Author Topic: Vs Super Mario Bros  (Read 3527 times)
Lecithin
  • Last login:April 04, 2012, 10:15:48 am
Vs Super Mario Bros
« on: February 19, 2009, 10:09:20 pm »
Well I've got a question and I fear the answer but since I intend to fully restore my cab I have to ask.
I recently purchased a Vs Super Mario Bros at an auction. Everything works perfectly... except the sound. The speaker makes a buzzing sound and if you turn it up it makes a screeching sound (I know its the speaker as I've played with the sound and plugged/unplugged it). Soo... thoughts from people who have had similar problems?
padstack
  • Last login:February 03, 2024, 12:54:24 pm
Re: Vs Super Mario Bros
« Reply #1 on: February 19, 2009, 11:15:58 pm »
you'll probably get a better response from the main forum, but I probably would have posted here too.  Sorry I can't be more helpful.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 20, 2009, 01:15:43 pm »
The audio amplifier circuit board is mounted on the video monitor. It needs to be recapped. Bob Roberts sells a kit for it.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: February 20, 2009, 02:45:16 pm »
Ditto what Ken said....fairly common problem.
Have you tried another speaker just for testing purposes then ?
(just about anything would work to test with)
Worst case scenario would be a game board problem.
Lecithin
« Reply #4 on: February 20, 2009, 03:45:15 pm »
two things to add to this;
1) I did try another speaker and I get the same thing
2) I removed the speaker, turned the sound up, and I can actually hear sound (very low) coming from the game, whats that all about?
am I to assume this is the kit then, Nintendo Audio Board Repair Kit    $5.00   (its under Sanyo)
« Last Edit: February 20, 2009, 03:53:18 pm by Lecithin »
Kevin Mullins
    • Me on Myspace
« Reply #5 on: February 20, 2009, 04:04:12 pm »
You are probably hearing bits of sound bleeding from the amplifier circuit especially if have it turned all the way up.
(not sure what else to call it, I'm sure there's a more technical explanation)
Are the sounds more normal to the game sounds?
And yes, that would be the audio board repair kit for the Sanyo 20EZ monitor.
(assuming you have the 20EZ)
Lecithin
« Reply #6 on: February 20, 2009, 04:10:17 pm »
Yes the sounds are very close to the normal sounds (perhaps a bit distorted). It caught me off guard thats for sure. I was playing and I'm telling the Mrs that I must be going nuts because I just took out the speaker and yet I'm hearing the sound.... it had me going for a bit.
As for which monitor it is.... I'm currently attempting to find that out. I know its mounted sideways (vertical perhaps?) but I don't see a tag/stamp telling me which it is.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: February 20, 2009, 05:14:21 pm »
Visit the monitor ID websites shown here:
http://forum.arcadecontrols.com/index.php?topic=62016.0
Kevin Mullins
    • Me on Myspace
« Reply #8 on: February 20, 2009, 06:47:09 pm »
And if it is a Sanyo 20EZ you'll find something to that effect stamped in the metal frame rails.
(something like 20EZV or so, I forget now)
Lecithin
« Reply #9 on: February 20, 2009, 08:54:06 pm »
On the rails I get   Japan EZV 1150521
a pic
another
« Last Edit: February 20, 2009, 09:18:19 pm by Lecithin »
Kevin Mullins
    • Me on Myspace
« Reply #10 on: February 20, 2009, 11:58:29 pm »
Yup, that's a Sanyo 20EZV
The small board with the fat grey cable in your first pic is the audio board.
Lecithin
« Reply #11 on: February 22, 2009, 12:38:43 am »
thanks, I kept hearing Sanyo EZ and I got JAPAN EZV so I wanted to make sure. :)
