Author Topic: no Neo Geo Roms work.. tried everything.. working on this for hours please help  (Read 2168 times)
greenday8616
  • Last login:March 01, 2012, 08:12:42 pm
hey i cant get any neo geo roms to work on my mame emulator.. i'm running .0135 command line version and using mala as a front end.. i downloaded at least 3 versions of the neo geo bios( in case i had a bad download).. no i didnt extract it.. it's sitting in the rom folder ive updated the rom folder.. i'm getting nowhere.. every single neo geo rom will not work.. i even tried downloading neo rage x and configuring mala to run that but its not a command line edition so i guess that won't work.. anyone have ideas?? oh also in mame 32 i tested  aero fighters and it worked perfectly... so its not the roms...
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
do you have the right roms for the version of mame you are running?  when mame updates, often the roms are redumped and you'll need these newer versions.
what happens exactly when you select a rom to play?
greenday8616
it just won't start and says files are missing.. but the thing is its every neo geo rom not just some.. the best workaround i can think of running neocps instead and just making a rom list for that in mala that is all the neo geo stuff
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Get the name of one of the files that it says is missing, then search for it on google.  that will probably point you to one of those sites that tells you when that file started getting used (as in what mame version) and you may also find out that there was an updated bios package that came out after the stuff you've been downloading.  you can either keep searching for the files you need, or even take a step backward in MAME.
Thenasty
  • Last login:Yesterday at 11:40:37 am
1. probably missing your NEO-GEO BIOS file (neogeo.zip) if ALL YOUR NEO GEO games don't work.
2. You probably go the wrong Bios File.
3. You also need the Game ROM along with the Bios File
4. Path is wrong
5. You need a ROM manager like Clrmame pro to check/fix your ROMS
6. Check MAWS for a list of the filenames your missing.
« Last Edit: February 01, 2010, 08:13:42 am by Thenasty »
Free VGA Breakout Cable
