Author Topic: Re: Tron Mini/Cabaret (aka TMC) scratch build - - - FINISHED! - - -  (Read 40619 times)
shrunkenmaster
Thought I'd share the construction on my Tron Mini/Cabaret (aka TMC). Firstly I'd like to point out that I wasn't aiming for a 100% accurate TMC here, before anyone rips me to pieces! Secondly I'd like to thank Triangel7D, HarumaN, Hoopz and particularly Encryptor for help along the way.
Many moons ago I picked up a Xenophobe stick with the intention of making a TMC at some stage. I grabbed a Tron restrictor from Encryptor (Restryptor?) soon after and it all got forgotten about until recently. Encryptor provided some handy measurements which I scaled down slightly - my room has a stupidly small door and I wanted the option of moving the TMC out.
Anyway, got the sides cut out and primed:
« Last Edit: September 14, 2010, 04:37:54 am by shrunkenmaster »
shrunkenmaster
« Reply #1 on: May 26, 2010, 03:51:43 pm »
Next my Midway coin door turned up, extremely battered. After some heavy filler action and several coats of spray primer and paint, I'm pleased with the outcome. I got a replacement Midway badge from arcadeshop.com too. Still have to get the coin insert artwork printed and applied though.
shrunkenmaster
« Reply #2 on: May 26, 2010, 04:00:13 pm »
Got to work on the CP next. Some time ago I got a full-size Tron control panel complete with spinner, one player button and a Wico joystick. Encryptor kindly supplied another play button and the metal control panel was then donated to Ninten-doh for his project.
I got to work routing some MDF to accept the spinner and Xenophobe stick. I had to mount the two player buttons onto some plexi as I couldn't route the MDF thin enough while giving enough strength (I hope this makes sense).
I then glued the two parts of the CP and routed the join with my roundover bit for a nice curve.
« Reply #3 on: May 26, 2010, 04:09:14 pm »
I've always liked your projects shrunkenmaster, looking forward to seeing this one completed to the quality of your other cabinets! Keep up the good stuff!  :cheers:
shrunkenmaster
« Reply #4 on: May 26, 2010, 04:11:31 pm »
Back to the cab. Got the structure together and did the usual filling and sanding.
Moved on to the speaker panel. I found some BMW car speaker grilles which looked close enough to the originals - only a couple of pounds from the 'bay.
Sanded and painted the panel, attached the speakers, then had a (sort of) brainwave. I thought it would be cool to have a UB blacklight on the cab, just like a full-size Tron. I realised i could have it on the speaker panel, shining down onto the CP, so I cut a slot and returned to the 'bay for some UV goodness.
I also got the marquee light attached - more of that later once my camera is charged again so I can take some pics.
shrunkenmaster
« Reply #5 on: May 26, 2010, 04:17:57 pm »
Keeping in line with the original cabaret, I went for the woodgrain look. Being born in 1970, everything I grew up with was covered with this, so I don't mind it! I used self-adhesive vinyl as laminate in the UK is a ---smurfette--- to find and expensive.
I began with the coin door panel, then moved onto the sides of the cab. This stuff goes on SO easily, so long as the surface is clean and smooth. Trimming and folding the edges over takes a little time though.
Got the t-molding on too. I didn't bother with castors on this build, but the t-molding lets me slide it around quite easily. Mind you, there's no computer or screen in here yet.
shrunkenmaster
« Reply #6 on: May 26, 2010, 04:22:37 pm »
At this point I couldn't resist a test fit of the replacement Tron handle from GroovyGameGear. It really is very nice - I must thank RandyT here for a great niche product :)
shrunkenmaster
« Reply #7 on: May 26, 2010, 04:26:50 pm »
I was going to use this old laptop (seen here testing my MALA layout) but I managed to kill it trying to extend the power switch. I have a cheap £20 'bay PC that will do the job instead.
Next time -  The "How the hell am I going to vertical-mount the PC CRT monitor without decasing it" issue.........
« Last Edit: May 26, 2010, 04:32:14 pm by shrunkenmaster »
shrunkenmaster
« Reply #8 on: May 26, 2010, 04:30:55 pm »
Thanks, my man. This would have been finished a short while ago, but I can't get the damn monitor mounted right. It wouldn't be a problem if it was a horizontal mount, but the casing is proving a real challenge when it's vertical. I have no intention of decasing this myself (I'll happily dissect anything else electronic), so I'm thinking of taking it to a local TV repair man for a discharge. Then I only have to get the marquee & bezel printed and we're done-ish.
shrunkenmaster
« Reply #9 on: May 26, 2010, 05:07:56 pm »
Just noticed my "itch with a capital B" got replaced with a "---smurfette---" - I had no idea this was automatic, I always thought it was the poster that chose to type that!!! You learn something new every day, eh?  ;D
Encryptor
  • Trade Count: (+34)
  • Last login:Yesterday at 07:22:51 pm
« Reply #10 on: May 26, 2010, 08:27:44 pm »
It's very nice looking dude! In one picture the vinyl looks like the original and in another one it looks darker. Guess I'll have to see what it looks like against the original when I get the scrap piece you're sending me. Looks sweet though! Great job!  :notworthy: :notworthy: :notworthy:
shrunkenmaster
« Reply #11 on: May 27, 2010, 02:53:37 am »
The vinyl looks different in every photo I have! Yours is now at the mercy of the postal system again, hope it arrives this time.
njay
  • To Nudge or Not to Nudge !
« Reply #12 on: May 27, 2010, 03:00:45 am »
Nice Job on the Coin Door :)  :applaud:
Encryptor
« Reply #13 on: June 03, 2010, 07:34:20 pm »
I got it today! It's a little darker than the original. I taped it to the side of my cab and took the picture below.
Encryptor
Encryptor
« Reply #14 on: June 15, 2010, 05:39:45 am »
Any updates?
Encryptor
Encryptor
« Reply #15 on: June 25, 2010, 05:41:54 am »
Bump!
Encryptor
shrunkenmaster
« Reply #16 on: June 26, 2010, 03:35:35 am »
Gonna be a week or before I get back on this. Real life and work are getting in the way, but hopefully I will have a monitor for the cab real soon.
Encryptor
« Reply #17 on: June 26, 2010, 06:37:53 am »
Decided not to use the PC monitor? What size are you going to go with?
Encryptor
shrunkenmaster
« Reply #18 on: July 11, 2010, 02:12:37 pm »
Finally got a monitor for the TMC !!! It's a Kortek 14" open frame CRT, brand new:
Should be with me in a day or two. Will be needing help working out how to interface this, for sure...
« Last Edit: July 11, 2010, 02:16:01 pm by shrunkenmaster »
shrunkenmaster
« Reply #19 on: July 15, 2010, 03:04:28 pm »
Monitor arrived today, I've never seen a brand new open frame monitor before - very exciting - the temptation to plug it in, wet both my hands and touch every component is....  :timebomb:  :lol
I've posted some details in the Monitor forum as I have no idea how to connect this - please have a look if you think you can help:
http://forum.arcadecontrols.com/index.php?topic=104158.0
shrunkenmaster
« Reply #20 on: July 16, 2010, 12:29:14 pm »
Franco B has kindly explained connection of the monitor, so I'll build the monitor mount while I await the ArcadeVGA and breakout cable from Ultimarc. Can't wait to get a picture on the monitor - being 14" it looks just like a larger monitor that's been shrunk in the wash. Cute, if a CRT can be called that  :)
shrunkenmaster
« Reply #21 on: July 19, 2010, 02:37:06 pm »
Finished work a bit earlier today and got the monitor mounted. I used a few strips of hardwood left over from doing my garden - working with an open frame monitor is SO easy!
I've finished the rest of the graphics too - hopefully by the end of the week I'll have everything ready to finish the job.
Encryptor
« Reply #22 on: July 20, 2010, 05:36:47 am »
It's looking great dude! What angle do you have the monitor mounted at? From that last picture it looks like it's almost laying flat.
Encryptor
shrunkenmaster
« Reply #23 on: July 20, 2010, 08:39:41 am »
Hopefully this pic will show the angle better:
macattack
  • Last login:August 03, 2018, 05:35:16 pm
  • Cabinet builder to the stars!
« Reply #24 on: July 20, 2010, 02:54:04 pm »
looking great. Would be great when you get completed if you could do a laundry list of what was used to build it and where to get it... for those of us itching to build one now :)
Pm me for custom cnc needs...
jimmy2x2x
« Reply #25 on: July 20, 2010, 03:07:59 pm »
My sentiments exactly.  This is shaping up great, would also like to see a parts list with prices if possible
Cheers!
shrunkenmaster
« Reply #26 on: July 21, 2010, 03:38:37 pm »
Got the ArcadeVGA card today, all installed, no problems. Cheers Andy!
Now I can't seem to get the spinner working in MAME. I have a MiniPac Opti and the spinner moves the mouse cursor along the x-axis in Windows ok. I can't work out how to assign it in the WiniPac setup software.
I have the Analog Dial in MAME set to mouse X. I tried checking/unchecking the "use mouse" in MALA. Let me know if you need any more info.
Anyone?
(Also posted request for help in main forum : http://forum.arcadecontrols.com/index.php?topic=104327.msg1103740#msg1103740 )
« Last Edit: July 21, 2010, 05:11:57 pm by shrunkenmaster »
Encryptor
« Reply #27 on: July 21, 2010, 07:40:25 pm »
The angle is close to mine. I looked at mine and now I know what the difference I was seeing was. On mine the monitor is raised about 2 inches higher than the control panel.
Encryptor
shrunkenmaster
« Reply #28 on: July 27, 2010, 04:45:28 pm »
What a nincompoop, I was editing the mame.ini of a test version of MAME I had previously installed. NOW the spinner works.
Anyway, here's a shot of the beast all fired up.
I have installed some tinted acrylic over the screen, which will eventually have the bezel artwork on top, followed by another layer of clear acrylic. Still need to get the marquee printed, but at least it's all up and running. I will be posting some more construction pics as time allows, being busy with real life at present.
I must say this is the first time I've enjoyed playing Tron since I first played it in the arcade back in 1982. It was my friend Nigel's birthday and we went to the local cinema to see the film. Our local arcade was 2 minutes away and afterwards we went to play the machine that had been delivered that same day. What an experience!
« Reply #29 on: July 27, 2010, 04:54:45 pm »
So sexy.
I love this build!  :applaud:
shrunkenmaster
« Reply #30 on: July 27, 2010, 05:04:21 pm »
Gotta stop playing the damn thing now - the Midway coin door keeps saying it's still hungry, even though I've just fed it £4.60 (46 credits)! At least I can get my money back...
MikeDeuce
  • Last login:September 15, 2013, 04:38:38 pm
  • It does a body good.
« Reply #31 on: July 27, 2010, 05:07:18 pm »
Ooooooooooooooooooooooooooh :applaud:
Encryptor
« Reply #32 on: July 27, 2010, 08:32:38 pm »
Dude! It looks very nice! Great Job!
Encryptor
shrunkenmaster
« Reply #33 on: August 20, 2010, 02:25:20 am »
Had a BBQ the other day, the TMC got a good 'beta testing'...
Dom was pleased with his first game of Tron since the 80's:
Mark The 1942 King:
Giselle The Xevious Queen
Young Luke said "This is MUCH better than my Wii":
"Seasoned arcade pro's" getting whipped by young Luke:
Progress has slowed on the TMC due to me being knee deep in home improvements, plus my wife is now pregnant with first child - happy days!
« Last Edit: August 20, 2010, 02:31:15 am by shrunkenmaster »
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #34 on: August 20, 2010, 12:21:49 pm »
The force is strong in this one...
As you have already found out it is very hard to complete the cab with the control panel working.  The cab looks awesome by the way.
shrunkenmaster
« Reply #35 on: September 12, 2010, 01:25:31 pm »
Behold!  ;D
______________________________________________________
Parts List
Midway coin door - eBay
Kortek 13" CGA monitor - eBay
ArcadeVGA card (AGP version) - Ultimarc
Dirt cheap PC - eBay
Spinner from a full size Tron CPO - QuarterArcade
Xenophobe joystick - eBay
Tron joystick restrictor - Encryptor
Tron repro joystick handle - GroovyGameGear
CPO Overlay and spinner decal - arcadeshop.com
Marquee, bezel, coin insert graphics - weezagraphics.co.uk
Wood effect vinyl - eBay (vinyldepot-retail)
Acrylic sheet for marquee & bezel - Plastic Merchants, Brighton, UK
Fluorescent light fitting - local electrical store
UV blacklight tube - eBay
Mame with Mala frontend
I really enjoyed making the TMC. Tron's a good little game with the proper controls. I really love the size of cabaret/mini cabs and I'm planning my next - a famous vector game that wasn't made in cabaret form. What could it be, I wonder?  ;D
« Last Edit: September 12, 2010, 02:09:13 pm by shrunkenmaster »
Encryptor
« Reply #36 on: September 12, 2010, 01:49:50 pm »
Very nice dude! Looks like an original.  :cheers:
Encryptor
JustMichael
« Reply #37 on: September 12, 2010, 02:05:40 pm »
Now you have done it!!!  Everyone is going to want one (the Tron cabinet, NOT the curtains!).
shrunkenmaster
« Reply #38 on: September 12, 2010, 02:19:53 pm »
Thanks Encryptor, looking forward to seeing your build too (you certainly don't want pics of the inside of THIS one)
Thanks JustMichael, but show some respect man, curtains have feelings too! Believe it or not, they look a lot better in real life  ;D
« Reply #39 on: September 12, 2010, 03:18:52 pm »
Great work here!
The cabinet looks amazing!
I hear ya about the cabaret sizes, I'm really digging the smaller cabinets these due to space restrictions.
Let me guess, are you planning a Star Wars mini??
