Author Topic: Wiring two joysticks together?  (Read 2105 times)
SephYuyX
  • Last login:November 28, 2013, 11:40:04 am
  • I Am, Who I Am.
« on: December 24, 2009, 03:10:32 pm »
I just realised I made an oversight when planning for the parts I need for my CP. I plan to have 3 joysticks (2 players and one for 4 way games), and was going to use IPAC2, but then I realized IPAC2 only has room for two joysticks (keep in mind all the button slots are taken), duh, what was I thinking.
So I thought since one would never use one player 8 way and the 4 way at the same time (correct?), why not wire them together?
Would this be a passable idea?
Bobulus
  • Last login:July 11, 2014, 10:42:28 am
Re: Wiring two joysticks together?
« Reply #1 on: December 24, 2009, 03:24:58 pm »
It should work, as long as you don't jostle the 8ways while using the 4way.
Alternately, all the ipac inputs are the same; You could just wire the way to something else, like those 1A 1B 2A 2B connections at the bottom.
edit: Oh, you said all the buttons spots are taken. Yeah, I'd just wire both to player 1 or something.
unclet
« Reply #2 on: December 24, 2009, 04:03:53 pm »
I wired my 4-way joystick to my 8-way joystick.  Just as long as no one moved the 4-way joystick while playing a game then you should be fine.   Never happened to me, so it seems to work fine.
Scotty
  • Last login:May 01, 2025, 09:16:56 am
« Reply #3 on: December 24, 2009, 06:19:24 pm »
I have done it as well.  Works fine.
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #4 on: December 26, 2009, 03:05:18 am »
You could also wire a 2 way switch and wire the grounds to it so either the 4 way or the 8 way would be grounded, if you want to have no chance of bumping it.
Thenasty
  • Last login:Yesterday at 10:21:15 pm
« Reply #5 on: December 26, 2009, 10:30:34 am »
or just configure your player 1 8-way to be 4-way via configuring MAME not to acccept the corners. But then its all about the feel of the true 4-way you'll be loosing.  :banghead:
Free VGA Breakout Cable
cnsf
  • Last login:June 30, 2023, 05:31:20 am
« Reply #6 on: December 26, 2009, 11:21:45 am »
I did the same on my cab and it works fine.  The 4 way and 8 way both are wired to the same opsitions on the IPAC.  see www notrica com/arcade/cpanel.shtml
