Author Topic: Asteroids and other vectors unplayable in MAME  (Read 12806 times)
blkdog7
  • Last login:October 07, 2015, 04:43:38 pm
  • Mushroom Kingdom, MA
    • John's Arcade
« on: April 19, 2009, 05:43:48 pm »
I have an Intel Celeron 2.4, 1.5 gb of ram, MALA front end, MAME 1.29, J-PAC in a Ms. Pac-Man cabinet with vertical monitor.
I am unable to play any of the Asteroid games at all on my machine. They are unplayable. Sound goes very slow and so does the gameplay. Everything is in slow motion. All my other games work great, just these vectors. Any settings I am missing?
Thenasty
  • Last login:Yesterday at 10:04:40 pm
Re: Asteroids and other vectors unplayable in MAME
« Reply #1 on: April 19, 2009, 10:33:32 pm »
Lowering down the samplerate will improve slowdown. You don't need 44100 samplerate for Asteroid IMO.
Free VGA Breakout Cable
NIVO
« Reply #2 on: April 20, 2009, 04:05:52 am »
could also try the AAE emulator for vector games. Its atleast worth a shot to get it going  http://pages.suddenlink.net/aae/
isucamper
  • Last login:November 25, 2019, 05:13:08 pm
  • I'm a slasher... of prices!!
    • my project arcade blog
« Reply #3 on: April 20, 2009, 08:07:42 am »
I can remember on one system I was using, there was a big difference between using:
-video d3d
and
-video ddraw
One of them was real slow and unplayable, and the other was lightning fast (can't remember which was which).  Do you have an integrated video card?
THE SYSTEM          Popeye
blkdog7
    • John's Arcade
« Reply #4 on: April 20, 2009, 09:57:59 am »
-video d3d
and
-video ddraw
I have  a PCI GeForce FX5200. I am using DDRAW which (I think) is what you're supposed to use with the J-PAC and Soft15k in all my readings.
blkdog7
    • John's Arcade
« Reply #5 on: April 20, 2009, 09:59:43 am »
Thanks! I'm gonna give that a shot unless someone knows why MAME isn't doing it for me.
Ummon
  • Trade Count: (+13)
« Reply #6 on: April 20, 2009, 04:12:33 pm »
Because your system is underpowered. Old, old, old, old story. Your card may be underpowered for AAE, too.
Yo. Chocolate.
Stephen Hawking
blkdog7
    • John's Arcade
« Reply #7 on: April 21, 2009, 10:18:45 am »
How can my computer be underpowered to play one of the oldest games around? I just don't see how that is possible. My video card too? A GEFORCE FX with a good chunk of RAM?? Really?
Minwah
    • MAMEWAH
« Reply #8 on: April 21, 2009, 12:12:02 pm »
FYI, vectors look shite (particularly) on low-res monitors since the last major Mame video re-write (v0.123 IIRC?). It has less vector options than previous versions. I use an older version (v0.99) for this reason, and it will also be faster...
blkdog7
    • John's Arcade
« Reply #9 on: April 21, 2009, 02:03:16 pm »
Ok, thanks for the info! Do you think V0.99 is better in general for a setup like mine? I encounter a few classic that don't seem to be running as well as they should.
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
« Reply #10 on: April 21, 2009, 06:10:21 pm »
did you say what os your running? i may have missed it.
on Windows 7 64bit, vector games are unplayable for me.  on windows xp they're fine.
blkdog7
    • John's Arcade
« Reply #11 on: April 21, 2009, 07:11:05 pm »
I am running Windows XP with SP3.
I tried MAME .78 today. I couldn't even get MALA to launch the game. Nothing would happen. It just sat there.
cmoses
« Reply #12 on: April 22, 2009, 09:26:05 am »
Not sure if this is a similar issue or not, but wanted to tell you about a recent experience.  I was having problems with a few "higher" end games, Shuffleshot and World Class Bowling Deluxe.  I was getting some slow down and some sound stuttering.  I posted a topic and did some searching.  Well it seems that DDRAW is the preferred choice as far as graphics are concerned.  So I changed that in my mame.ini file.  I think it might have helped a little but not a lot.  So I was playing other games to see if it made any difference.  I didn't really see any differences in the games until I tried Asteroids.  Suddenly my Asteroids was unplayable.  Pausing, slowness, sound issues, etc.  I also tried Asteroids Deluxe and the same thing.  I went in and changed their ini settings to be D3D and they worked perfectly again.
Ummon
« Reply #13 on: April 22, 2009, 02:19:42 pm »
Ram isn't really the issue, but the clock values of your card. I'm using an Nvidia 6200, and it doesn't have enough oomph for AAE. My 6800 does, though. Similar with mame in that it's processor-based. The 'that game is so old!' exclamation is really old, too. I've seen it several times at Mameworld. You have to understand how emulation works, but very grossly it's a matter of exponential resource usage of a general purpose device vs the original hardware operating in machine language.
« Last Edit: April 22, 2009, 02:24:46 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
blkdog7
    • John's Arcade
« Reply #14 on: April 22, 2009, 04:32:34 pm »
I really don't know much about how MAME works but it's my understanding that it doesn't really need a good video card at all, it's more about the horsepower of the CPU and the GPU.
zorrobandito
  • Last login:October 04, 2025, 12:11:09 am
    • Zorro's Classic Games
« Reply #15 on: April 23, 2009, 08:33:14 am »
I also run MAME 0.99, it loads relatively quickly and is missing very few games of note. Also Asteroids is the bomb! ;D
Try it and see.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #16 on: April 23, 2009, 05:33:59 pm »
if I remember the slowless of this game in a newer mame might been a sound issue, because it now emulator the sound rather than using the sound samples? Not sure it was for this game or a other game I was thinking? emulating the sound is very cpu hungry in these games using analog circus rather than a sound cpu. But here I do can take wrong?
AAE use the graphicscard a much more than you even think and use a loits of shader effects to show a nice image.
GAJoe
  • Last login:September 05, 2012, 03:35:51 pm
  • Bluster Blaster will DESTROY YOU!
« Reply #17 on: April 25, 2009, 05:59:54 am »
I was thinking this was the right answer, since it was the cause of my problems with Donkey Kong, but I just tested with my own system and Asteroids seems to run at full speed with clear sound and no slowdowns.  That's on a Celeron 2.6GHz, 2GB of RAM, GeForce4 MX420.  I used MAME .114, .119, and .127.  They all seemed fine.  None are using samples.
You can look at what's been changed about the Asteroids driver between different versions of MAME here:
http://www.arcadehits.net/datObase/rom.php?zip=asteroi1&s=VIEW
EDIT:  When I switched from D3D to DirectDraw with no hardware stretching, Asteroids did slowdown and experienced weird jittering sound.  So it appears that could be part of the problem.
« Last Edit: April 25, 2009, 06:19:21 am by GAJoe »
Robbbert
  • Last login:February 13, 2026, 03:19:56 pm
« Reply #18 on: April 26, 2009, 04:17:51 am »
I just tried ddraw in mame 0.131 and it went the same speed as d3d..
In case you are interested, you can create "vector.ini" in your ini folder.
It will take precedence for all vector games.
So, for example, you can set the brightness to be more like a real asteroids
brightness 1.0
contrast 2.0
gamma 3.0
and it will apply automatically to all vector games.
cmoses
« Reply #19 on: April 26, 2009, 11:47:08 am »
If you create that vector.ini will it only be for those settings?  Will it pull the other settings from your mame.ini or from the game specific .ini for everything else?
Robbbert
« Reply #20 on: April 26, 2009, 01:54:53 pm »
Hmm, I wasn't very clear...
Copy asteroid.ini to vector.ini
Then edit vector.ini, and change any lines you wish.
The 3 lines I listed are what I changed in my vector.ini
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #21 on: April 30, 2009, 01:18:39 pm »
Mame reads ini files in a certain order (assuming readconfig is left at default enabled).
First mame reads mame.ini, then vector.ini if a vector game, then sourcefile.ini, then parent.ini then game.ini, and finally the commonline options, each overriding the prior settings.
(Actually, even the above is simplified for easier understanding and less typing  ;D.)
Each of the ini files can be blank, have a few options, or all the options that are in mame.ini.  Personally, I like keeping the specific ini files as small as possible; I only put the options I know are different than mame.ini or that I don't want mame.ini to change.  This way, if I want to make a global change, I only have to edit mame.ini (assuming the option I'm changing isn't set in any of the specific ini files).
FWIW, if you have mame.ini, vector.ini, and asteroid.ini, and all are "complete ini files" with all the options, mame will act as if only the asteroid.ini file existed for asteroid, and as if only vector.ini existed for other vector games.
Robin
Knowledge is Power
