31, 2024, 03:15:07 am »
Hi GEECAB!
1. My Arcade machine is running Windows 11
2.My personal PC is running Windows 10
3.Driver Version 3.5.2019.1
4.The USB        USB\VID_1A86&PID_7523\6&93e0c40&0&3
5.On the chip it says WCH CH340T 205895047
 Thank you ;)
geecab
« Reply #431 on: August 31, 2024, 04:47:54 am »
Hi GPForverer2024!
Thanks for this. I've been reading about these WCH CH340 things, I am no expert on them, but it seems they are made in China by "Nanjing Qinheng Microelectronics Co., Ltd", and the latest drivers (02/11/2023, 3.8.2023.02) can be found here:-
https://www.wch-ic.com/downloads/CH341SER_ZIP.html
I've been reading a bit on this thread https://forum.arduino.cc/t/ch340-driver-rollback-workaround-works-on-windows-10-but-not-11/1187954 about CH340 and the latest drivers causing problems (Mainly the CH340 failing to be recognised) on Windows 11, but I think that is only a problem for unbranded CH340 chips. I *think* if you are able to see the WCH CH340 written on both your relay device and your steering wheel device, then you should be OK try the latest version?.... Depends on how brave you feel!
Before trying to install the latest drivers, might be worth trying to tick the "Enabling the Serial Port Enumerator (SerNum)" option for both CH340 device and seeing if that makes any difference? I really don't know what this option is for, but it wouldn't hurt to try it. How to do this is described in the arduino forum thread I've put a link to above (You'll have to scroll down quite a bit to see the post, there is screenshot showing the option to tick).
Also before trying to install the latest drivers, as an experiment (And I'm not sure if this is possible for you to do or not), you could try plugging your wheel and relay into your Win10 PC and seeing if that it any different? If so, see what version of CH340 driver that it is using?
Or maybe just wait for your 4-relay device to arrive and seeing if that is any better before you start updating drivers?
Hope this helps?
« Last Edit: August 31, 2024, 04:50:28 am by geecab »
GPForverer2024
« Reply #432 on: September 01, 2024, 08:21:29 am »
Hi GEECAB!
 yes you're right I also think that the fact that unbranded chips are a problem
 at least for me it's not the case otherwise for me it would be difficult to try with my Windows 10 PC with the connectors
 For information I don't have the option to enable the serial port enumerator (sernum) I think it's in the latest version of the driver (2023) that
it's there I also think you're right, I'll wait to receive my 4 relay card which should arrive in 2 or 3 days to test this and then I'll update the driver even if I'm itching to do it right away!!
 As soon as I receive the material I let you know
 Thank you for the script you're coding for the 4 relays
 thank you GEECAB ;)
geecab
« Reply #433 on: September 01, 2024, 09:46:39 am »
Hi GPForverer2024!
A sensible choice! Wait and see how the 4 relay board performs and go from there.
No worries, I shall have that written before your new relay arrives.
« Last Edit: September 01, 2024, 09:59:16 am by geecab »
geecab
« Reply #434 on: September 01, 2024, 09:50:03 am »
Hi All!
Just letting you know, Monaco GP v1.5.1 for Linux and Raspberry Pi is now released!
The release supports x86 Linux PCs Ubuntu 24.04 based distros (e.g. Linux Mint 22) and ARM Linux Debian 12 ('Bookworm') based distros (e.g. latest Raspberry Pi OS) 32-bit & 64-bit:
Monaco GP Remake v1.5.1 for Linux & Raspberry Pi (Download via My Google Drive)
Please read the release notes HERE.
Many thanks for Neil Davis for making the Linux and Raspberry Pi release possible! Check out Neil's Instagram and YouTube channel for more of his cool projects retrofitting arcade games into vintage handhelds! :cheers:
I've also updated the very first port of this thread with this information.
Enjoy!! :)
« Last Edit: September 01, 2024, 11:51:07 am by geecab »
geecab
« Reply #435 on: September 03, 2024, 04:12:32 pm »
Hi GPForverer2024!
I wrote a program called "scoreboard_to_relays", that should work with you 1xRelay device and also your 4xRelay device.
Here's the link to a zip containing the source code, Visual Studio project and a pre-built exe:-
https://drive.google.com/file/d/1QC4cAjBHPC7KMgNF3cg8a7Q94Q4p7n94/view?usp=drive_link
You need to run the scoreboard_to_relays.exe from a windows command prompt.
If you run it without specifying any arguments, it'll display the help/usage.
Usage:
To actually run scoreboard_to_relays.exe, you'll need to supply 8 arguments:
  scoreboard_to_relays.exe <r1_com> <r1_trigger> <r2_com> <r2_trigger> <r3_com> <r3_trigger> <r4_com> <r4_trigger>
Where:
   r1_com     = Relay 1 COM port number
   r1_trigger = Relay 1 scoreboard trigger
   r2_com     = Relay 2 COM port number
   r2_trigger = Relay 2 scoreboard trigger
   r3_com     = Relay 3 COM port number
   r3_trigger = Relay 3 scoreboard trigger
   r4_com     = Relay 4 COM port number
   r4_trigger = Relay 4 scoreboard trigger
Valid scoreboard triggers are:
   gear
   police
   damage
   skid
   night
   coin
   inplay
   none
Example 1:
   Configure so that 1st relay COM5 triggered when inplay, 2nd relay COM6 triggered by skid, 3rd relay COM7 triggered by gear shift and 4th relay COM8 triggered at night:
        scoreboard_to_relays.exe 5 inplay 6 skid 7 gear 8 night
Example 2:
   Configure so that 1st relay on COM3 triggered by police, 2nd relay on COM4 is not present, 3rd relay COM5 is not present and 4th relay COM6 is not present:
        scoreboard_to_relays.exe 3 police 4 none 5 none 6 none
Note. Running scoreboard_to_relays with your 1xRelay and using the arguments specified in Example 2 should function the same as the scoreboard_to_serial.exe tool I made.
Note. In Example 2, even though COM ports 4,5 & 6 are specified, scoreboard_to_relays will never try to connect to them because their associated trigger is set to 'none'. You are effectively saying that the relay isn't present.
Hope this helps!
GPForverer2024
« Reply #436 on: September 04, 2024, 04:07:25 pm »
Hi Geecab!
Wow again great job!
I'm testing all this and come back to you as soon as possible!
 thank you very much
FYI I sent you a message privately, had you seen it?
GPForverer2024
« Reply #437 on: September 05, 2024, 10:14:32 am »
Hi Geecab!
 That's it, I received the 4 relay card,
 I plugged everything in and unfortunately Windows 11 doesn't detect the card... so I tried on my personal PC windows 10 and same it detects nothing...
I even installed the latest ch340 drivers (2023) but nothing...
FYI I tested the 1 relay model with the latest CH340 drivers (2023) and it works with your first script scoreboard-to-serial.exe on the other hand I tried your 2 script scoreboard-to-relays.exe and it doesn't work it
can't find it here is what I put: scoreboard_to_relays.exe 3 font 4 none 5 none 6 none and he writes: Trying to connect to MGPr export instance... then the window closes while scoreboard-to-serial.exe works
for the 4 relays I have contacted the supplier I am waiting for this answer
I hope to find the solution
hope this helps you
 thank you Geecab :)
geecab
« Reply #438 on: September 05, 2024, 10:44:06 am »
Hi GPForverer2024!
That's weird that windows doesn't detect the 4xRelay card... Does the Device Manager detect anything at all?
Probably a good idea to run scoreboard_to_relays.exe from command line (Using a windows command prompt window) then you'll be able to see what error is causing it to terminate.
I think the problem could be you have specified 'font', but that is not one of the valid triggers. Try 'police' instead of 'font'.
Note. Valid scoreboard triggers are:
   gear
   police
   damage
   skid
   night
   coin
   inplay
   none
« Last Edit: September 05, 2024, 11:18:59 am by geecab »
GPForverer2024
« Reply #439 on: September 05, 2024, 05:17:35 pm »
Hi Geecab!
sorry for the typo but yes it's not font but police that I wrote
 then in device manager it detects nothing it displays nothing and I don't even have a beep sound from windows that tells me hardware connect while the 1xrelay yes it detects
For the scoreboard-to-relays.exe script the window displays Parsed Relay1 (COM3) - police Parsed Relay2 (COM4) - none Parsed Relay3 (COM5) - none Parsed Relay4 (COM6) - none Trying to connect to MGPr export
instance... Trying to connect to MGPr export instance... Trying to connect to MGPr export instance... then this closes
while scoreboard-to-serial.exe it displays Trying to connect to Serial Port... Serial Port connected OK Trying to connect to MGPr export instance...
 Then when I launch Mgpr it works
 I have the impression that script 2 can't open the com port
I think after I'm not an expert lol
if it can help you
Thank you GEECAB! :)
