January 29, 2026, 04:41:54 pm
pkunzip *.zip destination
Quote from: CCM on June 25, 2009, 05:46:02 pmpkunzip *.zip destinationMan, that brings back some memories
You can download 7zip, it comes with a command line tool that should handle everything.
if you have WINZIP installed, just select all your ZIP FILES and then RIGHT CLICK/DRAG over a bit to the side where it is a empty spot, then click UNZIP HERE.
Quote from: Thenasty on June 25, 2009, 10:48:36 pmif you have WINZIP installed, just select all your ZIP FILES and then RIGHT CLICK/DRAG over a bit to the side where it is a empty spot, then click UNZIP HERE.That's a GOOD TIP, man. The last time I had to extract hundreds of files, I couldn't figure out how to do it in Winzip so I went out to look for the old pkzip. Turns out it was called command line pkzip and they were charging for the full version. Go figure.
