Author Topic: i call her "bArcade"  (Read 68699 times)
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
« on: May 13, 2010, 04:59:41 pm »
EDIT:  pics updated, hopefully they are bigger
after lurking on here for years, i thought i'd post pics of my 90% completed cab.  i couldn't have done it without the help of this board and it's members, thank you all.
here is a full frontal, note the coin door.  also note the giant 10' screen on the living room wall behind the machine, more on that later:
the coin door is just a sticker, from groovy games i believe.  behind the sticker is a fridge for beer, hence the machine name "bAr-cade".  just to the left of the door is a bottle opener and volume knob.  to the right of the door is a pinball plunger for future pinball.
just below the marquee, between the speakers, is a small 9" fold down LCD.  that way i can still watch TV while playing :)  this small screen also has VGA in so i'm thinking in the future, it could display control cards for the game selected.  note that the screen folds down and when up, is held in place by magnets.
next up, a close up of the front of the panel.  slot loading dvd drive in the foreground.  if you look closely, you can see some lines in the background on the front of the panel (and the bottle opener just below the lines):
those lines i was talking about?  the front pops off and out drags a groovy games spinner.  i keep the wheel attachment close by so in 5 seconds, i can pull out driving controls:
from the side, you can see my guns holstered behind the panel, one on the left, one on the right (not pictured).  keeps them out of site.  also pictured, fold down drink holder, for the beers :)
in this downstairs pic, you can see the 10' screen, the 50" plasma below the screen.  top left, you can see my machine .  note that the machine clones it's image to either the tv or projector while you can watch another video source on the other screen.
and here are two pics of the end table i made (i still need to stain it).  one shows the table closed, the other with it open to put controllers inside.  on the table, back right, is a surface flush usb port.  this is where i have my xbox 360 controller (used as a mouse with xpadder for the desktop and as a game controller when in game) and keyboard plugged in to control everything downstairs.  there is also a hidden power button on the side so i can turn the beast on remotely.
and finally the control panel.  i'm thinking of rebuilding it, give it more of the classic arcade panel where the middle sticks out more.  that will give me a bit more real estate to add some stuff (thinking of adding 12 button key pads for consoles that use them)
all of the buttons and trackball light up with the excellent LEDblinky.  each player has two sticks (one top fire for each player), 8 buttons (plus start/coin) and a spinner; the trackball is shared.
the spinners are opposite each top fire with both top fires centrally located.  thought that would give me more control options, for two stick games with fire buttons.
also, i had a custom touchscreen panel built.  so the machine is also touch for my jukebox app.  works brilliantly with the touchmaster bartop games and also works great as a make shift light gun, touch what you want to shoot!
anyway, that's her.  let me know what you all think!
tony
« Last Edit: May 13, 2010, 06:08:01 pm by tony.silveira »
  • Last login:January 17, 2026, 09:30:46 pm
Re: i call her "bArcade"
« Reply #1 on: May 13, 2010, 05:47:13 pm »
Looks really nice but I have to squint!  Can you make the pics bigger?   :cheers:
TheGameFan
  • Last login:September 14, 2011, 12:21:42 am
« Reply #2 on: May 13, 2010, 07:04:00 pm »
That fridge is cool.
I am going to put shelves in my cab, since only about 10% of the space is actually used. I figure I can store games, movies, etc. in the empty space.
In the works: Full sized Capcom fighter cab, QBert Mini Bartop, Bartop JAMMA / MVS1, Centipede Cocktail restoration
« Reply #3 on: May 13, 2010, 07:27:52 pm »
The fridge and the bottle opener are great!
Why 8 buttons per player though? is that a console emulator thing?
tony.silveira
    • my baby
« Reply #4 on: May 13, 2010, 07:57:08 pm »
i'm still trying to think of a better layout for my updated panel.  but i did 4 across for my favorite system ever, vectrex.  also, neo geo has 4 across.
BurningBeard
  • Last login:September 06, 2019, 03:17:25 pm
« Reply #5 on: May 13, 2010, 08:03:42 pm »
That is awesome, brings a new meaning to all in one.  :notworthy:
tony.silveira
    • my baby
« Reply #6 on: May 13, 2010, 08:15:52 pm »
did i mention she acts as the speakers for my turntables, pictured to the right...
Joezero
  • Last login:May 06, 2018, 12:13:49 pm
« Reply #7 on: May 13, 2010, 09:18:07 pm »
This remnds me of an infomercial "but that's not all, it also...".
Do you have any more pics of the steering wheel setup?
tony.silveira
    • my baby
« Reply #8 on: May 13, 2010, 10:09:56 pm »
lets see if i can explain it, here are some pics.
first up, inside the control panel.  note the black box with metal pins sticking out of it at the front and back.  there are two wooden rails on each side to keep it straight.
and here is the black box removed with the spinner inside, one metal pin removed.
here is a close up of the front of my panel.  the front piece just pops off.
here is a pic of the box being pulled out.  note that the back metal pins drop down into a groove to add stability.
and here is the box, fully extended.  note that the pin on the front of the box has been pulled out and inserted further back.  this pin holds the box up at the desired angle.
here is the box, fully extended, pin holding it in place and wheel attached.
it's a bit ugly but works very well.  when i get around to my updated panel, i will be re-examining the design.  it'll still be a removable wheel from the front but it will be better implemented (guides, ball bearings to make it pull out smoothly).
« Reply #9 on: May 13, 2010, 11:15:59 pm »
That's a clever solution. Not necessarily pretty, but hey, it works! And you can always dress it up later.
Love that turntable collection. I finished ripping all my albums to mp3 some time ago, so I don't really use my table much anymore.
tony.silveira
    • my baby
« Reply #10 on: May 13, 2010, 11:30:34 pm »
i have most ripped as mp3's an even messed around with mixing from a laptop but it just isn't the same.  the tactile feel of vinyl on your finger tips can't be replicated.  haven't bought a record in years tho, talk about an expensive hobby...
« Reply #11 on: May 14, 2010, 01:18:35 am »
Bar fridge in a cab *slaps his forehead* of course!  why didn't I think of that?  Nice one.
tony.silveira
    • my baby
« Reply #12 on: May 14, 2010, 01:51:24 am »
i used to have the cab in the garage with the pool table, where i first started the project, and the mini fridge right next to it.  one day i was sitting there, looking at the cab with the original panel pulled off...
look at fridge
look at cab
back to fridge
back at cab
BRILLIANT
three circular saw cuts later... bAr-cade was born
  • Last login:January 18, 2026, 06:02:45 pm
« Reply #13 on: May 14, 2010, 07:39:24 am »
Best implementation of a cooler in a cab I've seen, even though the gamer in me can't really approve. Don't drink and drive.  :blah:
Shun
  • Last login:December 09, 2025, 05:14:48 pm
« Reply #14 on: May 14, 2010, 09:19:05 am »
Damn you beat me to it, i'm just installing my beer fridge into the base of my cab  ;D
Awesome machine, it seems to do everything!!!
Complete: Pac-Man Cabaret scratch build:
Project thread
Work in progress:
Two Phase Bartop With Flush Mounted Dreamcast. 75% Complete
Joezero
« Reply #15 on: May 14, 2010, 10:07:57 am »
Quote from: tony.silveira link=topic=102665.msg1087033#msg1087033 date=
[img
http://
That sounds like an ideal situation, using sliders and then perhaps some sort of ramp or guide in the bottom of the wheel to angle it once it's extended. Thanks for the pics and description, it's definitely getting the wheels turning (no pun intended). Is that a USB port on the side?
« Reply #16 on: May 14, 2010, 12:10:25 pm »
Do you have good ventilation to the refrigerator coils?
tony.silveira
    • my baby
« Reply #17 on: May 14, 2010, 06:08:02 pm »
yup, that is a usb port on the side.  come to think of it, i dont believe its a groovy games spinner.  i think it may be a tornado or some other old spinner i had.
you know that cover that i show that just pops off the front?  notice how it isn't square?  that extra notch on the left is to allow the usb cable to come out when the box slides out.
for my updated panel, the pic that i have of the inside of the panel, the two wooden rails that keep the box straight.  i'm thinking of having those made of metal.  then have the pins on the side of the box be rollers.  that should allow for a smooth roll.
the other design i had, but could never quite figure out, was having the spinner facing down.  that would make the top of the box flush with the front of the panel.  then you would simply pull the spinner up, rotate it up into place with a couple of pressure pins that when lifted into place, would extract on their own to lock the box in place.
as for ventilation on the fridge coils, it's ok.  i have some fans in the machine blowing air up with a couple of exhaust fans on the top of the cab drawing air out.  my pc with core duo2 e8500 at idle is running at 42 C
tony.silveira
    • my baby
« Reply #18 on: May 14, 2010, 06:16:47 pm »
hey shun, if you haven't done so yet, you may consider raising the fridge up a bit so that it's closer to the panel.
i wish i had done that so i could install those surface mounted pedals
tony.silveira
    • my baby
« Reply #19 on: April 26, 2012, 01:58:12 am »
newly added removable star wars yoke (based on 1up's design).  mostly the same, i used 3" corner braces internally instead of wood and my box has a bottom (hole cut out so the trackball pokes thru) which adds a bit of stability.
still need to finish it but couldn't wait to test it out :)  this sits right on top of my trackball so nothing need to be removed from the panel itself.
front edge of the box has some angled "claws" that hold onto the edge of the CP.  just need to add a screw in bolt along the player edge; that's what that little bit of lip is for under the yoke, that will lock it into place.  on the main panel, i have a brass "wood insert" that has threads, this is where the "clamping knob" will screw into.  i could supply more pics if anyone is interested.
the front edge "claw" and the brass "wood insert" will be a universal mount/screw in for future attachments (i am already sketching out a force feedback steering wheel attachment and also have some legs so i can use my "miracle piano system"
darthpaul
  • Last login:January 12, 2026, 08:59:11 pm
  • Join, It's your duty
« Reply #20 on: April 26, 2012, 08:46:02 am »
This is my kind of build  :applaud:
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
SNAAKE
  • Trade Count: (+29)
« Reply #21 on: April 27, 2012, 05:03:59 pm »
just when I thought Ive seen it all :cheers:
TheShaner
« Reply #22 on: April 27, 2012, 08:02:34 pm »
Good stuff.  I have been contemplating a couple of different ideas regarding multiple controls and attaching them when needed.  You have some really cool ideas and have executed them awesome here.   :cheers:
What kind of wheel is that?
TheShaner
« Reply #23 on: April 27, 2012, 08:13:38 pm »
Hey also, can you post a link to 1ups design you refer to?  I did some searching and couldnt locate it.  Thanks!
PIZZ
  • Last login:January 14, 2013, 10:24:17 am
« Reply #24 on: April 27, 2012, 08:44:57 pm »
Id stick a BBQ grill on top of that sucker and haul it off the next tail gaiting party!
« Last Edit: April 28, 2012, 02:44:56 am by PIZZ »
tony.silveira
    • my baby
« Reply #25 on: April 30, 2012, 01:02:17 am »
sure thing!
http://1uparcade.rmfx.com/projects-yokebase.html
as for the steering wheel, it is from groovy game gear and snaps right onto their spinner
here are a few more pics of the completed yoke attachment.
here is the panel sans yoke.  just under the trackball, you can see the brass wood insert
here is a close up of the yoke attachment sitting in place over the trackball.  you can see the knob that screws into the afore mentioned wood insert.  note the t-molding goes all around even on the bottom.  this will keep it from scratching up my panel
and here is a close up of the "claws".  these wrap around the front edge of the panel, close to the monitor.  then the front screws in and it's very solid
thats it for now.  although, i just found the perfect 12 key numeric keypads that i will be adding!  these will be for player 1 and 2 for consoles that had keypads
« Last Edit: April 30, 2012, 01:05:22 am by tony.silveira »
  • Last login:January 10, 2026, 01:53:23 pm
« Reply #26 on: April 30, 2012, 08:01:30 am »
Wow. you have some great ideas.
TheShaner
« Reply #27 on: April 30, 2012, 08:52:45 am »
Thanks Tony!  Good stuff.  How the heck did you find that Yoke??  Ive been looking for one for a while, they are not easy to come across.
tony.silveira
    • my baby
« Reply #28 on: April 30, 2012, 02:52:46 pm »
it was just perfect timing.  unclet put his list up for sale and I jumped right on it
« Reply #29 on: May 06, 2012, 06:50:07 am »
You know if that cab had a urinal on the front, you'd never have to pause the game...   ;D
tony.silveira
    • my baby
« Reply #30 on: May 23, 2012, 11:16:49 pm »
now with dual trigger sticks!  special thanks to Le Chuck for helping me out.
these trigger sticks aren't wireless, i made them a bit differently.  i surface mounted a 1/8 audio jack above each stick, the little silver circle in the picture.  from the base of the sticks, i have the male end phono plug wire coming out.  under the cab, the wire simply plugs into button 1 and 2.  the trigger sticks are Performance brand "raider pro".  these sticks are symmetrical and can be used by either the left or right hand
both the sticks and the ball tops use the magnetic attachment hack and i can't believe how solid they are!  i did do the trigger stick just a bit differently and i will be posting pics once i get the second stick in the mail and do the hack.  i did everything as in the wiki but instead of wrapping the putty around the joystick shaft, i put a brass tube in there that slides right onto the joystick shaft.  this way, the putty has hardened, sealing the bottom of the handle and with the plug in, i don't ever have to change a battery.
here are the two magnetically attached ball tops.  just above each are the phone plug receptacles
here is the first stick attached and plugged in
mebronx2000
  • Last login:December 25, 2025, 09:47:47 pm
« Reply #31 on: May 23, 2012, 11:28:41 pm »
 :notworthy: :notworthy: :applaud: :applaud: :applaud: :cheers: :cheers:
« Reply #32 on: May 24, 2012, 08:10:47 pm »
See, that wasn't so bad was it?  I'd paint the stereo cable to help it blend a bit.  Well done  :applaud:
If you have any tips or tricks that you learned along the way and feel would be helpful please update the wiki.  Thanks!  :cheers:
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:Yesterday at 05:42:53 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #33 on: May 24, 2012, 09:02:09 pm »
I like the stereo plug setup for its simplicity.
tony.silveira
    • my baby
« Reply #34 on: May 24, 2012, 10:38:38 pm »
yeah, next stick will have a black cable and it will plug in straight, not at a right turn.  that way, if someone yanks it, it will unplug cleanly.
wow, i've never contributed to a wiki :)  soon as i get my second trigger stick, i'll be taking photos so folks can see the brass tube that i used.
AGarv
« Reply #35 on: May 26, 2012, 09:57:24 am »
Very nice!  Could we also get updated shots of the full panel with the ball tops and trigger sticks installed?  I am a huge Robotron / SmashTV / Assault fan, so I really appreciate your layout.  Can you switch the trigger sticks between 4-way and 8-way quickly?
The only thing that might take some getting used to is the button placement for SF2/MK play - did having the buttons so far out of alignment with the joystick feel weird at first?
tony.silveira
    • my baby
« Reply #36 on: May 27, 2012, 10:41:31 am »
here are two shots, panel with ball top, panel with trigger sticks.
i will be replacing those center sticks with omni 2's and adding servos so that they will switch from 4 to 8 automatically.
you know, i never really notied an issue with the button / stick layout.  if i was champion sf/mk player, the placement probably would throw me.  but it was more important to me to get the center sticks aligned for the games you mention than to have a perfect layout for player 2.
tony.silveira
    • my baby
« Reply #37 on: May 27, 2012, 11:25:24 am »
got the second stick, here is step by step what i did.  i've never updated a wiki, not sure if this info would be good on there?
step 1:  my open stick and the pasrt i'm going to use
step 2:  shaft with ball top removed
step 3:  magnet on shaft
step 4:  apply some crazy glue around the magnet, slip collar over the magnet until it's flush with the shaft
step 5:  measure and cut outter brass so that when placed over the magnet and shaft, it will be just above the control panel.  do not have this outter tube rest on the panel.  i did this the first time and then when moving the stick, the pressure would cause the magnet to disconnect
step 6:  before placing the oitter tube over the magnet, i had to wrap a bit of duct tape around the magnet/inner tube so that when the outter tube slips over, it's nice and tight
step 7:  pop the trigger stick on and measure where these tubes will be sitting
step 8:  fill half the trigger stick base with the mixed putty, press the tube down into place.  fyi, for the wiring, i had to drill a small hole in the base of the stick
step 9:  cover the tube with the rest of the putty.  then put the other half of the stick on and squeeze.  allow to dry and put the screws back in.  with this stick, i did lose the bottom screw as i had to break out some plastic so the tube would fit in.  but with this putty, once it dries, it just about bonds to the plastic, keeping the two halves together.
let me know if you have any questions
« Last Edit: May 27, 2012, 11:31:29 am by tony.silveira »
AGarv
« Reply #38 on: May 27, 2012, 08:15:33 pm »
OK, that tutorial is awesome - the trigger stick must feel solid as a rock during play.  If you can add that on to the current wireless hot-swap trigger stick wiki by LeChuck, I think it would help a LOT of people out as this is becoming a popular mod.  Do you remember where the magnet and tubing was named/purchased from?
Los Abrazos Rotos
« Reply #39 on: May 28, 2012, 05:22:09 am »
Damn thats clever, yet another "why didnt I think of that" moment
So is it totally solid?
