Author Topic: New Product: OMNI2™ Below Panel Switchable 4/8-way Joystick - GroovyGameGear  (Read 29253 times)
RandyT
    • GroovyGameGear.com
The OMNI2™ from GroovyGameGear is a true 4 and 8-way switchable joystick, with positive restrictor tension adjustments, a standard mounting plate, and full compatibility with a wide range of balltops / battops and our SmoothJoy™ switches.  It even has an easy to use handle for changing the restriction.  More info at the GGG store (just click on the image above).
Here's the action from below;
Thanks for looking and thanks again to those whose purchases support GGG's ongoing efforts to bring useful new items to the BYOAC community.
RandyT
SavannahLion
How long do you figure someone pops off that handle to add a tab or tongue style handle so it sticks out of the cab so it can be changed on the fly.
Or mods the sucker to add a nice linear driver or small hydraulic push/pull rod to change it automatically?
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
so do you need to loosen the 4 screws each time you want to turn it or how does it work?  Looks like a JLW type stick.  Could i use that restricter on my JLW stick?
danny_galaga
  • Last login:Yesterday at 07:17:04 pm
    • dans cocktail lounge
The tab through the cp is an earlier product from GGG. For the second statement, you need only use a $10 RC servo. I thought about doing that with my Sanwas ages ago, and I think actually someone here has done just that. I think he might have used pushrods, but you just have to have a wheel on the servo rather than a bellcrank, and the wheel can drive against the plate directly.
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
This thread here: http://forum.arcadecontrols.com/index.php?topic=104762.0;all
RandyT
No need to loosen screws, just grab the handle and rotate the restrictor.  It is a JLW-type stick, but it has been rebuilt to properly support the restriction switching function.
RandyT
SavannahLion
IIRC the switch is through the top. I was thinking through the side. I'll have to check out the servo idea.
Gray_Area
  • -Banned-
  • -Banned-
Randy, and I mean this with sincere curiosity, did you do or find any market research on the possible popularity of this feature?
-Banned-
darthpaul
  • Last login:February 11, 2026, 08:01:39 am
  • Join, It's your duty
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
RetroBorg
Randy, this looks like being a great new product, I think I would prefer this over Ultimarc's MagStik simply because it comes standard with a ball top and you have heaps of different ball top options.
What I'd really like to see from someone, is a joystick like this with the integration of a servo for automatic switching with the ability to have both a computer control it, or for those people who have 60 in 1 type PCB setups, have the ability to switch simply by pressing a push button.
Any chance you might produce something like this one day Randy?
danny_galaga
Dude's gotta turn a buck! Imagine how much R & D would go into that, only for maybe 20 people in the whole world to buy it?
RetroBorg
The whole 4/8way is the biggest problem with any of those Xin1 PCBs not to mention anyone building a MAME control panel.
I would think they would instantly be the biggest selling joystick making nearly all other joysticks obsolete.
I wouldn't think R & D would be all that much, you would just need some minor adjustment to the joystick's mounting plate to mount an off the shelf servo with a cog that fits nicely against the cog like edge on the current restrictor.
As far as the controller goes, there's plenty that will do the job for MAME but as far as one suitable for an Xin1 I have no idea but I'm sure for someone as smart as Randy this wouldn't be a problem.  ;)
RandyT
I do market research every time I read our customers' emails, evaluate our products sell through rates, and visit these forums.  I also look at my own needs for machines I own, look at what is currently available to fill them, sometimes shake my head a few times when I see what is being offered, and start spending money on prototype parts to make my visions a reality.  Keep in mind also that sometimes markets don't exist until someone breaks away from the current way of thinking and moves things in a new direction.  Had I based everything I developed on existing market demand, there would have been no interface based electronic joystick restriction, high resolution button-hole mounted spinners, High resolution RGB trackballs, RGB lighted pushbuttons and their associated controllers, etc.  This design isn't quite so revolutionary, but it is useful and I believe it will make some folks very happy, either on it's own, or as has been mentioned here, as a base for an automated switcher or other "non-below panel" switching mechanism.  I also don't care if a new design flies off the shelf like gangbusters.  I'm in it for the "long haul", so if I can help a small percentage of the community (keeping in mind that it is always growing) with a new design, then I will be happy.  After 9 years of doing this, I think it's pretty reasonable approach that benefits everyone. :)
I don''t think the cog idea would work well.  There is no center to rotate about, so all the force would be on the side of the screw.  This would equal binding and burnt servos.  But the handle on this design offers a lot of possibilities.  I have a box full of servos (who said it wouldn't cost much for R&D  :laugh:) so when my laser gets set back up, I'll be looking at this again.  Longevity and safety are my biggest concern with regard to servo use.  Had I not seen one melt into a blob, I would probably be a little more "gung-ho" on the idea.  To the folks who have used servos: What have your maintenance requirements been like?  Has it been trouble free, or something that needs tinkering?  Or have you scrapped the idea and gone back to something more reliable?  I see a few have done it, but so far, not too many updates on the project 6 months after reasonable usage.
RandyT
Wow, when I suggested something that would "help a small percentage of the community" at the beginning of the year, you compared it to catching mosquitoes with a mouse trap, and said it wasn't worth the effort. Fortunately, a mosquito trap was released shortly after (gotta love coincidences) and it seems to be doing well. Your tune seems to have changed since then...
Anyway, I fail to see the appeal to this. You turned an underpanel manual switchable restrictor into an underpanel manual switchable restrictor? Is the plastic stud the main feature? If you're going to be placing your hand so close to the restrictor, why not just use the edge of the restrictor to turn it? Or is the restrictor mounting hardware the main feature? Are the restrictor mounting studs lock-tited into the holes? Otherwise, those nylock nuts won't be doing much. One thing to take away from this is the large OD nylon washers, should provide a lot of insight for the DIYers, I seem to recall a recent thread asking specifically about that. Convince me why I should use these instead of JLWs for my next project.
RetroBorg
RandyT
It's good to see you will be looking at the servo option.
The servo project I tinkered with was just a proof of concept build I used on a mock up panel.
I haven't used mine for a long enough period to give any advice of maintenance.
When I finally get around to building a proper control panel I do I intend to use a servo.
My project had one servo switching two joysticks at the one time and it seemed to switch them both effortlessly despite my poor mounting of the servo.
I discovered using one servo to switch two joysticks at once that you need the centre of the servo aligned perfectly with the centre of the two joysticks, something that probably isn't an issue when switching just one joystick.
Perhaps even if you could design your Omni2 joystick so it had some sort of universal mount for servos so people could attach them easily if they wanted to.
I used this servo on mine: http://www.robotgear.com.au/Product.aspx/Details/421
With this controller: http://www.robotgear.com.au/Product.aspx/Details/403
RandyT
Good to hear.  I'll be waiting to hear how things hold up for you.  I have been monitoring the RC websites where these are used often and hear a lot of conflicting opinions and reviews on the same servos.  The only thing I come away with is more expensive usually (but not always) equals better, and that you still could get a wonky unit, even with those having high ratings.
I prefer to have the restrictor be a little tighter than what the smaller servos could easily and reliably turn.  It may not be necessary with a custom controller and some good logic.
Nifty looking parts!  That controller looks well suited to the application.  Seems like some pretty intelligent software can be developed to get around the possible problems.
The servo you have may be better than most of the ones I tested, only because of the price point I was shooting for on the complete assemblies.  I do think a nearly bulletproof design can be made, but my biggest concern is what the market would bear cost-wise for a stick with this feature.  As would be expected, the lower the cost, the better the market, but on something like this, reliable and inexpensive tend not to go hand in hand.
What would you pay for a stick and controller with this feature?  (question open to anyone :))
RandyT
Gatt
  • Last login:February 04, 2020, 08:24:38 pm
RandyT
What would I pay?  I would probably buy it at $100 USD/stick.
I would definitely buy 2 at $50 USD/stick.
My holdback would be that I'd want at least 2,  since it'd be in a double joystick setup.  $100/stick would make me hesitate,  $50/stick would be an immediate buy for me.  Anything over $100/stick would probably be a pass for me.
While we're on the subject of possible ideas,  Randy,  have you ever considered offering modular boxes and panels for sale?  Perhaps that metal setup I've seen where you drop bolts through to secure them?  Seems like you're one of the few with the machining resources for a project like that.
A auto-switching 4w-8w and a prebuilt modular setup are my two dream items for this hobby
Edit:
I lied.  A marquee shaped LCD panel is my third dream item!
« Last Edit: November 20, 2011, 11:45:00 pm by Gatt »
RetroBorg
RandyT
I guess an Ultimarc UltraStik 360 sells for $59 each, so I reckon if you could get close to this price with an auto changing physical restricted joystick you would have a very competitive product for the arcade enthusiast.  ;D
Other things I would look to see are hollow shafts so people could customize them anyway they want, like light them up, add fire buttons etc.
Also be nice if you could mount one your nice Tron handles on it.
I don't want much do I?  :lol
RandyT
My "tune" has not changed, and your timeline is in error.  I have no desire to copy a competitors existing product, when doing so removes valuable and popular features from my own. Period
I'm not sure which sticks you are referring to, but I believe you are mistaken.  The JLW-style units are not "underpanel manual switchable" as stock items.  They are designed to be fixed as either one or the other at installation time, and left that way.  I think I stated above that the OMNI2™ units have been "rebuilt to properly support the restriction switching function", and that it has "positive restrictor tension adjustments".  The switching grip (no small nor inexpensive design endeavor on it's own) also makes it much easier to change the restrictor position when reaching blind under a panel, and even when not.  It also, as already mentioned, lends itself well to modification toward an external activation.
I have no need or desire to "convince" anyone to use the OMNI2 over a JLW, or any other stick.  I am simply presenting it as an option to those who can recognize the merits of this very functional package, and are grateful someone bothered to put in the time and effort to offer it to them.  If I have to try to convince you, then they aren't what you are looking for.
RandyT
  • Last login:February 11, 2026, 09:22:22 pm
nice Randy...
is this what slowed down the novagems?  ;D
jasonbar
  • Dr. Inferno
    • The Infernolab
Randy-
I have 2 Ultimarc Mag-Stik Pluses & I do like them.  My only complaint is the short throw of the sticks.  How does the throw of your OMNI2 stick compare to the Mag-Stik Plus throw?
Thanks,
-Jason
LeedsFan
This looks like a cool product I would consider buying. I had the older style T-Stik Plus from Ultimarc but found the throw way too short and stiff, but they were switchable from the top of the panel. If I were to buy these it would be so I could extend the little handle somewhat (but not too much) and have it so I can switch subtly from below the panel. Any extension would need good support around it so it couldn't flex or snap outside of it's path of travel.
So... how long is that little handle? About 10mm? And could it be changed or extended even if it was a home DIY job? Does it just screw in there or is it permanently glued in place?
RandyT
Longer and less stiff.
The handle is 3/4"+.  That's about 19mm.  I strongly advise against making it longer, as the directional forces would be altered, and may cause issues.  With a 3/4" handle, there should be more than adequate length anyway.  It is not permanent, but it is designed to stay tight, and needs to be kept that way for overall strength.  Any modifications should consider the handle as permanent, and interface with it.
RandyT
Still wondering about this one. It's a pretty important part of the design, just to ignore the question. Because if someone wanted to loosen the tension on the restrictor, and those studs didn't have a thread locker in the joystick base holes, there would be a good chance that the stud would start to back out of the hole before the nut backed off the stud.
If you don't have enough confidence in a product to try to sell it to a skeptic, the skeptic will remain skeptical. Still don't see the major advantage of this over just installing large OD nylon washers on the restrictor screws of a standard JLW.  :dunno
I don't know about you, but when I see screws or bolts holding something together, I view it as being designed to be taken apart, changed up, and serviced at will.
« Last Edit: November 21, 2011, 05:27:46 pm by Nephasth »
RandyT
"Positive restrictor tension adjustments", means the tension won't change unless you want it to.
If an individual is skeptical, they should save their money until someone less skeptical (and whose opinion they trust) buys one and offers an opinion.  I can extol the virtues of the item all day long and it will have no impact on such an individual.  But I'll give it a go because you seem to want me to;
If you have trouble finding or getting a grip on the restrictor under your panel, or keeping it tight enough so it won't move or loosen when you don't want it to, or getting sore fingers because you have to turn that tight (because you don't want it to move) SOB with whatever small portion of the sharp plastic cog that happens to be accessible, or you want an easy way to interface an external or automated switching device, or are just looking for a great, true 4/8 way switchable restriction capable stick, compatible with a wide variety of tops and switches, with a standard mounting plate design that makes it a drop in replacement for existing older sticks, without all the fuss and at a very good price, then the OMNI2™ is just what you are looking for.
But now I'm going to go and spoil my sales pitch....If none of those things are important to you, then move along...these aren't the droids you are looking for.  :droid
At will, perhaps.  On the fly?  No.
RandyT
ark_ader
  • I glow in the dark.
I picked up a stick very similar but it has an additional 2 way capability.
Is there ever any need for a 2 way for sticks of this size and if so can you implement this on your product?
NSS. Side stepped the question again... Is there any thread locker on the threads of the studs that engage the threads of the mounting holes?
TheShanMan
    • My Arcade (updated 1/30/13)
If you added 2 way capability that would certainly make it that much more appealing!
I have U360's as my main joysticks so I'm not sure how prone to switching I'd be if auto-switching was added (or was auto-switching ready), but I would have certainly been willing to pay around the same cost as the U360 for an auto-switching setup if I were to start over. And even with my U360 panel, I'd consider making a new panel with these (I have a swappable panel setup).
As for comparison to the mag stik plus, I've also got a panel with one of those and for all intents and purposes I consider it to be a dedicated 4 way joystick. The throw is just too short for me to accurately use it as an 8 way. So my opinion is this would have a big advantage due to the longer throw.
All that said, I'd be content to stick with my U360's as long as this doesn't include or at least support auto-switching. Nice new product offering though, Randy!
RandyT
2-way restriction has a fairly limited practical application.  The 4 way restriction is usually more than adequate for those games, as not too many, outside of possibly those with severe neuromuscular disorders, will lack co-ordination to the extent of accidentally hitting up or down, when intending to go left or right while in 4-way restricted mode.
A short throw is actually desirable for a 4-way.  I've always stated that a stick like the OMNI2, OMNI-Stik, etc.. is a tradeoff in that regard.  They will necessarily work backwards from the ideal, as the distance between two flats of the square shaped restrictor will always be shorter than the distance between two corners when rotated to a 4-way diamond.  What is important is that a good compromise is struck in that the 8-way throw is not overly short and the 4-way throw is not overly long.  This stick seems to do that quite well, by balancing the shaft length, switch position, actuator size and restrictor shape so that both are quite good.
RandyT
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Well on our J-Stik which has been around for many years we use nylon washers, springs between the screw heads and washers to apply pressure and a low-strength threadlock which allows adjustment. Would guess similar here.
Thanks for that Andy. That's something I didn't know about the J-Stik. I had to go back to your site to check it out, and only found a pic showing the nylon washers and this sentence: "All of our joysticks are supplied to our specs for 4-8 way switching without any dismantling." An understated feature of your sticks. Never caught a hint about the springs under the screw heads, but maybe I'm still overlooking it on your site.
That also puts a whole new meaning to following:
First one to put out an auto-switching-physical-restrictor joystick that hooks up to Mame is going to be King of the joystick castle.
That being said, I'm glad that you guys are still coming up with new products, and I enjoy seeing the Randy, Andy and Bryan dynamic in each-other's threads. :lol
RetroBorg
Couldn't agree more.
  • Last login:Yesterday at 03:35:47 am
Only if there's a rubber grommet involved!
Donkey_Kong
    • CNC Machines
what would happen if you had a setup like
What happens if you are in 4-way and it's trying to turn to 8-way and your 6-way year old has the stick pointed straight up and it can't turn?
RetroBorg
I doubt whether your 6 year old would be strong enough to stop it switching.
Donkey_Kong
    • CNC Machines
where do you go to buy a little motor for something like that? Is there anything plug and play out there that would work? This is just curiosity, I really have no intentions of trying it but it would be a cool thing to check out.
I think you are right, the leverage on the stick vs force from a motor locked onto that restrictor should be like night and day.
Gray_Area
  • -Banned-
  • -Banned-
The following is what I (and Nephasth) had in mind, initially, in comparison:
http://retroblast.arcadecontrols.com/reviews/joysticks/ultimarc_jstik.html
And the questions, then, were: how often are you going to do this?....how easy will it be?
« Last Edit: November 22, 2011, 10:51:02 pm by Gray_Area »
-Banned-
RetroBorg
I bought mine from here: http://www.robotgear.com.au/Product.aspx/Details/421
AndyWarne
    • Ultimarc
We added the springs between the screw heads and washers around 6 months ago. I mentioned this on this thread:
http://forum.arcadecontrols.com/index.php?topic=115592.msg1225760#msg1225760
I still need to update the pictures to show the spring version.
Andy
