Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 989375 times)
0 Members and 7 Guests are viewing this topic.
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #2320 on: April 20, 2016, 10:15:37 am »
Actually, try "haruscouch" and see what happens...
I think you have to provide artwork and work the ZapCon booth to be eligible  ;D
I get paid handsomely........
in harubux
CobraX83
  • Last login:December 20, 2019, 05:29:01 pm
« Reply #2321 on: May 17, 2016, 11:53:52 am »
I came across the template's for Haruman's single player Degenatron on page 11 of this thread and was curious if someone can confirm that these will be the correct one I need before I start working on it!
If someone can post the marquee png and bottom control panel png that would be MUCH appreciated!
Thank you for any help!
spedinfargo
  • Last login:September 28, 2023, 12:53:23 pm
« Reply #2322 on: May 21, 2016, 11:52:00 am »
Just got my kit in the mail and a couple questions before I actually start gluing.
1.  There is a slot for each of the two control panel batons.  However, the baton itself isn't long enough to fill the whole slot.  Do you slide the baton closer to the front of the cabinet or the back of the cabinet before gluing it or does it not really matter?  See attached picture for what I mean...
2.  I understand that the back panel is held either by a hinge or velcroing.  But what is that back slot for?  It's not as deep as the other five so I'm not sure what it's for.  See the other picture for what I'm talking about.
  • Last login:December 19, 2025, 12:57:19 pm
« Reply #2323 on: May 21, 2016, 12:02:09 pm »
Just center the batons in the slot, doesn't need to be super precise on those.
The long batons go in the shallow slots on the back, they just prevent the back door from getting pushed in.
Sent from my SPH-L710T using Tapatalk
spedinfargo
« Reply #2324 on: May 21, 2016, 02:09:05 pm »
Wow!  Thanks for the quick, response.   I may have been overthinking the batons because I'm still a bit unsure how the plexi fit works (thought I saw one post talking about wedging the plexi between the back of the speaker board and the control panel.
Mystery slot solved.
Thanks again...
Charlie97L
  • Last login:July 03, 2017, 03:35:56 pm
« Reply #2325 on: May 21, 2016, 03:33:05 pm »
Ordered my kit!  Very excited.
I also scored a 19" dell on CL for 10.00.  I don't know what got me more excited.  :)
« Reply #2326 on: May 21, 2016, 03:39:13 pm »
The bartop of course! ;)  :cheers:
Charlie97L
« Reply #2327 on: May 21, 2016, 04:15:37 pm »
Indeed.
I'm stoked because the money I saved on the monitor will allow me to get a SLG now.  :)
But yeah, man I did a lock/cam kit for my ex a few years back and the quality on yours seems so much better.  I'm honestly excited.
And once I get everyone in the house hooked it'll be cocktail time.  :)
Charlie97L
« Reply #2328 on: May 23, 2016, 11:54:32 am »
As I'm assembling my parts list...
Are these too thin on the CP to use flush-mount joystick kits with the T nuts?
No problem either way, just curious!
« Reply #2329 on: May 23, 2016, 01:36:04 pm »
So I do have some threaded inserts I've been playing with, they mount from the bottom and you just screw into them.  I press them into the control panels with an arbor press.
I'm considering making them a standard feature (or maybe an optional one), it would add a little cost due to the hardware.
Charlie97L
« Reply #2330 on: May 23, 2016, 07:58:52 pm »
I would definitely be down to add that on.
gonzo90017
« Reply #2331 on: May 24, 2016, 09:04:15 pm »
Do you have any plans to sell Jukebox kits?
SNAAKE
  • Trade Count: (+29)
« Reply #2332 on: May 26, 2016, 02:42:01 pm »
random weeweecade sighting :burgerking:
« Reply #2333 on: May 26, 2016, 03:23:15 pm »
That's always a possibility.  Next up for new designs though is a mini virtual pin kit.
« Reply #2334 on: May 26, 2016, 03:37:17 pm »
lol nice!   :cheers:
Charlie97L
« Reply #2335 on: May 26, 2016, 09:47:17 pm »
Oh no.  Well, the future!
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« Reply #2336 on: May 27, 2016, 11:48:38 am »
I still want to do a Q*BERT soon..
anybody done one yet?
« Reply #2337 on: May 27, 2016, 12:37:07 pm »
That would make a good looking bartop...
Charlie97L
« Reply #2338 on: May 29, 2016, 02:53:41 pm »
I'm so excited. :)
« Reply #2339 on: June 07, 2016, 01:14:57 pm »
New kit added to the store:
http://shop.harumancustoms.com/index.php?route=product%2Fproduct&path=59&product_id=71
(and yes, floriske's permission was obtained first)
wildbil52
  • Last login:June 24, 2020, 04:59:40 pm
« Reply #2340 on: June 17, 2016, 11:33:58 am »
My kit showed up a few weeks ago.  Looks awesome.  Artwork printed and applied, will finish wiring the cp tonight.  Mobo, cpu, memory, and PSU should be here on Saturday.  I'll post pics once its mostly together.
I was thinking about attaching the back panel using only 4 magnets, no hinge.  Basically I would attach two vertical wooden handles (you'll understand when you see the theme) to the back of the door so I can just pull the door off the back and set it aside  if I need to get into the machine.  The magnets need to be strong enough to hold the door on by themselves, though.
Considering these:  https://www.amazon.com/Extra-Strong-High-Magnetic-Catch/dp/B009ZTQUPQ/ref=sr_1_8?ie=UTF8&qid=1466177553&sr=8-8&keywords=cabinet+magnets
« Reply #2341 on: June 17, 2016, 11:40:37 am »
That should work, although it seems like a little overkill, you could probably get away with smaller latches.
wildbil52
« Reply #2342 on: June 17, 2016, 11:54:44 am »
Yeah, thats why i haven't pulled the trigger yet.  The magnetic latches I saw at the local hardware places all seemed very weak so I wanted to find something slightly heavier duty than the standard ones.
BDS
  • Last login:July 18, 2016, 07:23:04 am
« Reply #2343 on: July 06, 2016, 07:46:20 am »
Hi I'm new here. I had a couple of questions and I'm not sure it's in the forum and has been answered already, sorry in advanced if it is.
My questions:
What button size would I have to purchase for Haruman's Ultimate widesreen Bartop? Does Sanwa sell Led joysticks and Led buttons that could be used in it?
Thanks.
« Reply #2344 on: July 06, 2016, 12:14:38 pm »
It's designed for Sanwa JLF (x2) and 30mm Sanwa OSBN (screw type, x 16) and 24mm Sanwa OSBN (screw type, x 6).
Don't know if there are LED versions of those available or not.  If not, I can always change the button / joystick holes to what you need.
BDS
« Reply #2345 on: July 06, 2016, 02:52:20 pm »
Thank you for the information. No need to modify the bartop in my case ,those dimensions are perfect.
rincewind
  • Last login:August 06, 2016, 06:44:36 pm
« Reply #2346 on: July 09, 2016, 07:56:35 pm »
My first post here. I was much more active on a Pinball cabinet sites but then decided to go ahead and build my own arcade bartop cab. I was a longtime arcadecontrols.com lurker - never registered on forum but always found my answers here through a google search :)
Anyhow, I want to thank HaRuMan for the CNC widescreen plans which I intend to cut on my own. Frankly, I'd go straight ahead and buy a pre-cut cab from you, but I live on the other side (Europe) and the shipping would cost me a fortune and money is tight now eh. :) So I decided to find a local cnc guy and try my luck. :)
Since I haven't bought a cab directly from you, I still hope I'm eligible for some forum help if I come across any "gotchas"
Thanks again
« Reply #2347 on: July 09, 2016, 08:49:04 pm »
Sure thing.  Just let me know if you have any questions! :cheers:
rincewind
« Reply #2348 on: July 10, 2016, 02:28:24 pm »
OK quick question, would I have to alter the plans for a 18mm thickness of MDF sheet? I think the only change should be the thickness of routed holes (for the horisontal plates) on the inside panels?
mR_CaESaR
  • Last login:July 04, 2024, 10:40:13 pm
« Reply #2349 on: August 26, 2016, 10:08:05 am »
Managed to find this thread through the wonders if google and I would like to thank you for openly distributing the cad file.
I've recently gotten access to a CNC machine and I am hoping to get one of these built up.
I'm hoping to extend the width by 10 cm or so, so I can fit 2 players and a 19" dell monitor. Not too worried about being "cramped" as the target audience are my kids :)
« Reply #2350 on: August 26, 2016, 10:09:56 am »
Hey there.  Good luck!  I also have the widescreen version posted on the first page, it's already wider and 2 players.  Don't know if you saw that one or not.   :cheers:
Post pics!
mR_CaESaR
« Reply #2351 on: August 26, 2016, 10:18:22 am »
Post pics!
I did see that, but it's too wide for me. I want to put a 5:4 screen in and I feel the WS version will look too odd with excess bezel on the sides
I'll definitely post pics once it's all done (it'll be a while, I need to try and learn how to modify this in solidworks or something equivalent). Configuring the retropie atm to make sure it's perfect once it goes in to the bartop.
I think I'm also going to want to modify the panel a bit so it's Sanwa OBSF30/OBSN30 and JLF compatible with the correct 25mm height.
mR_CaESaR
« Reply #2352 on: August 28, 2016, 12:58:20 am »
Finally managed to through the whole thread, and I found this...
Here's a rare beast. Someone wanted a widescreen in white, just shipped it to Tasmania, Australia this morning.
Out of curiosity, how much did this cost to ship down under?
« Reply #2353 on: August 28, 2016, 03:01:11 am »
That was $155 (ouch)
mR_CaESaR
« Reply #2354 on: August 28, 2016, 03:44:07 am »
Yes. Ouch is a great way to explain it.
After spending a few hours yesterday trying to muck around in solidworks, I realised even though I have access to a CNC, I have no way of being able to edit the file :)
The thought crossed my mind about getting one shipped over here to Sydney. After all the mods, I'd want, it'll end up costing a pretty penny :)
How customisable are the control panel options?
« Reply #2355 on: August 28, 2016, 10:28:11 am »
Can customize to anything you want.   :cheers:
« Reply #2356 on: September 04, 2016, 03:56:46 pm »
New coupon now through end of September.  $10 off a purchase of $100 or more.  Code is:
BYOACSEP
  • Last login:December 21, 2025, 02:02:09 am
« Reply #2357 on: September 04, 2016, 06:30:58 pm »
I heard a rumor if you type in the word COUCH as your code, you get to stay at HaRuMaN's house for free during ZapCon .
All kidding aside, that's a good deal. You should jump on it, people.
« Reply #2358 on: September 04, 2016, 06:48:40 pm »
That only works for a select few...
« Reply #2359 on: September 04, 2016, 06:52:46 pm »
SHOW US YOUR COUCH!
