Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1029570 times)
0 Members and 8 Guests are viewing this topic.
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #680 on: September 04, 2013, 03:13:16 pm »
Ok, so I think I got everything, now... Recessed cuts for speaker / marquee, control panel parts, monitor support pieces, and a shelve type thing the cp and monitor assembly rest on...
TKW4rr10r
  • Trade Count: (+16)
« Reply #681 on: September 04, 2013, 10:30:33 pm »
It's a thing of beauty, as line art CNC paths go, lol
« Reply #682 on: September 04, 2013, 11:44:17 pm »
If you think it looks good, I'll go ahead and put it in for an estimate.
TKW4rr10r
« Reply #683 on: September 05, 2013, 06:22:40 am »
Yeah man looks good to me
Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #684 on: September 05, 2013, 08:11:43 am »
ghostrider
  • Last login:October 16, 2017, 08:29:47 pm
« Reply #685 on: September 05, 2013, 05:56:18 pm »
Is there any way you could build a kit for the Little Ms. Pac-man (http://forum.arcadecontrols.com/index.php/topic,128666.0.html) that Griffindodd (aka Maximus) designed and make it fit the asus 23" evo monitor?  I would be down for one of those for sure.
Any chance of this happening???
« Reply #686 on: September 05, 2013, 10:30:43 pm »
I have to get caught up on some other projects, but after that I can take a look.
steved61
  • Last login:October 19, 2025, 01:05:53 pm
« Reply #687 on: September 06, 2013, 08:24:58 am »
Pedestal?
Steved61
« Reply #688 on: September 06, 2013, 09:57:56 am »
Pedestal?
Of course! Where else would we put Haruman?
:D
« Reply #689 on: September 06, 2013, 11:14:29 am »
Lol. Yes, pedestal is up on the list. :-)
tron84
  • Last login:November 15, 2017, 06:45:56 am
« Reply #690 on: September 06, 2013, 11:21:15 am »
Pedestal?
:D
:laugh2: :laugh2: :cheers:
I about spit out my Java when I saw this :D
of course he belongs on there :D
+1 for the Pedestal thou Haruman & the mini pin cab wink wink :)  :cheers:
That cocktail table is coming along Nicely!!!!!! so pretty :)
mann0mann
  • Last login:June 25, 2016, 12:31:54 pm
  • Still looking for the right project...
    • My Hobby Store
« Reply #691 on: September 06, 2013, 10:14:46 pm »
Hey Lee, any word on if an xbox original console will fit in the widescreen version?  Hope it will fit without having to remove to the case.  I'm thinking it might if mounted against the back of the monitor support?
« Reply #692 on: September 06, 2013, 10:29:36 pm »
I just checked, and no, it will not fit. Sorry...
tron84
« Reply #693 on: September 12, 2013, 02:48:56 pm »
Well finally the Barstick is finished. :D
I used GGG, GP Wiz40 Max interface.  So down the line rotary joys could be used if decided to be put in here. :D
Thanks again Haruman for the kit. :cheers:
I do not have the back on it for the pic, so there is some light from the marquee showing on the wall.
But on the CP & the top of the Barstick, I did a Data East in a Star Wars font  ;D
« Reply #694 on: September 12, 2013, 06:04:32 pm »
that is tits right there, big fat oprah tits  :applaud:
tron84
« Reply #695 on: September 12, 2013, 06:17:40 pm »
lol  :laugh2:
Thanks man  :cheers:
degenatrons
« Reply #696 on: September 13, 2013, 02:47:02 pm »
Looks sweet!  and good to see the first completed barstick  8)  Hopefully will inspire others to make one.
« Reply #697 on: September 13, 2013, 02:49:53 pm »
She's a beauty!
Just a question - have you considered rounding the two back corners? In looking at them, the top rear corner looks a bit sharp for my tastes, which led me to think if you did both, the t-molding could be 'joined' in the center of the bottom, and then you wouldn't have as many sharp corners.
Just my two cents.
tron84
« Reply #698 on: September 13, 2013, 06:41:43 pm »
Thanks degenatrons :D & thanks for the open source plans for it. :)  I hope it will inspire others to make one. :)  I really like the Barstick.  ;D
You can never have to many controllers  ;D
@Rick
Thanks also  ;D
The rear top corner is a bit sharp.  I had to snip a little of the inside track of the Tmold to get it to go on the rear corners.  No biggie thou  ;D
rablack97
« Reply #699 on: September 16, 2013, 11:06:45 am »
Nice work man on the barstick....
Did you recess the sticks a bit? Cause they look mights short.
I sometimes have to route a recess under the CP so the sticks sit up higher.
Regardless the assembly and completion was well done. :applaud: :applaud: :applaud: :applaud:
tron84
« Reply #700 on: September 16, 2013, 02:32:00 pm »
Thanks man  ;D
& a shout out again to Haruman for his kits :D
No, I did not recess the sticks.  They are just shorties  :D   normally I just say that after getting out of a cold pool  ;D ::) :laugh: :lol
I like the quick throws of them.  To the top of the ball is 2" from panel.
« Reply #701 on: September 16, 2013, 04:13:41 pm »
No, I did not recess the sticks.  They are just shorties  :D   normally I just say that after getting out of a cold pool  ;D ::) :laugh: :lol I like the quick throws of them.  To the top of the ball is 2" from panel.
So, these are mounted from underneath then?
« Reply #702 on: September 17, 2013, 10:33:50 am »
Yes.
« Reply #703 on: September 17, 2013, 10:40:51 am »
So, until I find a good (read cheap) freight option, the Atari Cabaret will be local pickup only...
tron84
« Reply #704 on: September 17, 2013, 10:49:44 am »
They must have some serious weight to them.  How much was the quote that you said, "umm I dont think so"?
I am sure somebody here knows a good freight option.
« Reply #705 on: September 17, 2013, 10:54:30 am »
Well the issue is that anything over 150 pounds gets pushed into freight category (with FedEx) and that basically quadruples the price.
3/4" Black Melamine is pretty heavy, even heavier than 3/4 plywood.  With 2 sheets of melamine, it'd be pretty close to the limit...  plywood should be able to keep under the limit maybe.
« Reply #706 on: September 17, 2013, 11:00:13 am »
Well the issue is that anything over 150 pounds gets pushed into freight category (with FedEx) and that basically quadruples the price.3/4" Black Melamine is pretty heavy, even heavier than 3/4 plywood.  With 2 sheets of melamine, it'd be pretty close to the limit...  plywood should be able to keep under the limit maybe.
I was thinking about this myself, for my pinball cabinets. If the price is prohibitive, try packaging the larger items separately, to bring the price down. Sure, you'll be almost doubling your regular shipping costs, and increasing the risk of lost/short shipments, but you should be able to get your packages in under the weight limit.
Source: I worked for Canada's largest courier company for over 13 years.
:D
« Reply #707 on: September 17, 2013, 11:06:01 am »
:D
Hmm...  that's a thought.  Put the 2 sides together in a largish box, then the rest of the parts in smaller box #2.  Each one would be well under 150 pounds.
« Reply #708 on: September 17, 2013, 11:06:59 am »
"Thank you for shopping at Rick's Shipping Tips. Helping out the competition since 2013."
:lol
« Reply #709 on: September 17, 2013, 11:11:03 am »
:lol
Lol.
« Reply #710 on: September 19, 2013, 03:30:15 pm »
Mmm...
TKW4rr10r
« Reply #711 on: September 19, 2013, 04:40:16 pm »
That's incredible!  :o The glass come with the kit? did you paint the black areas around the controls, or where they cut from black stock? Also what size LCD is in that cocktail?
I'm working with a local CNC guy in SC for the Atari kit. I hope to have one cut and some photos up in the next week or so, in case anyone is curious on how the finished product turns out.
« Reply #712 on: September 19, 2013, 05:02:16 pm »
Glass not included, but is available online for around $80 shipped.
Those particular control panels were cut from wood, and covered with black cabinet grade vinyl.  Metal pacman control panels (11") will work as well.
The top is designed to fit a 20.1" LCD, a Dell 2001FP.
« Last Edit: September 20, 2013, 09:51:55 am by HaRuMaN »
  • Last login:Yesterday at 11:23:23 pm
« Reply #713 on: September 19, 2013, 06:25:50 pm »
HOLY ---smurfing--- ---steaming pile of meadow muffin---, THAT LOOKS AWESOME!
« Reply #714 on: September 19, 2013, 06:36:04 pm »
OMGWTFBBQ!!!
« Reply #715 on: September 20, 2013, 09:54:06 am »
Another pic
« Reply #716 on: September 20, 2013, 10:08:34 am »
Is that price coming from you, or a different source? Any opportunity for smoked/tinted?
« Reply #717 on: September 20, 2013, 10:33:46 am »
Nope, different source.  I will look into smoked / tinted.
« Reply #718 on: September 20, 2013, 01:37:41 pm »
Flash on
« Reply #719 on: September 20, 2013, 01:43:24 pm »
With all the money you make from these kits, please consider investing in a better camera.
;) :D
Awesome work, man!
