Author Topic: Sanwa JLF/JLW/Ultimarc U360 top mounting guide  (Read 66867 times)
Franco B
« on: March 13, 2009, 04:11:51 am »
I started work on my Xbox 360 arcade sticks last night and I thought I would do a top mount guide for anyone wanting to top mount there joysticks.
Japanese joysticks such as the JLF and JLW amongst others are traditionally mounted to a thin metal CP. If you bottom mount them you reduce the shaft length between the CP and ball top and you end up with a stick height that is unsuitable. This guide will show you how to top mount them so that you retain the full shaft length. The U360 is a modified Sanwa JLW so this guide will also work for that.
I'm not saying this is the best way to top mount sticks but its what works for me.
I'm top mounting a Sanwa JLF in this guide but you can apply the techniques to other sticks.
The tools I used were:
Drill (hand or bench/pillar)
Jigsaw
Router
Router bits - 1/2" flush trim, 3/4" pattern bit
Router table (not necessary but it does make things easier IMO)
Pencil for marking out
Scrap pieces of MDF for making templates.
I'm making some templates in this guide to keep everything nice and neat. Making templates is also handy as once you have them made you can quickly churn out multiple CPs. You don't have to make the templates but I think its much easier in the long run.
1) Disassemble the shaft from the joystick by removing the e-clip. Remove the other components from the assembly and put them to one side. Remove the four screws that hold the mounting plate to the joystick base and remove the mounting plate.
2) You need to make a though hole in the CP for the base to fit through. This is where I made the first template. Trace round the joystick base on a scrap piece of MDF.
3) Remove the bulk of the material from the inside of your traced line. I drilled four 10mm holes close to the corners and then used a jigsaw to remove the center section. You then need to remove enough material so that the joystick base slides through the hole. You can use any method to remove the excess but I free hand routed mine using a 1/4" bit on my router table. You could jigsaw, scroll saw, file etc - whatever works for you.
The joystick base should fit nicely through the hole. I left about 1-2mm for clearance but it doesn't really matter as long as it fits in. You don't want to remove too much material though as you will be reducing the amount of material that the mounting plate will eventually sit on.
4) That's the first template complete. I then made a second to use to counterbore the recess for the mounting plate to sit in. Trace round the mounting plate on another piece of scrap MDF.
5) Cut out the excess again and remove the last of the material leaving a mm or two for clearance.
You can see I extended the corners slightly. This is because the pattern bit I am using has a much larger diameter (3/4"-19mm) than the radius on the corners of the mounting plate (~5mm). The extended corners will allow the mounting plate corners to fit inside the profile.
6) That's the templates complete. You can now use them to template route your CP. Mark out your joystick position on your CP.
7) Fix your 1st template to the CP and use a flush trim bit to template route the profile after removing the excess. I used my DIY router table but you could do the same using a router normally.
8.) Attach the mounting plate to the joystick base and slide the base through the hole you just routed. You can then trace round the mounting plate to find the recess position.
9) Put your second template over the marked out position and fix it to the CP.
10) You can then use a pattern bit with your router to route out the recess. You need to remove the height of the mounting plate plus the height of the mounting plate you are using. I'm using some M5 machine screws that I faced off to leave a 1mm thick head so my recess depth was ~3mm
These are the pattern bits I have. I used the shorter 3/4" bit so that the bearing runs along the templates profile.
11) Unscrew the template from your CP and you should be left with something like this:
12) Insert your mounting plate and joystick base into the hole and recess. Check that the recess is deep enough. If its not the adjust the router height and go round the profile again. Once you are happy with the depth you can trace the mounting hole positions.
13) I'm using M5 machine screws and bolting the mounting plate to the CP with some M5 dome nuts so I drilled 5.5mm holes.
14) Finally reassemble everything. Job done :)
Keep the templates as they will come in handy if you need to mount any more joysticks.
Hope this helps  :cheers:
markronz's recommended mounting plate modification:
I can explain to you what I ended up doing with mine.  I used a bit to customize the mounting plate a bit.    I basically made the mounting holes recessed so that the screws would sit level with the rest of the mounting plate. See below:
Here is a picture with the screws in place.   As you can see, the whole top of the mounting plate is now level.
When recessing the mounting holes, you just have to make sure to use a V shaped tool to recess the holes.  Then of course don't go too far.  The screws still need to catch the metal, but yet need to sit even with the top of it.   If you route in too deep, the screws would just fall through the holes.   So that was the only touchy part for me.
And yes, my dust washer is on top of the artwork.   For me, that's how I'd prefer it anyway.
« Last Edit: November 04, 2011, 04:15:43 am by Franco B »
thatitalian
  • The Revolution Is Coming...
Re: Sanwa JLF/JLW/Ultimarc U360 top mounting guide
« Reply #1 on: March 13, 2009, 06:59:08 am »
One word: NIIIICE! :afro:
Where did you get the short pattern bits from?
Also, where did you get the flat screws (metal circles) for the Joy plates? Those are perfect for flat top mounting!
Franco B
« Reply #2 on: March 13, 2009, 07:25:34 am »
I bought [this] set from the US. They also sell the smaller one on its own [here].
I bought the set as they come in handy, especially at that price! :)
The 'flat screws' you see in the picture were actually the rounded hex head screws you see in the picture with the dome nuts. I just machined them to give a 1mm thick head. I bought a box of 100 from screwfix so if you want a few for your CP just let me know and I'll machine some and post them over with your other bits.  :cheers:
You could just use the un-machined screws or similar other screws but the 1mm thick head allows you to retain as much of the shaft length (oo-er!) as possible.
thatitalian
« Reply #3 on: March 13, 2009, 07:36:33 am »
Just bought my set!!! ;)
For the money you can't argue! Shame about the USD though! :(
If you can do me some bits to extend my shaft I would appreciate it! (not that I need my shaft extending, but every little helps :P)
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #4 on: March 13, 2009, 09:34:24 am »
Question, the most common number I see used for mounting depth taken from the top of your control panel is 9mm deep. So with 3mm plexi, 6mm would be ideal for the recessed depth but I'm not sure how thick your top layer is going to be. Were you targeting the 9mm overall depth as well?
Franco B
« Reply #5 on: March 13, 2009, 09:48:50 am »
I'm using 12mm MDF with 3mm acrylic and 5/8" t-moulding.
The recess is aprox 3mm deep which will give 9mm of material to bolt through.
Does that answer your question?
cmoses
« Reply #6 on: March 13, 2009, 10:32:32 am »
Franco B,
Very nice write up.  Can you give some more information on your mounting hardware, nuts and bolts?  You mention using some M5 machine screws that you faced off (meaning your sanded down?).  In the picture it still shows the hex pattern, but in the final picture it looks as though the screw head is completely smooth?
I got some machine screws yesterday at Home Depot that had a low profile head (flattest ones I could find).  That I think will work pretty well.  I think I will have to route out a little more than 1/8" maybe 3/16" which will leave 7/16" or a little less than a 1/2".  But these were the flattest bolts that I could find.
« Reply #7 on: March 13, 2009, 10:49:41 am »
Very nice Franco!  What are you going to do about the voids left around the mounting plate?  Are you going to use some spackle or filler and then sand it flat (permanently encasing the mounting plate)?  If not, how are you going to handle the wrinkles in the artwork that will show though in that area?  Is this even a concern?   :cheers:
MrMojoZ
« Reply #8 on: March 13, 2009, 12:07:06 pm »
Yes, but if this is the case your mounting depth is 3mm short of the officially recommend depth of 9mms. Your plexi would need to be 6mm thick to use a 3mm recess. I doubt it really matters but if someone was anal about the stick height they would proably notice. Also, I need a router table.  :-\
massive88
« Reply #9 on: March 13, 2009, 12:38:06 pm »
Bottom mounting into a 1/4" left recess using 1/8" plexi gets you almost exactly to the 9mm recommended, which is why I have always bottom mounted my JLFs in 1/4" material.
Nice guide Franco.  Final product looks great!
Franco B
« Reply #10 on: March 14, 2009, 06:07:47 am »
Franco B,
The machine screw in the final pic isn't actually the type I will be using, it's just one I had to hand from experimenting with different bolts. The ones I will be using will be the first one in the black picture with the two bolts and nuts. The bolts I got came as the second one in that picture. I put them on a lathe and faced the excess off with a turning tool to leave a 1mm thick head. The hex cannot be used anymore as the material has been removed but the nuts will still be able to be tightened sufficiently from the back.
Any bolt should do really with a relatively thin head and it sounds like you found some suitable ones. If the recommended mounting depth is 9mm then you have plenty of material to play with and you can increase the recess to over 1/8" so that your bolts sit below the MDF CP top.
Cheers bud. The voids shouldn't really be a problem as the top of the bolts sit flush with the MDF CP top and they will support the art etc. I would be more concerned about the artwork sagging in the area between the bolts where the dustwasher is. In the worst case scenario I would make a ring to sit in between the bolts to support that area. The first stick I'm making is going to be covered in 0.3mm (0.012") thick carbon fibre which is fairly stiff so it shouldn't sag:
My second stick is going to have printed artwork. I'm going to try and get it printed on some heavier gauge paper or use some thin card to support the artwork.
Thanks for the info. I didn't realise there was an officially recommended height. I would have thought that the depth would have been less but I don't know the thickness of the metal CPs. I guess there must be some ~3mm bosses on the back of the CPs where the mounting plate as attached.
The stick feels comfortable at the height I have mounted it. If I do change my mind about it it will be easy to reattach the mounting plate template and remove some extra material.
Blanka
« Reply #11 on: March 14, 2009, 06:43:57 am »
The idea is good, but leave out the disassembly of the joystick. There is absolutely no need to do that. Difficult to route: just make the hole in the MDF with a fret-saw, and only use the router for the recess. Don't have a router: make the panel of 2 sheets of mdf. one 4mm thick for the recess, and the other 9mm for the mounting. Then you can add 4mm of plexi and artwork to get to the 18mm in total.
Franco B
« Reply #12 on: March 14, 2009, 07:06:16 am »
Like I said, its not a definitive guide, its what works for me.
You do need disassemble the joystick with this method to trace around the various parts and line up the templates etc. Is it really that hard to remove an e-clip and four screws?
Its not difficult to route. Its takes a little time to make the templates and then you can mount the joystick very fast. I can easily knock out four identical panels in less than an hour, something which would take much longer with a fret saw etc.
Blanka
« Reply #13 on: March 14, 2009, 07:39:25 am »
But can you mount a fresh joystick without disassembly in those holes? How about the pins on the switches?
It's OK to disassemble one to get the measurements if you can't do that by just using a ruler on it, but it would be too much work to disassemble every stick if that is needed for mounting.
And with a decent true-man-wanking-arm you can fret saw 8 joystick holes within the hour too with no problem  :laugh:
Franco B
« Reply #14 on: March 14, 2009, 07:50:44 am »
Complete disassembly is only necessary for making the templates for the 1st one. After that you don't need to disassemble the joysticks for subsequent CPs.
Lol @ true-man-wanking-arm  :D
Okay, ill race ya ;)
ViciousXUSMC
  • Last login:July 28, 2009, 10:25:53 am
« Reply #15 on: March 16, 2009, 03:41:19 am »
Tag, Nice Guide
I want to use a Sanwa or a Seimitsu in my next build just so I can say that I tried both sides of the joystick world (JP vs US) and this will come in handy probably.  I wish I had a router table, or even a table lol.  I do most of my work on the ground....
I have to know where did that button layout thing come from?  Not the printout, thats like what I used from slagcoin but it looks like a metal 6 ring object that could be used to route the buttons perfectly.  I absolutely must get that for my next project.
Franco B
« Reply #16 on: July 11, 2009, 01:48:27 pm »
Apologies, I've only just seen your reply after searching for this thread for someone. I do sell internal copies of that drilling/routing guide. They are currently MDF but will soon be made from HDPE or similar. You can see them [here] in my BST thread.
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
« Reply #17 on: July 26, 2009, 03:48:09 am »
Any newer links to the router bit set that you bought?  The link is stale now. :(
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
Franco B
« Reply #18 on: July 26, 2009, 01:06:00 pm »
[Here] ya go. I'll also include a link to the seller [here]. If the item link expires again in the future you should be able to find the set amongst his items. Look/search for '3 pc 1/4" SH Top Bearing Trim Pattern Router Bit Set'.
GaryMcT
« Reply #19 on: July 28, 2009, 07:01:44 pm »
Would you consider using something like that Joystick "Blind Hole" Mounting kits on this page with this sort of routing to avoid having to muck with the mounting screws?
http://www.ultimarc.com/controls.html#mountingkits
Franco B
« Reply #20 on: July 29, 2009, 01:24:52 am »
As MrMojoZ etc said the 'official' mounting height (which I didn't know about) from the top of the mounting plate is 9mm. If you are using 3mm (1/8") acrylic you will still have 6mm (1/4") to play with so if you make the recess ~7mm deep (6mm difference + 1mm mounting plate thickness) you will have a 6mm (1/4") void for your screw heads to sit in so there is no need to bother with low profile bolts like I did. I would just use some M4 bolts and nuts (or 6-32 UNC or whatever you guys use).
GaryMcT
« Reply #21 on: July 29, 2009, 04:36:44 am »
Thanks.  That makes life easy.  I haven't fully absorbed this whole thread yet. :)
4nubis
  • Newbie
  • Last login:September 24, 2009, 09:28:08 am
« Reply #22 on: September 20, 2009, 01:20:09 pm »
Now, this topic was helpful (for a woodworking noob like me).
Thanks for visualising this  :applaud:
Stickify !
Donpatchi
  • Last login:May 17, 2015, 04:09:28 pm
« Reply #23 on: October 09, 2009, 11:09:10 am »
That has been a usefull guid indeed.
Thanks for putting it under my attention.
Franco B
« Reply #24 on: October 09, 2009, 12:13:57 pm »
Your more than welcome :)
ammitz
  • Last login:April 25, 2017, 07:22:09 am
« Reply #25 on: October 15, 2009, 02:59:27 am »
These imperial measurements are killing me...
I'l find the calculator and translate it to mm's
Building my first bartop CAB
Epyx
  • "You're an oddity"
« Reply #26 on: October 15, 2009, 12:26:05 pm »
Agreed, great guide Franco. I will be doing this with my next CP.
Last Project
Epyx Tutorials:
Tutorials
Epyx
« Reply #27 on: April 02, 2010, 03:02:46 pm »
Thanks again FrancoB!  :cheers:
Fantastic guide and method!
Last Project
Epyx Tutorials:
Tutorials
Franco B
« Reply #28 on: April 02, 2010, 03:28:58 pm »
Thanks and thanks again :)
markronz
  • Game on!
« Reply #29 on: October 11, 2010, 03:14:31 pm »
This is a great guide.   Seems very easy to follow.  I do have a question about it though.  Is this guide assuming that plexi glass will be on top of the artwork then?   I am just confused about the bolts sticking out.   I read in there, that you can recess the whole thing further, and then the bolts attached to the mounting plate will be level with the rest of the CP.   But it would seem the problem with that, is then that the rest of the mounting plate would be too low.
I plan to order artwork from GameOnGrafix.   I know the laminate stuff they use is pretty thick, but you'd think that if the mounting plate was so low in there, it would likely wrinkle or get messed up.   That is, unless you had plexi on top to prevent the player from pushing it in?   Am I wrong here?  Or what am I missing?
Franco B
« Reply #30 on: October 11, 2010, 04:06:21 pm »
Yeah I was going to use an acrylic top sheet. The CF sheet I was using is stuiff so it wouldn't sag.
If I was using conventional artwork I would probably sandwich the artwork between two 2mm acrylic sheets.
lord-jaffa
  • Last login:April 05, 2012, 11:12:12 pm
« Reply #31 on: October 15, 2011, 06:39:10 pm »
If this is the case, would it not be better to recess 9mm out from the bottom instead of top mounting them? (if 3/4 boad is used that is) I would this this would be way easier, and probably stronger too.
Turambar
  • And I don't watch Fox news or use Happ joysticks.
  • Last login:October 03, 2021, 11:10:13 pm
  • Owner of Wayback's Arcade
    • Wayback's Arcade
« Reply #32 on: October 24, 2011, 09:51:30 am »
Thank you for the guide.  There was no response to Markronz's questions, and those are the very answers I need.  If you used this guide, would not the top of the machined screws be even with the top of the CP?  If that is the case, the top of the joystick plate would be just a few millimeters from the top of the CP.  This would cause there to be a good bit of surface area that was just lower than the top of the CP.  If you used a printed CP from gameongrafix and wanted to get the one with the adhesive backing and forgo the plexi top.  If I did that... what would happen where the adhesive printing encountered that lower spot on the joystick plate?  Secondly, I would assume the dust washer would have to be on top of the artwork if you went with the adhesive backed printing?  Can anyone comment on this?
markronz
  • Game on!
« Reply #33 on: October 24, 2011, 10:26:13 am »
Turambar
    • Wayback's Arcade
« Reply #34 on: October 24, 2011, 11:52:35 am »
Thanks for the post, Markronz.  That does look like it would solve the issue.  I am seriously thinking about bottom mounting and going with longer sticks at this point.  I am just not certain about my ability to do your mod, and I still like the idea of having a completely smooth surface to mount the adhesive backing of the CP art to. I am at the point on my project where my artwork is being made, and I currently am second guessing a lot of things before building my panel.
1st, my original intention was just to use some Happ competition sticks.  I have now hung out around this community enough to get the feel that the happs would almost be the last choice of everyone here.  So now what?  Do I invest in 2 u360s (a cost I hadn't really counted on) or should I just get some sanwas... too many choices on things is making me indecisive.
markronz
  • Game on!
« Reply #35 on: October 24, 2011, 12:42:23 pm »
Yeah, you know it's a difficult decision.    For myself, I have one arcade that has Happ Comp's on it. It was my first arcade. And I actually don't mind them at all.  They get a somewhat bad rap around here, but I really don't mind them.   I guess it depends on your preferences.  Some people just have set idea of what things should feel like.    They were affordable and they worked decently well for what I use them for.   So I don't regret using them.   Now having said that, on my second arcade I made, I used the Sanwa JLF's with octagonal restrictor plates.    I LOVED these joysticks.   I just love the ball top feel, and they just moved so much smoother than the Happ Comp's.   I can still go back to my first cabinet, and it's still playable.  I don't hate the joysticks, but I did enjoy the Sanwa's a lot more.
So I guess it's really up to you.   If you don't have a lot of money, I don't feel that theres any shame in going with something more affordable like the Happ Comps.   From what I hear, it's fairly easy to upgrade later too.   But if you just want to get it right the first time, and not have to think about upgrading something in the future, then you will want to consider the alternatives.
If I had the money, I would easily get some u360's, and be done with it.   Seems like it's bar none the most preferred choice around the forum.   I personally have only used the two joystick types I've mentioned, so I can't give any real opinions on any other models.   But good luck in your decision!
Turambar
    • Wayback's Arcade
« Reply #36 on: October 24, 2011, 01:13:26 pm »
What was the full model number of the Sanwas you went with?  For me, knowing that I am going to shell out a lot for the art, I want to get the CP right on the first time and not have to upgrade later.  I have read more about doing the countersinking you did.  I think I might get brave and try it :)  I hope I don't have to buy an extra plate.
markronz
  • Game on!
« Reply #37 on: October 24, 2011, 01:56:47 pm »
I personally used the Sanwa JLF.  I believe it was a JLF-TP-8YT  to be exact.   I purchased an old Tekken 4 machine, and it had two of these joysticks in it, and they looked to be barely used.   So I decided to reuse them in my machine.  That's my main reason I went with that model, although I know the Sanwa JLFs are popular.
You can read more about the joysticks here:
http://slagcoin.com/joystick/attributes_brands.html#SANWA
Also, you can read more about mounting them here.  This is where I got the idea to modify my mounting plate:
http://slagcoin.com/joystick/mounting_layering.html
The main thing you want to think about though, is how many 4 way games you plan on playing.   If you are a classic arcade game fan, you will want to think about a 4 way joystick, or getting the u360s.  As with all 8 way joysticks, playing 4 way games on them can be challenging.   For me, I found I was able to play the 4 way games just fine, but it depends on the person.   I think when using an 8 way joystick, you just need to be more conscious of how you move the joystick, to make distinct up/down, left/right motions.
Anyway, I personally purchased my parts from Lizard Lick
http://www.lizardlick.com/Sanwa_c_146.html
But I know other sites, such as Paradise Arcade offer some parts as well
http://www.paradisearcadeshop.com/en/17-sanwa-joysticks
I personally went with Lizard Lick at the time because I had the joysticks, but did not have mounting plates for them.  When you purchase them new from a vendor, however, they will come with a mounting plate.   But I went with Lizard Lick because PE does not appear to offer the mounting plate on it's own.   Looks like the plates are about $6.  So if you were to mess them up, it wouldn't be the end of the world.  :)
Turambar
    • Wayback's Arcade
« Reply #38 on: October 24, 2011, 03:30:32 pm »
You have been incredibly helpful!  Last question... do you remember what screws you used or where you got them?
markronz
  • Game on!
« Reply #39 on: October 24, 2011, 03:58:57 pm »
No problem at all, glad to help.
I would have to say that I don't off hand remember, however, as luck would have it, I believe that is the box in the background of the first photo.
Machine Screws - Flathead slotted 10-24 , 3/16 x 1.5
Pretty sure any hardware store would have them.  Not sure where you're from but any Home Depot, Lowe's, Menards, etc should have them.
