January 22, 2026, 04:35:25 am
Ok, so I think I got everything, now... Recessed cuts for speaker / marquee, control panel parts, monitor support pieces, and a shelve type thing the cp and monitor assembly rest on...
Yeah man looks good to me
Is there any way you could build a kit for the Little Ms. Pac-man (http://forum.arcadecontrols.com/index.php/topic,128666.0.html) that Griffindodd (aka Maximus) designed and make it fit the asus 23" evo monitor? I would be down for one of those for sure.
Pedestal?
Quote from: steved61 on September 06, 2013, 08:24:58 amPedestal?Of course! Where else would we put Haruman?
Hey Lee, any word on if an xbox original console will fit in the widescreen version? Hope it will fit without having to remove to the case. I'm thinking it might if mounted against the back of the monitor support?
that is tits right there, big fat oprah tits
Well finally the Barstick is finished.
Looks sweet! and good to see the first completed barstick Hopefully will inspire others to make one.
Quote from: tron84 on September 12, 2013, 02:48:56 pmWell finally the Barstick is finished. Looks sweet! and good to see the first completed barstick Hopefully will inspire others to make one.
Nice work man on the barstick....Did you recess the sticks a bit? Cause they look mights short.I sometimes have to route a recess under the CP so the sticks sit up higher.Regardless the assembly and completion was well done.
No, I did not recess the sticks. They are just shorties normally I just say that after getting out of a cold pool I like the quick throws of them. To the top of the ball is 2" from panel.
Quote from: tron84 on September 16, 2013, 02:32:00 pmNo, I did not recess the sticks. They are just shorties normally I just say that after getting out of a cold pool I like the quick throws of them. To the top of the ball is 2" from panel.So, these are mounted from underneath then?
So, until I find a good (read cheap) freight option, the Atari Cabaret will be local pickup only...
Quote from: HaRuMaN on September 17, 2013, 10:40:51 amSo, until I find a good (read cheap) freight option, the Atari Cabaret will be local pickup only... They must have some serious weight to them. How much was the quote that you said, "umm I dont think so"?I am sure somebody here knows a good freight option.
Well the issue is that anything over 150 pounds gets pushed into freight category (with FedEx) and that basically quadruples the price.3/4" Black Melamine is pretty heavy, even heavier than 3/4 plywood. With 2 sheets of melamine, it'd be pretty close to the limit... plywood should be able to keep under the limit maybe.
Quote from: HaRuMaN on September 17, 2013, 10:54:30 amWell the issue is that anything over 150 pounds gets pushed into freight category (with FedEx) and that basically quadruples the price.3/4" Black Melamine is pretty heavy, even heavier than 3/4 plywood. With 2 sheets of melamine, it'd be pretty close to the limit... plywood should be able to keep under the limit maybe.I was thinking about this myself, for my pinball cabinets. If the price is prohibitive, try packaging the larger items separately, to bring the price down. Sure, you'll be almost doubling your regular shipping costs, and increasing the risk of lost/short shipments, but you should be able to get your packages in under the weight limit.Source: I worked for Canada's largest courier company for over 13 years.
Hmm... that's a thought. Put the 2 sides together in a largish box, then the rest of the parts in smaller box #2. Each one would be well under 150 pounds.
Quote from: HaRuMaN on September 17, 2013, 11:06:01 amHmm... that's a thought. Put the 2 sides together in a largish box, then the rest of the parts in smaller box #2. Each one would be well under 150 pounds."Thank you for shopping at Rick's Shipping Tips. Helping out the competition since 2013."
Glass not included, but is available online for around $80 shipped.
Quote from: HaRuMaN on September 19, 2013, 05:02:16 pmGlass not included, but is available online for around $80 shipped.Is that price coming from you, or a different source? Any opportunity for smoked/tinted?
